DYI _Coding the E63-E64 *Updated 02-21-2011 - Page 8 - BMW M5 Forum and M6 Forums
Like Tree184Likes
LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 27th February 2011, 14:33   #71
NCM6Cabrio
NCM6Cabrio's Avatar
Garage: 07 Black M6 Cabrio
...Changing the KALTUEBERWACHUNG (Cold Monitoring) from aktiv to nicht_aktiv, tells the module NOT to cold check the bulb. So, no more resistors when you add LED's. I deactivated the Cold Testing of the side directional lighting, and since that was the only LED I did not use a resistor with, it does not blink for the first few seconds as it used to. I left the WARMUERBERWACHUNG setting as aktiv, to alert me if it actually burns out. I'm using the largest Amber LED I could find that physically fit in the housing. It's a 9 LED amber....
Does this also mean that if we install LED turn signals we won't need the resistor pack either? If so that is awesome- and a huge $$ savings! Thanks again for all the effort you've put into this!
2007 M6 Convertible- Black Sapphire Metallic, Indianapolis Red Full Merino Leather, Comfort Access, CF trim, HUD, Sirius Radio, 3M Clear Bra, Hamann Rear Spoiler, 35% 3M tint, //M pedals, LED interior lighting, RED RPI Scoops, BMC Filters & block off plates, Charcoal filter delete, 3rd brake flasher, CF steering wheel trim & E-brake handle, EFX Red Angel Eyes, Rouge Engineering Spacers, RPI Full GT Exhaust, Alcantara SMG & E-brake boots, Active Autowerke Tune, H&R Sport Springs, CIC & Combox Retrofit
NCM6Cabrio is offline   Reply With Quote
Old 27th February 2011, 15:30   #72
whatheheck
whatheheck's Avatar
Garage: 2009 M6 Convertible, black / tan
Sales Feedback: (4)
Yes, that would be really really nice if we would no longer need to add load resistors whenever we convert any exterior lights to LED's.
I hate load resistors as they consume a lot of battery power, they get really hot and they are big and bulky.
And expensive!
Looks like the side marker lights recode for disabling bulb check is done. Great work!
Its only a matter of time before Zerocks1 will figure out the recode for the front and rear turn signals.
Continued Thanks to Alan!
Dan
Evolve ECU Tune, Tubi Rumore exhaust, BBS RGR rims; Polk Audio Tweeters, 5500K Osram Cool Blue HID,Valentine 1 Radar Detector; Laser Interceptor Laser Jammer; All LED interior lights, LED footwell lights, LED trunk lights, Ultimate Cup Holders, 3rd brake light LED flasher, ash tray delete; LED license plate lights; RPI Ram Air Scoops + Block off plates; BMC Air Filters.......
whatheheck is offline   Reply With Quote
Old 27th February 2011, 18:57   #73
zerocks1
zerocks1's Avatar
Garage: 2007 M6 Cab Sapphire Black
The LMA module (Lighting Module), has the option to disable both cold and hot monitoring of all bulbs it seems. So logically no more resistors, to answer the previous questions. I have my front LCI LED resistors behind the front bumper (which I am not about to take off yet again to remove resistors), and the 'Sean adapters' on my rear LCI LED turns. The worst case is, you disable the cold monitoring on the front and/or rear turns, and if a bulb out error appears (without using resistors of course), you disable the hot monitoring. That should guarantee no bulb out message, but of course you have to check the lighting periodically like in the old days, to make sure the bulbs are still lighting.
Here is an extract of the lines of code in the LMA module for all the turn signals.
Definitions:
KALTERUEBERWACHUNG = Cold Monitoring
BLK = Blinkers (turn signals)
V = Front
H= Rear
BLK V 2 = Front
L = Left
R = Right
A few lines of code from the LMA module before modification:
KALTUEBERWACHUNG_BLK_V_L (side turns)
aktiv (change to nicht_aktiv)
KALTUEBERWACHUNG_BLK_V_R (side turns)
KALTUEBERWACHUNG_BLK_H_L (rear turns)
aktiv
KALTUEBERWACHUNG_BLK_H_R (rear turns)
aktiv
KALTUEBERWACHUNG_BLK_2_VL (front turns)
aktiv
KALTUEBERWACHUNG_BLK_2_VR (front turns)
aktiv
If you look closely at the Word.doc in post #70, you can see all the bulb options. I am putting a cheat sheet of the abbreviations together. I'm trying not to overwhelm with information until your cables arrive, then I can provide shortcuts and tips
I noticed an option for bulb BFD and the word flash. I think we can change the option of our brake lights to flash regardless of brake pedal pressure and/or car speed to stop.
Here's a short reference
SL = Parking Lights
AL = Low Beams/Cornering Lights
BL = Brake Light
BLK = Turn Signals
FL = High Beams
KZL = Lic. Plate Lamps
NSW = Rear Fog lamps (assuming you've enabled them; previous DYI)
RL = Reverse Lights
BFD = Brake Force Display
AL = DRL's
There is an option, (and I've read about success doing this); that you can program Welcome Lights, so when you unlock the vehicle any lights you wish will come on.
