DYI _Coding the E63-E64 *Updated 02-21-2011 - Page 46 - BMW M5 Forum and M6 Forums
Like Tree180Likes
LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 17th July 2011, 11:44   #451
mimi74
mimi74's Avatar
Garage: BMW M6 Saphire Schwartz
I'm going to look to the PDC module and see if I could active automatic front PDC under a speed of... 8km/h
mimi74 is offline   Reply With Quote
The Following User Says Thank You to mimi74 For This Useful Post:
menacez (17th July 2011)
Old 17th July 2011, 13:40   #452
menacez
Garage: E63
Hi Mimi,
Great idea!!! I do find it annoying that you have to enable it when you park/drive straight in. The only challenge I see with this is if you're stuck in traffic and the thing beeping away - I assume the manual disable would still work but how frequent would it trigger - any timeout etc etc.
Great suggestion though - not sure if there's anything in the Nettodat
Menacez
menacez is offline   Reply With Quote
Old 17th July 2011, 13:48   #453
menacez
Garage: E63
I've got a good working NCS Expert for my 2008 635d and I have my mate coming around in a few hours who wants me to code his 335d also a 2008 model.
Do I need to bear anything in mind apart from the module naming convention that may be slightly different?
Is there a diff profile I need to load up for the 335d - i.e. Would 'Revtor's NCS Expert Profile' work?
Appreciate any pointers.
Menacez
Old 17th July 2011, 14:13   #454
zerocks1
zerocks1's Avatar
Garage: 2007 M6 Cab Sapphire Black
I'm not sure if the profile will work. I had trouble early on with other model profiles for the E63-4. Try it youll know pretty early on You will likely need newer daten files however. Each post I have made, including the links throughput this thread only contain newer E6x daten files. You may have to get an extract of daten versions newer than what came with NCSExpert from this original post for the 3 series Other than that, the procedure should be the same.
zerocks1 is offline   Reply With Quote
The Following User Says Thank You to zerocks1 For This Useful Post:
Old 18th July 2011, 00:10   #455
Mark Carson
Mark Carson's Avatar
Garage: Cold beer
I have posted a number of .TRC files from my 2010 M6 here: BMW E63 M6 .TRC Files (17-JUL-2011)
The password is my license plate. If you don't know what it is, search the Board or send me a PM. I won't post it here.
Some of these files have been modified, so they are not all stock.
There are no files for the following (which I suspect don't exist on a 2010 car): 2MULF, CID, TCUM, ZBE2
I will remove these after a while, but for now, go get 'em if you need them.
2011 Z4 3.0
2011 528i
2010 M6 Individual Coupe http://www.m5board.com/vbulletin/e63...vidual-m6.html
Mark Carson is offline   Reply With Quote
The Following User Says Thank You to Mark Carson For This Useful Post:
zerocks1 (18th July 2011)
Old 18th July 2011, 04:28   #456
zerocks1
zerocks1's Avatar
Thanks Mark, these might help figure this 6NR thing out, (iPhone BMW Connected Apps, Facebook, Twitter, etc) for our models.
Appreciate it!
Old 18th July 2011, 08:11   #457
mimi74
mimi74's Avatar
Correct me if I'm wrong, but there's no 6NR on E6x and same for the very last product... Think you have to look to F10 or last E9x files for that
Old 18th July 2011, 14:30   #458
zerocks1
zerocks1's Avatar
Ah yes. Good point. I recall seeing that was the method used to enable. Mirroring lines if code from the E9x. Thanks for reminding me
Old 19th July 2011, 17:43   #459
mimi74
mimi74's Avatar
So I've looked closer to the PDC feature Here's some of my stuff. Think to make some test on this
MELDUNG_TASTER
nicht_aktiv
To makes a tone when PDC button pressed
AKUSTISCHE_FEHLERMELDUNG
nicht_aktiv
Acoustic error message for PDC
EINSCHALTMELDUNG_IMMER
nicht_aktiv
Power always
EINSCHALTMELDUNG_BEI_1MAL
nicht_aktiv
Power-on 1 time ??
