Evolve AlphaN (no MAFS) Tune now available - Page 2 - BMW M5 Forum and M6 Forums
 5Likes
post #11 of 34 Old 13th December 2011, 10:39 PM
tmiked
I dont understand the purpose of an Alpha-N if the MAF's are not removed.
The whole point is to eliminate that restriction.
As far as 'smoothness', etc, that would reflect the skill of tuning, with or without a MAF.
For instance, if you are going to leave the MAF in, why not use it to optimize part-throttle cruise, if nothing else.
tmiked is offline
post #12 of 34 Old 13th December 2011, 11:03 PM
rocket5979
rocket5979's Avatar
Agreed.
-Robert-
2003 4.6 XLT Black Explorer,Built, blown, ported, cammed, and on and on...
2009 Pontiac G8 GT Stryker Blue, 402ci Stroker, Twin Turbo's, 230/240 Turbocam, Circle D Built 6L80E, Circle D 3000 Stall, and a few other things...
rocket5979 is offline
post #13 of 34 Old 15th December 2011, 10:10 PM Thread Starter
evolve automotive
evolve automotive's Avatar
If you think MAF's are a restriction themselves then you are mistaken.
You really need to feel an AlphaN tune to realise the difference.
The same theories and questions came up on the E39 section. So many have converted.
There is no amount of skill you can apply to create the same smoothness with MAF's.
evolve automotive is offline
post #14 of 34 Old 16th December 2011, 04:15 AM
rocket5979
rocket5979's Avatar
I do not know how much of a restriction the MAFS are in the M6's but I do know that in other non-BMW vehicles some decent gains were had with physically removing them from the intake tract. Since the M6 slot-style MAFS are roughly similar shape and size in the intake tract, and the engine requires proportionally more airflow then the others that gained I would figure that something would be gained with the M6 as well, especially considering there are not just one MAFS but two. Will the gain be large? Probably not. But when people fight tooth and nail to even gain 75rwhp from bolt-ons installed in their M6 then 3-5rwhp here and there can add up.
I am an custom ECM tuner so I tend to understand a bit more than the average guy when it comes to the jargon. Every other vehicle I have tuned, the AFR's both at part throttle and at WOT were always more smooth and accurate when the MAFS has been properly recalibrated through the transfer table than any other way such as a speed density mode using MAP or just forcing the vehicle into closed loop all the time. I am not trying to be a naysayer, since I have never tuned an M6 I do not know all of its ins and out's yet. But I would like to better understand the benefits of what you are talking about without you feeling I am asking you to disclose enough information that would be considered intellectual property. So exactly what is allowing it to be more "smooth" because simply stating that it is smoother doesn't really tell anyone much. Is it a WOT AFR thing, PT AFR, Spark advance, transmission shift related or what? When a sensor as important to engine function as the MAFS is removed from the equation I want to know exactly why. I don't mean to come across as challenging or rude, but inquiring minds would prefer more of an explanation than it is smoother and go talk to the E39 guys before dropping their hard earned dollars on this mod.
-Robert-
post #15 of 34 Old 16th December 2011, 07:47 AM
Deadgame
Deadgame's Avatar
I sent Paul an email a few days ago concerning upgrading my current Evolve-R stage 2 tune and haven't got a response. Can a brother get some help?
2008 E63 Black Sapphire, Carbon Interior, SMG, RPi GT Exhaust, RPi Ram Air Kit, Evolve-R Stage 2 ECU Tune, H&R Springs, Auto Technik Carbon Kidney Grills, Dry Carbon License Plate Holder, 20" ADV.1 5.01 Satin Black Monoblocks, Blinder X-Treme M27 Laser Jammers, DDM Tuning HID Angel Eyes, Auto Technik Carbon Steering Wheel Trim, Blk/Slvr Carbon Front/Rear Roundels, Painted Front & Rear Calipers, Euro Tuned SMG, Opti-Coat 2.0 paint sealant.
Deadgame is offline
post #16 of 34 Old 16th December 2011, 10:10 AM
Ahmed
Ahmed's Avatar
I believe the MAF's are a restriction, not physically.. but electronically. I also believe when you by-pass the MAF's, you are more connected to your car and the beast feels more raw than electronic.