I'm trying to figure out the settings 'Wert 1,2.3.4'. Wert is 'setting", but I'm not sure what each number change does in each line of code...yet. There's also levels of various lighting; low, medium, high; timing of lights off; hibernation time; etc.
There's a program floating around called NCS Dummy ver 4.xx beta. The writer has all the options that are able to be set if you browse for the module file you have previously read. No car connection is required for this; and some translations are next to a modules file. It doesn't have the E60-63-64, and only shows translations we already know. aktiv = active, and nicht_aktiv = not active.
The one tip that I will recommend again and again. When you get the SW and the cable working,
- The first action is to read all the module and save them with different names so you have a backup of the settings as they are of that moment. It's also a good way to practice before you actually write anything to the car.
- I saved each of mine in the NCS Work>Backup folder with names like FSW_PSW original CAPPL module.TRC. If you need it, you rename it as FSW_PSW.TRC and move it to the work folder for writing. Only one FSW_PSW.TRC file can be in the work folder at any time.
There's two tips
zerocks1 is online now   Reply With Quote
The Following 5 Users Say Thank You to zerocks1 For This Useful Post:
Bavarian Beast (27th February 2011), clintmoore (2nd March 2011), Clyde (27th February 2011), MKSixer (27th February 2011), NCM6Cabrio (27th February 2011)
Old 28th February 2011, 00:47   #74
whatheheck
whatheheck's Avatar
Sales Feedback: (4)
Awesome. Thanks Alan!
Old 1st March 2011, 01:39   #75
Michael A
Garage: E63 M6, Silver
Please add me to the group buy. I just came across these threads about this coding breakthrough. Good stuff.
Michael
Michael A is offline   Reply With Quote
Old 1st March 2011, 04:42   #76
whatheheck
whatheheck's Avatar
Sales Feedback: (4)
Please copy the running list on post number 69 and add your name as number 15.
I have sent a follow up eMail to the seller this morning asking for pricing and detailed info on how to place our orders.
No reply yet.
Michael
Old 1st March 2011, 19:38   #77
Michael A
Please count me. Here is the list with me added as #15
1) MKsixerffice
2) NCM6Cabrio
3) Audioguy
4) Whatheheck
5) Sherid1
6) Randy'sV10
7) Jlf74100k
8) dave_t
9) golf_hero
10) itso_001
11) sattman
12)eddiejb
13)aorange (Blocks my name...my apologies)
14)jamiethole
15)Michael A
The Following User Says Thank You to Michael A For This Useful Post:
whatheheck (1st March 2011)
Old 2nd March 2011, 05:10   #78
FogPuppy
Garage: 2010 M6 Carbon Black
Add me
1) MKsixerffice
2) NCM6Cabrio
3) Audioguy
4) Whatheheck
5) Sherid1
6) Randy'sV10
7) Jlf74100k
8) dave_t
9) golf_hero
10) itso_001
11) sattman
12)eddiejb
14)jamiethole
15)Michael A
16) fogpuppy
FogPuppy is offline   Reply With Quote
The Following User Says Thank You to FogPuppy For This Useful Post:
whatheheck (2nd March 2011)
Old 2nd March 2011, 13:28   #79
clintmoore
Garage: 2007 BMW 650i
Add me please.
1) MKsixerffice
2) NCM6Cabrio
3) Audioguy
4) Whatheheck
5) Sherid1
6) Randy'sV10
7) Jlf74100k
8) dave_t
9) golf_hero
10) itso_001
11) sattman
12)eddiejb
14)jamiethole
15)Michael A
16) fogpuppy
17) clintmoore
clintmoore is offline   Reply With Quote
Old 2nd March 2011, 14:01   #80
clintmoore
zerocks1 - Allen,
Thank you very much for all of your hard work. I'm very much a DYI type person. I don't have an amazing M6, but would like to know if the interface itself is good for working with a 650i. I was also curious if it is possible to use the interface cable and other software for other types of coding for the car. For example. I am currently having the Crankcase sensor replaced in my car. The part is only $80.00 yet the "coding" of the sensor to the car costs a significant amount, Price quoted was around 700+ to replace the sensor. The physical labor is not significant, but the code was. Would I be able to use this cable and possibly some other software to do that coding on my own? I am a computer geek, I'm quite familiar with software development, java, c++, hardware systems, automation for industrial facilities, so it is up my alley, I’m no professional hacker though, grin. I'm new to the BMW 6 series though. My last BMW was a 525 E34. I would like to explore of the programmability of the I-Drive and the features as well. Thank you again for everything on this post. This is a huge jump start for me. I saw the post and thought. WOW SCORE!!!fficeffice" />
Clint
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
Coding our own E63-E64 Success_Finally! zerocks1 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 37 25th April 2011 10:56
How long will you keep your M6 (E63/E64)? Mark Carson E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 22 20th August 2010 18:01
The last E63/E64 - own a piece of history Mark Carson E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 5 12th March 2010 17:43
E63 and E64 Exhaust the same? Serious6 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 17 22nd April 2009 20:53
Euro Headlights for M6 and other E63/E64 TheGermanOne Parts / Other For Sale or Wanted 0 30th July 2007 13:52
