And It All Starts With The First Mod (Full Build 08 M6) - Page 2 - BMW M5 Forum and M6 Forums
Like Tree5Likes
Old 15th June 2012, 07:23   #11
cpark352
cpark352's Avatar
Garage: 2006 M6
That looks great~ I just got my M6 a few weeks ago and, once I get the money up I think I may get some exhaust.
those look awesome.
cpark352 is offline   Reply With Quote
Old 15th June 2012, 08:45   #12
M6///Power_BuRR
Garage: BMW M6
looking goood nice!
M6///Power_BuRR is offline   Reply With Quote
Old 15th June 2012, 22:05   #13
shadowfaxss
Garage: 2007 BMW M6 Stratus Gray Metallic
Originally Posted by VGM6 View Post
Edited... tires are 295/30 currently had a typo with the stocks. I thought the same about the sidewall being to short but when i got the measurements it was less then a 5mm difference. Picks will be up as soon as I get the SD Card. Im looking to buy a wide angle lens for my DSLR then ill shoot some sick shots and post them also.
There is a difference here. Looking at the specs for the Super Pilot Sport:
Size Rim Width Range Measured Rim Width Overall Diameter Revs per Mile
245/40ZR19 8 - 9.5" 9" 26.7" (678.18mm) 778
295/30ZR19 10" - 11" 10.5" 26" (660.4mm) 799 (-21)
Using the Bridgestone S-04 Pole Postion (only one with all specs), the stock specs are as follows:
255/40ZR19 8.5" - 10" 9" 27.1" (688.34mm) 769
285/35ZR19 9.5" - 11" 10" 26.9" (683.26mm) 775 (-6)
Based on the sizes provided there is quite a bit of difference between the front and rear sizes selected for the Super Pilot Sports versus the stock specs for the S-04 Pole Positions.
shadowfaxss is offline   Reply With Quote
Old 15th June 2012, 22:44   #14
VGM6
VGM6's Avatar
Garage: M6 Coupe Alpine White
That seems correct but your width does affect the diameter of the tire slightly so if you were to compare the bridgestones 255 width with the 245 width which is the stock size there might be a difference. That's atleast what I found when I compared the pss tire sizes. Do you know what the stats would be for stock tires to compare them with what you already found. I wouldve got them in my stock sizes but they don't make pss's in that size yet. But its by far a way better tire then stocks you can feel the width of the tire as it grips. Good find btw
My Build Thread
2008 Alpine White M6-6MT
Cosmetics
Custom Painted White Side Reflectors
Custom Painted Black Grilles
Custom Painted Black Side Markers
Carbon Fiber BMW Roundels
VRS Carbon Fiber Front Lip
Weischlicht Angel Eyes V2
DCTMS Carbon Fibre Steering Wheel
Aluminum ///M Pedal Set
Performance
Akrapovic Evolution Exhaust
RDSport Pulley
ASR Intake
Dinan Throttle Bodies
UUC Short Shifter
Handling
RDSport Front + Rear Sway Bars
H&R Spacers (Front-12mm) (Rear 10mm)
H&R Springs
PSS (Front) 255/40/19 (100Y)
PSS (Rear) 295/35/19 (104Y)
In the Works
Stock Alcantara Headliner
Headers
4.1 Differential
RPI Oil Cooler
Republic Wraps Headlights (Umnitza V.4)
Republic Wraps Tail Lights
Dinan Carbon Fiber Front Strut Tower Brace
Dinan Carbon Fiber Rear Shock Tower Brace
Dinan Lower Control Arm Monoball Kit
Ground Control Camber/Castor Plates
VGM6 is offline   Reply With Quote
Old 16th June 2012, 00:27   #15
CatsFan
CatsFan's Avatar
Garage: Black Sapphire 2008 M6 E63
As much as I love my black beast I must say that this car looks best in white; yours is simply stunning. Love your work so far and looking forward to following this thread.
-David
2008 E63 M6 - Black Sapphire - Sepang Bronze Full Merino - Carbon Fiber Trim - Alcantera Headliner - SMG - HUD - Soft Close Doors - Comfort Access - Individual Audio w/Sat and HD Radio
2009 E92 335i - Black Sapphire - Black Dakota - Burl Walnut - Sport - Premium - Cold Weather - Navigation - L7 - Comfort Access - Smoker's Package
Member: BMWCCA #471614
CatsFan is online now   Reply With Quote
Old 16th June 2012, 01:06   #16
shadowfaxss
I agree that the Super Pilot Sports are a superior tire. I wish that they currently made the 285/35. There were specs missing for the front tires on the Michelin and Continental front tires. The section width (255 or 245) does not vary. However, the tread width is what I believe you are referring to. Most but not all tire manufacturers will provide the specs for the tread width. Some tread width are actually wider on say a stock size as compared to going with a larger section width and smaller profile. It is one of the items I consider when purchasing a tire. I can tell that my Conti's are round so the tread width is a bit more narrow then say the BS S-04 which is squared off with the bead protruding well past the rim seat to protect the wheel. Tire rack is a good place to learn about tires. Not insulting your intelligence mind you. Everything must be considered including the weight the tire is designed for.
Old 16th June 2012, 01:24   #17
VGM6
VGM6's Avatar
Hey thanks hahah no worries haha tire racks is a great site i just didn't no you could find stats like that from them.
Old 17th June 2012, 22:18   #18
VGM6
VGM6's Avatar
Just got a few more parts coming in. spoke to Serge at Benzworks to get it all set up soon. I will be doing a before and after vbox run, dyno and gopro the rear exhaust and front of the engine bay to get a before and after....... Hint hint guess what the next mods will be . I'll post pics as the parts come through over this next week.
Old 18th June 2012, 04:47   #19
princevick
Garage: E63 630i Black
@VGM6:
Beautiful car mate!
I am looking at getting a custom made steering wheel like yours!
princevick is offline   Reply With Quote
Old 18th June 2012, 23:28   #20
ktlocklear
ktlocklear's Avatar
Garage: 2007 M6; Black Sapphire
any pics yet with the new tire sizes?
2007 M6: Black Sapphire
Mods:
*Eibach Pro-Kit Lowering Springs
*Street Wheels- AG M310's 19x11/ 19x8.5; Powder Coated Jet Anthracite Matte
*Track Wheels- Apex ARC-8's 18x9.5 Squared; Anthracite Gloss with 275/35 R compounds
*Motul RBF 660 Race Brake Fluid
*Stop Tech Brake Pads
*RPI GT Exhaust ( Sections one, two, & three)
*RPI Scoops
*RPI Block Off Plates
*BMC Filters
*Charcoal Filter Delete
*Formula One Pinnacle Series Ceramic Tint; 15%
*Autotecknic Matte Black Kidney Grilles
*Matte Black Fender Grilles
*Stealth Front Turn Signal Bulbs
*Nokya Hyper Yellow H7 DRL's
ktlocklear is offline   Reply With Quote
Burn the clock by IND (full Atlantis Blue E92 M3 build) Nate@IND E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 52 27th May 2012 00:43
The 1M build starts Nate@IND BMW 1 Series M Coupé, X5M and X6M Forum 17 19th January 2012 19:55
Burn the clock by IND (full Atlantis Blue E92 M3 build) Nate@IND E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 22 15th September 2010 04:59
Burn the clock by IND (full Atlantis Blue E92 M3 build) Nate@IND E60 M5 and E61 M5 Touring Discussion 42 13th September 2010 16:33
The mod bug for the M3 starts (exhaust) TriflowM5+M3 E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 35 8th June 2003 08:14
