RIP Vanos - BMW M5 Forum and M6 Forums
Like Tree1Likes
  • 1 Post By csepipeti
Old 6th July 2011, 09:46   #1
csepipeti
csepipeti's Avatar
Garage: 2005 BMW M6
RIP Vanos
I had my car at the service station for about 3 weeks with some damage caused by a too high ramp, also had a hard time dealing with the insurance company.
Anyways, yesterday I got her back, and after warming up, i went to a test-drive. It did not last long, as i got engine check error, and reduced power
Took it back to the service station, and the computer says vanos problem. After resetting the error, and starting up the engine, it runs for a few minutes, and then engine check error, reduced power, vanos error again. So it seems like its dead finally.
I was seriously thinking about getting rid of the car, as it is mostly pain in the *** in the past year, but now i cant even make it work for a week to be able to sell it. Maybe i'll just set it on fire...
Do you guys have an estimate about this vanos repair cost? I know its gonna hurt bad...
csepipeti is offline   Reply With Quote
Old 6th July 2011, 10:23   #2
Mark Carson
Mark Carson's Avatar
Garage: Cold beer
That sucks. The early (and I see what you have a 2005) M5 and M6 cars had VANOS issues. Which should have been repaired under warranty back when you car was still in warranty. Do you have the service records? If everything is original, maybe BMW will help you even though you are probably out of warranty. However the VANOS problems were a manufacturing defect, not a "broken part" from normal wear and tear.
Good luck. Sorry to hear that your beast has had so many problems.
Cheers
2011 Z4 3.0
2011 528i
2010 M6 Individual Coupe http://www.m5board.com/vbulletin/e63...vidual-m6.html
Mark Carson is offline   Reply With Quote
Old 6th July 2011, 11:20   #3
csepipeti
csepipeti's Avatar
Garage: 2005 BMW M6
Well, unfortunatelly, the previous owner did not take the car to the official dealer, so this reduces the chance that BMW will help even if i have the full service history, but i might give it a shot, thanks!
Old 6th July 2011, 18:50   #4
q8kamikaze
q8kamikaze's Avatar
Garage: 07 BMW M6 onyx blue metallic
Sorry to hear the bad news , I think the $tealer will change the Vanos cause it's can't be fixed , Keep us posted my friend .
Good luck .
Kamikaze
///M6 onyx blue metallic ( SOLD )
RPi scoops + block off plates + BMC air filters
Evosport under drive pully
Tubi exhaust ( Rumore ) + Tubi X pipe
H&R sport springs + H&R wheels spacers , 10mm front / 12mm rear
WeissLicht Ultra bright Angel eyes V2
CA Automotive custom remapping
Vorsteiner CF boot lid
CF front grill
CF mirror covers
6000K Ultra bright LED license plate lights
LED interior lights
2008 Cadillac Escalade ( DD )
2001 Porsche 996TT ( sold )
2003 Ferrari 360 spider F1 ( sold )
2004 BMW E46 318i ( for fun )
q8kamikaze is offline   Reply With Quote
Old 27th February 2012, 09:42   #5
csepipeti
csepipeti's Avatar
Garage: 2005 BMW M6
It's been a long time ago... But finally the beast is working fine again. The story would be too long and boring to tell, but the car was at 2 different dealerships, including BMW Hungary, and none of them found what the real problem was. I've spent a lot of money and time (and it was winter in the meantime), but finally i've found a guy, who is a real BMW guru, and he was able to fix the car in 4 days. The culprit was a flexible oil pipe, belonging to VANOS. Just telling it, so that if anyone of you experience VANOS problems, it is mostly caused by this pipe, and the leak not visible from the outside of the car, as the oil goes back to the oil tray, but there is no oil pressure for vanos units.
Damn, i almost got rid of the car, was so devastated that noone was able to fix it...
Now i feel like i have a new car!
Old 27th February 2012, 10:22   #6
ritchy-69
ritchy-69's Avatar
Garage: E63 M6 Sepang Bonze
For your information:
With the previous owner of my 2005 M6 the "Vanos High pressure hose" was replaced under warrenty within the first 8000 KM.
(I could not find out if this was a "recall".......)
Maybe this information is helpful to you??
ritchy-69 is offline   Reply With Quote
Old 27th February 2012, 10:35   #7
csepipeti
csepipeti's Avatar
Garage: 2005 BMW M6
Thanks, but i'm not under warranty, but this hose was the culprit. It's been replaced, and the car seems to be ok now.
Old 27th February 2012, 10:39   #8
ur20v
ur20v's Avatar
Garage: e60 M5 (June 05 Build) Black on Black
The VANOS high pressure line was a recall if a fault showed only. I would get on to BMW and ask for assistance, the dealers should have known to check this part for the very reasons it failed, this are known to BMW. Charging you lots of diagnostic labour for this clear issue isn't on. The bulletin is on here:
VANOS Oil Line Replacement Service Bulletin
Jay
ur20v is offline   Reply With Quote
warning light,vanos oil pressure/vanos sensor dejanstepan E60 M5 and E61 M5 Touring Discussion 62 26th April 2013 02:12
HELP! Vanos replacement advice needed, is my vanos capoot?! M5aud E60 M5 and E61 M5 Touring Discussion 100 13th July 2010 12:18
Help with VANOS issue- mechanic convinced me to replace vanos and now code is back MPOWDER E39 M5 and E52 Z8 Discussion 10 27th January 2010 21:23
Vanos Solenoid vs Complete Vanos Replacement SoCaLE39 E39 M5 and E52 Z8 Discussion 5 4th June 2008 21:42
Problems w/Vanos system (After Vanos lise replaced) patq E60 M5 and E61 M5 Touring Discussion 10 23rd March 2006 08:42
