Transmission Warning -> SMG Pump Replacement - BMW M5 Forum and M6 Forums
Like Tree5Likes
Old 30th May 2012, 22:13   #1
Impulse
Impulse's Avatar
Garage: '08 Alpine White M6
Posting this info mostly for historical reference if anyone else is looking thought posts.
Two weeks ago I had a blip of an error on start up that resulted in the car not starting and and red transmission error (reduced power) warning show up. Seconds later I restarted the car no problem no warnings. 2 times later that same day the car didn't start but then started the very next try (yellow light as if it wasn't in neutral but it was) on the second try is started. Since then it has been fine...
I just took the car in for the Recall battery fix today (no problems there), and told them about this issue so they could see if anything was up. I'm a bit surprised but the results are in they are going to replace the SMG pump... I drove the car between the two weeks on a long road trip no issues glad I didn't run into any problems. I'm only about 20 days away from my original warranty being up...
Impulse is offline   Reply With Quote
Old 31st May 2012, 01:11   #2
B767capt
B767capt's Avatar
Garage: 2008 M5 SMG
Make sure you replace the relay too.
B767capt is online now   Reply With Quote
Old 31st May 2012, 01:21   #3
CatsFan
CatsFan's Avatar
Garage: Black Sapphire 2008 M6 E63
Mine is in for the same problem, but I wasn't as lucky as you. I was driving down the road in D and P400 as I had a few calls to make and didn't want to have to shift gears while on the phone and the car was still cold. About a mile into my journey I came to a stop at a red light and the car went into neutral. The light turned green and I was unable to get the car to shift back into D. A few transmission errors popped up on the screen, but to be honest I wasn't paying much attention to them as it was rush hour and cars were flying by me on both sides.
After trying to start the car a few times I gave up and dialed 911 to get some assistance moving the car off the road as it was a danger to myself and fellow motorist. While I was doing this I kept trying to start the car, and luckily it came back after about five minutes. I was able to drive it about a quarter of a mile to a gas station. The car would not leave first gear and wouldn't go over 20MPH.
When I got to the gas station I shut the car down and called my SA. I tried for a few more minutes to start it and finally gave up and called a tow truck. Of course they didn't send a flat bed, even though I requested one and told them what kind of car it was, so I had to send the guy off and wait another thirty minutes.
The gentleman that came with the flatbed did an excellent job of loading and unloading my car. He used 2x6 planks to ensure that the bumper did not scrape, and he fastened each wheel to the truck. I of course let him know how much I appreciated his work and kindly tipped him $20.
I called my SA today and he said that it would most likely be ready to pick up tomorrow, Friday at the latest. It will be a week tomorrow, and to be honest I have never missed a car this bad. On the bright side it should feel like a new car again since I have only had it for a month, and of course the repairs were covered under my factory warranty that is intact until 2/2/13.
-David
2008 E63 M6 - Black Sapphire - Sepang Bronze Full Merino - Carbon Fiber Trim - Alcantera Headliner - SMG - HUD - Soft Close Doors - Comfort Access - Individual Audio w/Sat and HD Radio
2009 E92 335i - Black Sapphire - Black Dakota - Burl Walnut - Sport - Premium - Cold Weather - Navigation - L7 - Comfort Access - Smoker's Package
Member: BMWCCA #471614
CatsFan is online now   Reply With Quote
Old 31st May 2012, 03:18   #4
Impulse
Impulse's Avatar
Is it just me or is EVERYONE getting their SMG Pump replaced? I think the count is at 5 or 6 board members in the past 2 months. I only had 41k miles on my car, Dan's is a few thousand less. How about yours?
Old 31st May 2012, 03:25   #5
CatsFan
CatsFan's Avatar
Damn, I'm only a few hundred miles away from hitting 41,000!
Old 31st May 2012, 03:47   #6
GIFF
GIFF's Avatar
Garage: 2007 M6 Grey
29600 miles on mine and keeping my fingers crossed .....
Matt did they give you any insight as to the reason why they were willing to replace the SMG pump? I'm wondering if BMW is being somewhat lenient given the resent outbreak of failed pumps at such a young age.
~Gary
GIFF is offline   Reply With Quote
Old 31st May 2012, 04:01   #7
Impulse
Impulse's Avatar
I was in the middle of something when I took the call, now that you bring it up I'm not 100% on the part they are replacing. I remember it going "recall stuff fixed no problem ---looked into the error and was traced to the SMG Pump --- part on order will be here tomorrow --- keep the loaner car"
I sware it was the pump needing replacement but maybe I should check back either way SMG pump related and just in time for the warranty. Still not happy about the problem regardless but glad to get a fix on something that is know to ware over the lifetime
Old 31st May 2012, 04:07   #8
GIFF
GIFF's Avatar
No doubt, it's always nice to take advantage of the warranty while it's available.
Old 31st May 2012, 04:15   #9
kendall993
Garage: 2006 M5 Black
Dang Matt, Im knocking on wood right now. You are correct there seem to be a lot of SMG issues lately. Im out of warranty and dont want to come out of pocket that kind of money.
This is one reason Im considering buying a used Mini Cooper S for a daily driver. Itll save me gas and wear n tear on the beast.
Good luck on the repairs and Ill see you soon. Mines in the body shop now getting painted. You and Dan will have fresh SMG pumps, Gary will have new wheels and Ill have new paint. Sounds like a good run will be due in a few weeks!!!
kendall993 is offline   Reply With Quote
Old 31st May 2012, 06:55   #10
iroquis_pliskin
iroquis_pliskin's Avatar
Garage: M6 Sapphire Black
Matt,
I got mine replace at 56k miles (keep note that i did launch control quite often on my car)
I hope the dealer replace your whole transmission before you are out of warranty.
HRE 847R
LCI Taillight
Tubi Rumoré
Custom Painted Kidney Grill
Lumma Carbon Roof Spoiler
Vorsteiner Carbon Boot Lid
Vorsteiner Add- on Diffuser
Vorsteiner Aero Front Spoiler
Portland Brown Interior Conversion
BMC Air Filter+RPI Scoop+Block off Plates
iroquis_pliskin is offline   Reply With Quote
SMG Pump Replacement CabCreekM5 E60 M5 and E61 M5 Touring Discussion 4 9th May 2011 00:10
Increased emissions warning leads to vanos oil pump replacement!? phat E60 M5 and E61 M5 Touring Discussion 18 14th April 2008 07:08
SMG - Got the SMG Explosion of Warning Lights Today M52006Black E60 M5 and E61 M5 Touring Discussion 22 23rd September 2006 22:15
Transmission Warning bavarian E60 M5 and E61 M5 Touring Discussion 7 5th January 2006 20:55
transmission warning markf E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 2 29th October 2005 16:21
