Does anyone know what size wheels and tires Turner used on the M6 they raced? - BMW M5 Forum and M6 Forums
Old 22nd June 2012, 03:17   #1
MrBoom
Garage: 2006 M6
Thanks.
MrBoom is offline   Reply With Quote
Old 22nd June 2012, 08:08   #2
ktlocklear
ktlocklear's Avatar
Garage: 2007 M6; Black Sapphire
Email Kevin Foote....he is Turners tire man. If anyone knows it would be him. kfoote@turnermotorsport.com
2007 M6: Black Sapphire
Mods:
*Eibach Pro-Kit Lowering Springs
*Street Wheels- AG M310's 19x11/ 19x8.5; Powder Coated Jet Anthracite Matte
*Track Wheels- Apex ARC-8's 18x9.5 Squared; Anthracite Gloss with 275/35 R compounds
*Motul RBF 660 Race Brake Fluid
*Stop Tech Brake Pads
*RPI GT Exhaust ( Sections one, two, & three)
*RPI Scoops
*RPI Block Off Plates
*BMC Filters
*Charcoal Filter Delete
*Formula One Pinnacle Series Ceramic Tint; 15%
*Autotecknic Matte Black Kidney Grilles
*Matte Black Fender Grilles
*Stealth Front Turn Signal Bulbs
*Nokya Hyper Yellow H7 DRL's
ktlocklear is offline   Reply With Quote
Old 22nd June 2012, 14:38   #3
MrBoom
Garage: 2006 M6
Thanks. I sent an email. I know that your tire and wheel setup works well. Just wondered of it made sense to run a slightly wider tire to help with the extra weight and hp vs an M3.
Old 22nd June 2012, 16:49   #4
ktlocklear
ktlocklear's Avatar
I'd be curious to hear what Kevin tells you. I've seen their M6 several times at Barber Motorsports over the years, but I never looked at the tire sizes on it. All of their Conti's they had in their race tent stacked up that I saw were 275/35's....so if I had to guess, they used the same size on their M6 race car....but hopefully Kevin will clarify. Also, a lot of people just assume...but their M6 is really not a M6. It is a tube chassis with M6 panels, and I think, used the same V8 that they use in their M3's.
My set-up works great on the track. It is very balanced running the 275/35's on the 9.5's squared. Much better than the OE staggered sizes. If anything run a 285/35 squared...or if you can find the right offset wheels, go 275/35 on a 10" wheel squared. I've got a set of Nitto NT-01 275/35's that will be going on next, which are wider than the Conti scrubs
Old 24th June 2012, 07:13   #5
Hasan Shaikh
Hasan Shaikh's Avatar
Garage: E63 ///M6 - White
I think they use 18" wheels. Not sure about the other dimensions.
Hasan Shaikh is offline   Reply With Quote
Old 24th June 2012, 15:54   #6
ktlocklear
ktlocklear's Avatar
The do for sure on their m3's..... 18x10 squared with 275/35/18's
Old 29th June 2012, 04:42   #7
MrBoom
Garage: 2006 M6
Kevin didn't give the tire data for the M6 race car. He said it was a tube frame car and the info would be irrelevant. Makes sense. He did say that I could run a wider tire in the rear on a 10" wide rim if I didn't have to run a square setup, ie. 285, 295.
Old 29th June 2012, 05:26   #8
ktlocklear
ktlocklear's Avatar
Yeah... There is plenty of room for a 285 or 295 on the rear on a 10" wheel. I'm running a 19x11" wheel on the rear with a 285 for my street set up, and there is still room. I test fitted a 305 and it fits fine with no issues.....BUT, it will depend heavily on your offset.
Only reason i'm running the 275's squared for my 18x9.5 track setup is because it is a common size in a R compound with plenty of brand options...and honestly i have no traction issues running that size squared in R comps
Plus size tires on e39 M5 aliusa E39 M5 and E52 Z8 Discussion 15 10th September 2012 20:27
19" on M5 e39. Tires size? KGB_SSSR E39 M5 and E52 Z8 Discussion 12 13th December 2008 06:02
Size for winter tires? madcitym5 E39 M5 and E52 Z8 Discussion 2 30th August 2007 01:38
Recommendations on Wheel Spacers MM size & Tires on Hartge Classic ll 20" wheels? ///Bruno E60 M5 and E61 M5 Touring Discussion 6 26th May 2007 18:21
What size tires on 9x20 and 10.5x20 wheels? apexassassin E60 M5 and E61 M5 Touring Discussion 8 22nd March 2007 01:50
