Radio/speaker issue - BMW M5 Forum and M6 Forums
Like Tree1Likes
Old 13th June 2012, 01:09   #1
Tymad
Garage: 2008 M6 Black
Radio/speaker issue
Was driving home listening to the radio. I heard a loud crackling/pop sound and the music stopped playing. Everything on the display screen is working properly (ex. Navigation, radio presets, climate settings), but no sound is coming from the speakers. I have checked all related fuses in the trunk and glove box, but no blown fuses. I also plugged in my iPod and it dispayed, but no sound. I was thinking it could be an amplifier issue, but not sure. Does anyone know where the amplifier is located and is there a fuse? Any thoughts?
Tymad is offline   Reply With Quote
Old 13th June 2012, 02:47   #2
stevelp99
Garage: 07 M6 coupe blk saphire on blk w/full merino & CF
Sounds like the amplifier to me.
The amplifier is located behind the left trim panel in the luggage compartment.
BMW TIS - 65 12 070 Removing and installing/replacing amplifier
Here is the fuse layout.
http://www.m5board.com/vbulletin/att...-lay-out_c.jpg
hifi amp:59,73,75,77,80
stevelp99 is offline   Reply With Quote
Old 13th June 2012, 21:15   #3
whatheheck
whatheheck's Avatar
Garage: 2009 M6 Convertible, black / tan
Sales Feedback: (4)
I agree with stevelp99l. Whenever you dont hear audio on the speakers I would start with the fuses, then check the amplifier.
It is also possible that your fiber optic audio connection got disconnected somewhere.
Since you have iPod interface - i would check the connection behind the iPod interface to ensure all connections are mated properly.
Dan
Evolve ECU Tune, Tubi Rumore exhaust, BBS RGR rims; Polk Audio Tweeters, 5500K Osram Cool Blue HID,Valentine 1 Radar Detector; Laser Interceptor Laser Jammer; All LED interior lights, LED footwell lights, LED trunk lights, Ultimate Cup Holders, 3rd brake light LED flasher, ash tray delete; LED license plate lights; RPI Ram Air Scoops + Block off plates; BMC Air Filters.......
whatheheck is online now   Reply With Quote
Old 14th June 2012, 01:45   #4
Tymad
Well i believe it is the amp but I actually found another problem. When I pulled off the rear panel in the truck everything behind it was wet. I forgot to mention it was raining when the radio cut out. It looks like the amp and whatever else is back there may have shorted out due to the moisture. I dropped it off at he stealer so I'll see what they come up with. Thanks for the help guys.
Old 14th June 2012, 14:41   #5
nonford
Garage: 2011 Lexus ISF
I had the same thing happen to me with my 5 series when they installed the tint. My speakers started clicking and humming and then nothing. I let it dry out and cleaned the fiber connector. Thought for sure I would need a new amp. Well, after about 3 hours it started working again and had no other issues. Reckon got lucky. And yea, its placed in a poor location......
nonford is offline   Reply With Quote
Old 16th June 2012, 15:45   #6
whatheheck
whatheheck's Avatar
Sales Feedback: (4)
Moisture or water in the trunk is a must fix ASAP issue.
The battery is there, relays are there, amp is there, lots of electronic stuff back there and as you all know - moisture or water and electronic stuff dont get along very well. And moisture starts corrosion.
I suggest you get that fixed ASAP.
Dan
Old 26th June 2012, 21:25   #7
RemaxRalph
Garage: "07 BMW M6 Vert-Stick "02 Porsche 911 Cab Artic Silver
I have the same issue. Any updates?
"07 BMW M6 Black Vert-Stick
"02 Porsche 911 Silver Cab-Stick
"02 PT Cruiser White Stick
"01 Crown Vic Police Interceptor Former Cleveland PD
RemaxRalph is offline   Reply With Quote
Old 27th June 2012, 01:27   #8
kgati
kgati's Avatar
Garage: 2010 M6 convertible - sapphire black
I had something similar in the past. I would get a loud static noise through the speakers for up to a minute then it would go away. Nothing ever stopped working. After multiple trips to the stealer they finally replaced my amp and all has been well. Here is a link to my post. Annoying Static
Ken
kgati is offline   Reply With Quote
The Following User Says Thank You to kgati For This Useful Post:
whatheheck (27th June 2012)
Old 25th August 2012, 11:31   #9
M_Power_Fanatic
Garage: F12 M6 and 135i Coupe
My issue is on a M6 2006. The sound from the speakers play for about 1hour then starts cutting on and off. Almost like the amp is overheating? Anyone here have instructions of removing the rear cover in a M6 to get to the amp?
M_Power_Fanatic is offline   Reply With Quote
Old 25th August 2012, 11:55   #10
M_Power_Fanatic
Nice article : BMW M6 (the dangers of scope creep) Part 1 - DIYMA Car Audio Forum
The Following User Says Thank You to M_Power_Fanatic For This Useful Post:
Clyde (25th August 2012)
Sirius Radio Car Charger Issue glrtrgi E39 M5 and E52 Z8 Discussion 6 31st January 2012 17:52
Issue With My Late 2000 E39 M5 Issue - Methods tried inside. 72433 E39 M5 and E52 Z8 Discussion 12 10th January 2011 22:47
Speaker wiring - need source for cabin speaker pjfox23 E39 M5 and E52 Z8 Discussion 0 22nd March 2010 00:58
CD issue and HD Radio ra0507 E60 M5 and E61 M5 Touring Discussion 0 31st December 2008 19:36
For those who have switched their radio, in order to get SIRIUS Sat. radio...... FAST 5 E39 M5 and E52 Z8 Discussion 48 21st April 2005 18:17