NOTFUNKTION
nicht_aktiv
Emergency operation (What for?)
EIS_AUSBLENDEN
aktiv
Hide the ice (?)
AKUSTIK_RECHTS_LINKS
aktiv
Right and Left tones
EINSCHALTVERZOEGERUNG
aktiv
Power on delai
ANHAENGERKUPPLUNG
nicht_aktiv
Trailer mode
PDC_AKTIV/DEAKTIV
rueckwaertsgang -Comes on in reverse gear and goes off when leave reverse
weg_geschw (off speed?) - default behavior where PDC turns itself at specific speed
TONGEBER_HINTEN
lautsprecher
Rear sound (loudspeaker)
TONGEBER_VORN
lautsprecher
Front sound (loudspeaker)
ABSCHALTMELDUNG
nicht_aktiv
Unpower confirmation
ABSTAND_KOPPLUNG
nicht_aktiv
Pitch generation
DYNAMIC_ABSCHALTEN_VORN
aktiv
Dynamic power off forward (perhaps need to coupling this function with always power on ??)
Old 22nd July 2011, 15:41   #460
reesy_csl
reesy_csl's Avatar
Garage: BMW M6 - Silverstone 2
Tools update
Update to BMW tools guys: https://rapidshare.com/files/980891824/setup_2100.zip
This contains the BMW Service Tools installer with the latest INPA 5.0.2.0, NCSEXPERT 1.0.0.1, EDIABAS 7.2.0 2.0, and the latest other tools such as Tool32 etc. Works fine, i've installed this just now, it will prompt for the file locations of existing directories, just point them, and the installer will do the rest. The only thing I had to do was blank the .TRC in the work folder before the first module read would work correctly. I had to do this upgrade to enable the reading of the latest modules which are being retrofitted to our cars from the 2011 range. I also updated the E89 daten(E90) folder using V41 daten files, you'll see why in the next part.
For those of you experimenting with modules never installed in E63, who want to read things such as combox etc. I have found out that you can use a SSD file which simulates the latest E90, to effectively bypass the VIN identification stage of NCS Expert and allow you to read those new modules which now exist in your vehicle. I've attached the file to here as a txt file, simply rename the file ending to .ssd. Instructions and file excepted from 5series.net, thanks to the guys over there for sharing the knowledge:
1. In NCS after you choose the Profile, click the VIN button.
2. Then instead of clicking the ZCS button you choose "Open File".
3. Then point to your ssd file. That will fool NCS into thinking the car is anything with any VO. Basically does not look at the car.
4. Click the back button and now you are in the normal NCS except its using a different car/vin/vo to what you have. In that list you will see the MEDIA ecu listed.
File Type: txt testssd.txt (307 Bytes, 206 views)
E63 M6 - GC Coilovers/Camber Plates/Top Mounts, Brembo BBK, Eisenmann Race, CA Stage 2 Map, Carbon Lip, LCI Tails, CIC Idrive Retrofit, Combox
E36 M3 Evo
Race Car - S54 Engine, Stripped Out, Cobra Sebring Pro, Lexan Windows, 1100kgs
ZX10R Track Bike - Ohlins, PC3, K-tech, Akrapovic Exhausts, Brembo, Renthal
reesy_csl is offline   Reply With Quote
The Following 2 Users Say Thank You to reesy_csl For This Useful Post:
Clyde (22nd July 2011), zerocks1 (22nd July 2011)
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
DC-M6
Coding our own E63-E64 Success_Finally! zerocks1 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 37 25th April 2011 10:56
How long will you keep your M6 (E63/E64)? Mark Carson E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 22 20th August 2010 18:01
The last E63/E64 - own a piece of history Mark Carson E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 5 12th March 2010 17:43
E63 and E64 Exhaust the same? Serious6 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 17 22nd April 2009 20:53
Euro Headlights for M6 and other E63/E64 TheGermanOne Parts / Other For Sale or Wanted 0 30th July 2007 13:52