2013 C63 AMG P31
2009 Lexus GS460
2004 Acura NSX-T
1994 Ferrari 348 Spider
1993 Dodge Viper RT/10 Roadster
1980 Porsche Turbo 3.3
Ahmed is offline
post #17 of 34 Old 18th December 2011, 12:51 PM Thread Starter
evolve automotive
post #18 of 34 Old 18th December 2011, 01:38 PM Thread Starter
evolve automotive
I will test the restriction for everyone by doing a thorough dyno test with the MAF's in and without by replacing the MAF with a blanking plate/bung.
Will try and measure the pressure drop accross that area with the MAF's removed also.
The cars we are converting to AlphaN already have stage 1 tunes one them so we are not touching the ignition maps between the two versions.
The smoothness does not come from AFR changes. Part load we are always at 1 lambda. Same as with MAF's. The system is in closed loop with or without the MAF's.
Fuel is all target based on the MSS85.
So where does the smoothness come from??
HFM Technology does not measures air mass directly. It is done with the additional input sensors such as barometric and intake air temperature sensors. The output signal is literally just that. An electrical signal. This is used to then calculate a 'load' which is used in variables tables such as fuel.
VANOS and ignition are usually independant of the HFM load calculation.
SO the HFM is really all about trying to make the fuelling as close to maximal efficiency as possible.
However, the setup relies on laminar (smooth) flow through the MAF housing tube so a far more accurate signal may be generated. While in theory on a bench laminar flow may exist, when installed at the beginning of the plenum with pulses being generated through it laminar flow can become turbulent flow at certain loads and engine speeds. Once you get any type of turbulent flow over the HFM the signal becomes distorted.
By removing the HFM altogether (but keeping the IAT sensor) this turbulence is removed leading to improved smoothness.
So now the question comes.... without the HFM we might run into lean or rich conditions under partial load especially.
Well, not really no. First of all we have the closed loop wide band lambda control with the DME being target based.
Then, the fuel maps are very very well developed by BMW and there is also programmed in the throttle position memory of what assumed air mass or load is at any given throttle position. We have barometric and intake temperature correction (so atmospheric) still active.
Now, we are not going to dismiss the MAF completely. They are very useful but really in conditions where for example the air filter becomes extremely blocked or restrcitive and the oil becomes very old and contaminated. Really conditions which the enthusiast is never going to allow. Under these conditions the MAF allows enough correction of fuel injection to get the system to an acceptable emissions level or target.
On the downside the MAF can very easily become contaminated especially when being used with any type of oiled performance (so called) air filter.
Where does this then leave your MAF's as part of an accurate system to control fuel?
What you will tend to find is that if an excellent calibration for fuel is made on AlphaN setup even on cars like the old E30 325i M20 and you just use barometric and intake temperatures for correction, keep the filters and oil clear and don't even use a closed loop lambda system, these cars will run incredibly well and pass tail pipe emissions tests.
So, really, on something as sophisticated as the MSS85 with so much more control and development the MAFs can be taken out of the equation and you have a fantastic running car.
E46 M3, E39 M5's are running evolve AlphaN all over the world with excellent independant feedback and passing emissions at the same time.
The same will happen with the S85.
The assumption here is that owners will avoid any kind of rich running and excellent emissions by keeping clean (ish) air filters and oil.
post #19 of 34 Old 18th December 2011, 02:25 PM Thread Starter
evolve automotive
post #20 of 34 Old 18th December 2011, 03:50 PM
Ahmed
Ahmed's Avatar
Sal, I knew it! I thought you were on holiday.. but you just can't can you? LOL
2013 C63 AMG P31
2009 Lexus GS460
2004 Acura NSX-T
Ahmed is offline
Evolve AlphaN Impression w/ pics JL21ah E39 M5 and E52 Z8 Discussion 63 29th February 2012 08:55 PM
Evolve AlphaN (no MAFS) Tune now available evolve automotive E60 M5 and E61 M5 Touring Discussion 32 28th February 2012 11:42 PM
Evolve AlphaN review m5rosemont83 E39 M5 and E52 Z8 Discussion 19 17th September 2011 08:54 PM
Group buy on Evolve's AlphaN and Power tune BenTong Australian Forum 0 25th November 2010 03:18 AM
My day at the dyno: Evolve AlphaN bono E39 M5 and E52 Z8 Discussion 13 20th July 2010 03:04 PM
