M6 CIC retrofit fitting questions - BMW M5 Forum and M6 Forums
Old 19th February 2012, 21:28   #1
pyro225
Garage: E39 M5 No 3 | E63 M6 No ?
ok so ive got all of the kit now and the emulator etc.... couple of questions... how do you get the old iDrive controller out? and how do you get the trim infront of the cic unit off? dont worry ive worked out how to ge tthe screen out :P
pyro225 is online now   Reply With Quote
Old 19th February 2012, 22:13   #2
cegeste
cegeste's Avatar
Garage: X5M
Sales Feedback: (5)
Did you get a new console for the new iDrive controller, or are you going to cut the existing one?
cegeste is offline   Reply With Quote
Old 19th February 2012, 22:17   #3
zerocks1
zerocks1's Avatar
Garage: 2007 M6 Cab Sapphire Black
pyro225,
It's all right here. The post above explains it easily. Pop the hazard switch assay out with a trim removal tool. remove the single screw just behind it, then the rest of the panels are removed with the trim removal tool. They are pressed in with flat springs. the iDrive controller knob is removed by prying up
2010 CIC install in 2006 M5 Pictorial
zerocks1 is offline   Reply With Quote
Old 20th February 2012, 13:37   #4
pyro225
sorry dont mean the knob i mena the whole unit as i have the cic one? not going to cut was going to make a new surround for it as with no surround the cic controller is actually smaller than the early one however the surround is chunky so with make my own.....
Old 20th February 2012, 16:12   #5
cegeste
cegeste's Avatar
Garage: X5M
Sales Feedback: (5)
The bottom picture above details removing the controller. First button, then controller (secured underneath console)
I'd really suggest reading the thread Zerocks1 has posted in the multiple threads you've created on your CIC retrofit. Look at post 31 and then the M6 CIC thread post 13 Consoles and fit are different.
The Following User Says Thank You to cegeste For This Useful Post:
zerocks1 (20th February 2012)
Experience with bimmer retrofit CIC? keca10 E60 M5 and E61 M5 Touring Discussion 25 16th August 2012 20:29
Cic retrofit quick question pyro225 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 50 12th July 2012 22:29
!!!! First M6 with the CIC retrofit !!!! Patrys E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 14 7th June 2011 19:00
CIC Retrofit Part numbers mollet E60 M5 and E61 M5 Touring Discussion 3 6th May 2011 05:55
CIC retrofit with pre-LCI AC bruce_miranda E60 M5 and E61 M5 Touring Discussion 0 2nd February 2011 23:38
