Ref: Nav default to Navigation.
That is the correct coding for the iDrive to default to the NAV screen upon startup. Here are a couple of reasons why it may not be defaulting to NAV
- Legal Disclaimer must be nicht_aktiv as well CAPPL module
legal_discl >nicht_aktiv
- There may be additional defaults set to aktiv in addition to va_fb_navigation, such as va_fb_entertainment, or some other. They may be in conflict. All others should be nicht_aktiv
- You haven't let the CAPPL module completely reboot (10 min or so), and it is working
- The line of code did not take
To your question regarding upgrading iDrive or module firmware/sw. the answer is no, with NCS or INPA. That requires SW that is more complex. If you wish to upgrade your iDrive controller physically, you can. If you wish to upgarde the CAPPL module to the newer CIC module, with or without the physical controller, you can as well.
Look at the thread 'My new M6 from France'. Read through all of it, courtesy Mimi74
I just finished (well almost finished), that upgrade. Im going to start a new post later. Thanks to Mimi74, Reesy_csl, and our friend Patryk in Poland, I have the new CIC, Screen, CF front, LCI Climate Control, and COMBOX
I just enabled real time internet access via BT. Yup, you read me correctly.
Also I started using the iPhone app BMW Connected. I will explain that in an upcoming thread I will create....and, I have my iPhone screen display whatever is on it, including mail, at will.
I'm overwhelmed with the possibilities. just finished two days worth of a tvandnav2go video interface removal and reinstall of a newer version, removal of Dension 500. Just don't need it any longer, and a number of other older mods.
Don't want to change the topic of the thread so here's a tease until later
