16th June 2011, 10:10
#386
BMW M6 - Silverstone 2
Yes you are right it will restore if you code a blank .MAN file to a module. What I would do though is read it, and copy a version to another folder and rename it so you know which module it relates to. You may find a factory reset will lose some things you currently have setup.
You can fold up the mirrors without comfort access, not sure if it relates to that line. I have coded mine with comfort access but it was a while ago. I do know that it's definitely possible. Back the module up, and try some different things. Good luck!!!
E63 M6 - GC Coilovers/Camber Plates/Top Mounts, Brembo BBK, Eisenmann Race, CA Stage 2 Map, Carbon Lip, LCI Tails, CIC Idrive Retrofit, Combox
E36 M3 Evo Race Car - S54 Engine, Stripped Out, Cobra Sebring Pro, Lexan Windows, 1100kgs
ZX10R Track Bike - Ohlins, PC3, K-tech, Akrapovic Exhausts, Brembo, Renthal
