M6 convertible battery replacement - BMW M5 Forum and M6 Forums
 14Likes
post #1 of 45 Old 28th December 2011, 07:34 PM Thread Starter
bernhtp
My 2007 M6 convertible is now off warranty/maintenance and the battery is going out. The BMW dealership wants to charge $410 for the part and (probably) an hour for install/charge.
The 5-year warranty Interstate battery for this costs $179 plus lower-priced installation ($20). BMW says that the battery needs to be registered with the computer - they will do it for $65 - but is this really necessary?
Any reason that's worth $250+ to get the BMW battery?
bernhtp is offline
post #2 of 45 Old 28th December 2011, 08:26 PM
Clyde
Clyde's Avatar
Your M6 most likely has an AGM battery, which will have a black case and no inspection "magic eye".
BMW NA uses replacement batteries manufactured by East Penn, part number 9AGM49.
Auto Barn is one of several online sources.
I would register, since it is likely that non-registering will reduce the life of a new battery. On the other hand, some dealers charge so much to register, it's cheaper to just replace more often
$65 is not unreasonable...
Clyde is offline
The Following 3 Users Say Thank You to Clyde For This Useful Post:
Hasan Shaikh (29th December 2011), MKSixer (11th January 2012), whatheheck (1st January 2012)
post #3 of 45 Old 28th December 2011, 09:04 PM Thread Starter
bernhtp
Clyde: Thanks. Is there a material advantage to the AGM over the Interstate? I can get the Interstate from my local mechanic.
bernhtp is offline
post #4 of 45 Old 28th December 2011, 09:51 PM
Clyde
Clyde's Avatar
AGM is a more advanced battery design, for more demanding applications. The charging requirements are different, but the car can be coded to support AGM or conventional battery types. It is easier to just keep using the same type.
If you do have an AGM battery, your mechanic should be able to get the East Penn battery (which is available under several brand names).
Clyde is offline
post #5 of 45 Old 30th December 2011, 04:14 AM
tampamark
That is a good price that Clyde found for you on the battery.
If there are some independent BMW repair shops in your area you might get it registered for less - it is reported to be as low as a $25 fee. Even if you buy a non-OEM battery you will want to register the new battery to the car. The BMW uses an Intelligent (I use that term loosely) charging system that adjusts the charge to match the battery as it degrades over time.
I do say, if it is so smart and can determine if your battery is getting weak and can adjust the charge, why can't it figure out the battery is stronger when you replace it??? Why, because they want to scam a register fee out of you.
I'm not bitter...
tampamark is offline
The Following User Says Thank You to tampamark For This Useful Post:
post #6 of 45 Old 30th December 2011, 08:38 PM Thread Starter
bernhtp
The independent BMW repair shop only did Interstate - not AGM - but also didn't recommend Interstate for the M6. They gave me the same price on the BMW battery and $110 to install/register the AGM if I got it.
I just ordered the AGM and will install it myself. I might get it registered with BMW for $65 unless I find a better alternative. I imagine that registration requires special computer-connect equipment that only exists at shops that explicitly handle BMW?
Thanks again.
bernhtp is offline
post #7 of 45 Old 30th December 2011, 10:32 PM
Clyde
Clyde's Avatar
...I imagine that registration requires special computer-connect equipment that only exists at shops that explicitly handle BMW?
Most likely you will need to go to a BMW specialist.
It is possible to register a new battery using a PC and interface cable:
DYI _Coding the E63-E64 *Updated 02-21-2011
Clyde is offline
post #8 of 45 Old 31st December 2011, 08:37 PM
gdalton
What exactly is `battery registration`? and is it really necassary? What happens if it isnt done?
I have replaced batteries on other cars simply fit and drive!!!!
Happy New Year all
gdalton is offline
post #9 of 45 Old 1st January 2012, 08:01 AM
Clyde
Clyde's Avatar
BMW has optimized charging to adjust as a battery ages, so a new battery is charged differently than a old battery.
How charging is "optimized" is not clear.
Battery registration informs the charging system that a new battery has been installed. The mileage of each battery registration is also stored.
Failing to register a new battery means it will be charged like an old battery. In theory this might reduce the life of the new battery, although there have been many posts about owners having no issues. Older M5/M6 models are now having their first battery replacement, so it is too soon to know if not registering will reduce the life of the replacement battery.
This post warns of possible issues:
Total battery % charge remaining
Clyde is offline
The Following User Says Thank You to Clyde For This Useful Post:
post #10 of 45 Old 1st January 2012, 06:13 PM
whatheheck
whatheheck's Avatar
As always, thanks for the great info Clyde.
My beast is a 2006, and it only has 28,000 miles.
My experience with BMW batteries through the years is they are only good for about 6 years max.
One thing I hate is getting stuck somewhere as the car wont start.
Do you think I should go ahead and replace my battery before it fails since my battery is now reaching 6 years of age?
Dan
Evolve ECU Tune, Tubi Rumore exhaust, BBS RGR rims; Polk Audio Tweeters, 5500K Osram Cool Blue HID,Valentine 1 Radar Detector; Laser Interceptor Laser Jammer; All LED interior lights, LED footwell lights, LED trunk lights, Ultimate Cup Holders, 3rd brake light LED flasher, ash tray delete; LED license plate lights; RPI Ram Air Scoops + Block off plates; BMC Air Filters.......
whatheheck is offline
The Following User Says Thank You to whatheheck For This Useful Post:
MOTRSPRT (26th March 2015)
battery replacement? MOOK03TRMN8R E60 M5 and E61 M5 Touring Discussion 31 6th December 2013 06:42 AM
Replacement Battery WOO E34 M5 Discussion 15 21st July 2013 12:15 PM
Best replacement battery? tomssvx E39 M5 and E52 Z8 Discussion 6 26th January 2011 12:26 PM
'03 M3 Cab Battery Replacement? 2mnycars E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 3 1st September 2009 04:25 AM
Battery Replacement Question bimmernut1 E39 M5 and E52 Z8 Discussion 15 21st January 2008 08:41 PM
