DIY: Maintenance - BMW M5 Forum and M6 Forums
Like Tree2Likes
  • 1 Post By ktlocklear
  • 1 Post By Clyde
Old 20th September 2011, 13:52   #1
Zel
Zel's Avatar
Garage: 07 M6 Convertible, Black
Maintenance
Hey guys, with help from this forum, I changed my oil last night. It went about as smooth as could be expected for the first time on this car and working on ramps. Whenever I buy a used car, one of the first things I do is change the oil. I feel better knowing that its been done. The filter I removed was not an OEM filter and was stamped "Made in South Korea" and had the date "2-19-11" also stamped on it, so I'm assuming the oil has been changed sometime since 2-19-11. That being said, the oil seemed extremely dark and loaded with carbon. Wondering if this is normal for these cars? If it is a sign of the wrong weight having been used? Or did someone only change the filter and not the oil?
Also, regarding other maintenance, I have 2 cabin filters on order and am weighing options for air filter replacements. The iDrive is saying that our brake fluid flush service is overdue. Is this as simple as bleeding the brakes and adding new fluid until the new fluid comes out of each bleeder? Also, is all Dot 4 brake fluid good enough or should I buy that from the dealer? I did a search here and found very little info about flushing the brake fluid.
One other thing, I noticed this plactic piece hanging down under the car. It was in the center of the car, at about the rear of the engine and it was riveted to the bottom of the undercarriage liner. It had been mostly broken off but there was one small part left just hanging there by 1 rivet. I removed it completely because I didnt like the look of it hanging down. Any idea what this was, what its function was and if its necessary? Should I replace it?
Thanks guys. I love this forum and am addicted to reading it! I learn something new every time!
Our fleet:
07 M6 Convertible - Black/black/carbon fiber, MTEC V3.0 and DAEOS, Vorsteiner diffuser, front lip, wing. QTP remote cutouts. LED's here & there.
13 Dodge Durango (for work and to tow the boat/ski)
07 Dodge Nitro - for sale soon! Over-maintained, safe and reliable!
07 Mercedes C230 Sport, AMG upgrades - Wife's
55 Chevy 150 (project car)
08 Yamaha 212SS Jet Boat
01 Yamaha GP1200R Waverunner-recently reconditioned, possibly for sale...
Sold:
88 Ford Mustang GT Convertible
07 Infiniti G35 Sport Coupe
88 Ford Mustang GT Hatchback
Zel is online now   Reply With Quote
Old 20th September 2011, 18:43   #2
ktlocklear
ktlocklear's Avatar
Garage: 2007 M6; Black Sapphire
A lot of us use ATE Super Blue brake fluid. Flushing the brake fluid is the same as other cars.....pretty simple and straight forward.
That broken piece sounds like the center lift pad that is used to jack up the front of the car with a floor jack. If so, replacements are avail.
2007 M6: Black Sapphire
Mods:
*Eibach Pro-Kit Lowering Springs
*Street Wheels- AG M310's 19x11/ 19x8.5; Powder Coated Jet Anthracite Matte
*Track Wheels- Apex ARC-8's 18x9.5 Squared; Anthracite Gloss with 275/35 R compounds
*Motul RBF 660 Race Brake Fluid
*Stop Tech Brake Pads
*RPI GT Exhaust ( Sections one, two, & three)
*RPI Scoops
*RPI Block Off Plates
*BMC Filters
*Charcoal Filter Delete
*Formula One Pinnacle Series Ceramic Tint; 15%
*Autotecknic Matte Black Kidney Grilles
*Matte Black Fender Grilles
*Stealth Front Turn Signal Bulbs
*Nokya Hyper Yellow H7 DRL's
ktlocklear is offline   Reply With Quote
Old 20th September 2011, 19:19   #3
Clyde
Clyde's Avatar
Garage: Sepang Bronze M6 Coupe
I like ATE Type 200 Amber Brake Fluid
The same specs as Super Blue, but does not stain everything...
Clyde is online now   Reply With Quote
Old 20th September 2011, 19:28   #4
ktlocklear
ktlocklear's Avatar
What get's stained besides maybe the resivor?
I plan to use the amber at my next flush to make it easier to see when all of the blue is out at each caliper....then flip flop between colors with each flush
Old 20th September 2011, 22:20   #5
Clyde
Clyde's Avatar
I'm just messy, so the blue stuff gets on the garage floor and my hands
Old 21st September 2011, 00:25   #6
Zel
Zel's Avatar
Thanks for the replies. Is 1L enough to do 1 full flush on the system? As I understand it, you cannot safely store brake fluid, once the can seal has been broken. It will absorb moisture from the air.
Old 22nd September 2011, 13:42   #7
Zel
Zel's Avatar
I ordered up a liter. Couldnt locate any locally.
Old 22nd September 2011, 16:37   #8
ktlocklear
ktlocklear's Avatar
1 liter is enough to do a flush and fill. I had some left over when I did mine
Old 22nd September 2011, 23:08   #9
Zel
Zel's Avatar
Thanks Kt. That will be the last overdue maintenance item my beast needs. Assuming it hasnt been done and not reset. My oil change notification said it was 2700 overdue. When I removed the aftermarket oil filter, it had "Made in South Korea 2-17-2011" stamped on it. I'm fairly sure someone changed the oil since February and didnt know how to reset the notification. I guess its possible they did the same with the brake fluid. I'll have to look and see how dirty it is.
Old 23rd September 2011, 16:14   #10
vraa
vraa's Avatar
Garage: M6 Stratus Gray
I thought the notification didn't have to be reset, BMW used some sort of viscosity or resistance sensor to determine oil wear?
07 LX470 08 IS-Fx2 08 LS600 04 360 Spyder 07 M6
vraa is offline   Reply With Quote
Maintenance get together (UK) captain_anonymous_2003 E39 M5 and E52 Z8 Discussion 117 31st August 2011 13:20
New M5 @ 70K... what maintenance should I do? NousDefions E39 M5 and E52 Z8 Discussion 23 18th February 2011 21:50
M5 maintenance ashleyschaeffer E39 M5 and E52 Z8 Discussion 34 27th October 2009 08:43
Even more maintenance FinalEditionE34M5 E34 M5 Discussion 17 24th October 2006 18:02
More Maintenance FinalEditionE34M5 E34 M5 Discussion 33 15th September 2006 21:38
