DYI _Coding the E63-E64 *Updated 02-21-2011 - Page 31 - BMW M5 Forum and M6 Forums
Like Tree180Likes
LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 13th April 2011, 10:35   #301
reesy_csl
reesy_csl's Avatar
Garage: BMW M6 - Silverstone 2
I remembered that Alan posted up some modules and activities in to a word doc. I've re-attached them here- they contain the seat belt gong, and some various others.
The video in motion- thats a tough one with the late CIC idrive, its much more complex than just changing a line in one of the modules. The DIY'ers have some special methods of doing it. I'll try and dig it out again.
E63 M6 - GC Coilovers/Camber Plates/Top Mounts, Brembo BBK, Eisenmann Race, CA Stage 2 Map, Carbon Lip, LCI Tails, CIC Idrive Retrofit, Combox
E36 M3 Evo
Race Car - S54 Engine, Stripped Out, Cobra Sebring Pro, Lexan Windows, 1100kgs
ZX10R Track Bike - Ohlins, PC3, K-tech, Akrapovic Exhausts, Brembo, Renthal
reesy_csl is offline   Reply With Quote
The Following User Says Thank You to reesy_csl For This Useful Post:
Mark Carson (13th April 2011)
Old 13th April 2011, 16:44   #302
zerocks1
zerocks1's Avatar
Garage: 2007 M6 Cab Sapphire Black
Congrats Mark. First things first. On 2010's, you do not have a CAPPL module. It had been replaced with a CIC module.
The lines of code are slightly different than the CAPPL version
I would exercise caution writing changes to that master 193K module. That's the entire car and acts as a master backup. Strongly urge you to write to the individual modules
From memory, the CIC lines of code of interest are:
(even though you've done this through the master). CIC module Legal_xxxxx_timeout_xx. Change to kein_ld. The character before the lower case d is not on our US keyboards. You have to copy it from the existing command line to make the new command kein_ld. It looks like a lower case L or the number 1
Video in motion (VIM), is a two step process on the 2010's. First is the handbrake command so the video plays whether or not the handbrake is applied
Search for the word handbremse_xxx in the CIC module. Change the command to nicht_aktiv. You can do both of the above changes at the same time.
The VIM requires a very specific procedure that uses a combination of NCS and a program that's embedded in your Ediabas directory called Tools32.exe.
Much of what's around the web on this topic require changes for E63/4 models. If you send me a PM with an email address I will send you a version that I tested once on a 2010 with another member who is local here in SoCal
This is my pasted list from my iPhone. Ignore the CAPPL module references.
- Legal disclaimer CAPPL_legal_discl >nicht_aktiv
- iDrive entertainment default screen CAPPL va_fb_entertainment >aktiv
- Key in Ign gong KOMBI cc_zuendschluessel >nicht_aktiv
- Seat belt gongs ABG sbr_beifaher and sbr_faher >nicht_aktiv
- HUD directionals HUD blinker_ausstattung >aktiv ( you likely have visual blinkers in your HUD already. Only works when in non M mode)
- bc digital display KOMBI bc_digital_v >aktiv
- fan speed in auto mode IHKA gebl_anzeige_auto >aktiv
- auto light sensor sensitivity RLS flc_schwellwert >wert_03 (very sensitive)bottom number only
- bc real speed korrektur KOMBI bc_digital_v_korrektur >_aktiv (gives you true GPS speed on the bc digital speed display)
- Eject key fob when engine turns off CAS. KOMFORT_EJECT >aktiv
- Outside mirrors fold when key fob lock is held for 2 sec or finger is placed on door lock for 2 sec CAS komfortschliessng_fb. aktiv and komfortschliessung_pa aktiv
PLUS KGM module beiklappen_xxx > acktiv
- KOMBI gas tank to empty warning reduced tank_schwelle_reserve. wert 03>02. (or wert 02 which warns within 20 miles)
Have fun!
zerocks1 is offline   Reply With Quote
The Following User Says Thank You to zerocks1 For This Useful Post:
Old 13th April 2011, 17:44   #303
whatheheck
whatheheck's Avatar
Garage: 2009 M6 Convertible, black / tan
Sales Feedback: (4)
Thanks for the welcome back greetings Alan and James.
Yes, very good memory Alan! The photo is St Thomas Virgin Islands.
I took the photo when we went on an excursion exploring the island.
Our ship Equinox is the first one on the left.
Vacation was really nice. Lots of rest and relaxation, we ate some great food and did some nice sight seeing in the Caribbean Islands.
The sad part - I have over 300 personal eMails and over 400 work emails to read and reply to. Sucks.
Anyway, thanks to Alan and you all for the continued update on this.
I will keep reading for now until I get caught up with my to-do list and catch up with work and home eMails.
Never ending thank you Alan and to all of you for this great thread.
Originally Posted by zerocks1 View Post
welcome home Dan. The pix looks like Charlotte Amalie, St Thomas? If so I'm jealous. If not, I'm still jealous
As to the pin#8,. just desoldering the wire to it should be sufficient. No electric, no longer live. Give it a try, it's working for most.
Regards
Dan
Evolve ECU Tune, Tubi Rumore exhaust, BBS RGR rims; Polk Audio Tweeters, 5500K Osram Cool Blue HID,Valentine 1 Radar Detector; Laser Interceptor Laser Jammer; All LED interior lights, LED footwell lights, LED trunk lights, Ultimate Cup Holders, 3rd brake light LED flasher, ash tray delete; LED license plate lights; RPI Ram Air Scoops + Block off plates; BMC Air Filters.......
whatheheck is offline   Reply With Quote
Old 25th April 2011, 10:57   #304
Mark Carson
Mark Carson's Avatar
Garage: Cold beer
Briefly, I've got some things changed as of tonight. The hand brake disabling of VIM is done, but the movement part remains an action item. I do have digital speed though. So I'm happy that the "getting going" hurdles have been cleared and now it's just the actual changes to be found and applied.
Thanks to Allen and reesy_csl and everyone else who has helped and shared their woes!
2011 Z4 3.0
2011 528i
2010 M6 Individual Coupe http://www.m5board.com/vbulletin/e63...vidual-m6.html
Mark Carson is online now   Reply With Quote
Old 25th April 2011, 21:42   #305
reesy_csl
reesy_csl's Avatar
Good man! Glad to see your making good progress, it's definitely a rewarding process!!
Old 25th April 2011, 22:36   #306
whatheheck
whatheheck's Avatar
Sales Feedback: (4)
And how much was someone asking for again Mark to bypass the BMW Video in Motion lock awhile back?
Yes, never ending thank you to Alan and James for all their help on this!!!!!
I am sure I will have fun once I start to do mine.
I still want Kim Kardashan or Megan Fox wearing thongs washing my beast as an initial start up splash screen.
Now there's a challenge for Allan, James and Mark Carson!
Old 25th April 2011, 23:52   #307
BurnR8
BurnR8's Avatar
Garage: 2007 M6 Indy Red
If you get Kim K to wash your car, I will paint your house if you let me do the video work!! And of course, I will host the after party!!!!! I will do my best to find out if she actually has a talent.
BurnR8 is offline   Reply With Quote
Old 26th April 2011, 01:46   #308
whatheheck
whatheheck's Avatar
Sales Feedback: (4)
LMAO! Right on Dave! You are on buddy.
I dont know about talent though.........
They are usually only good for their good looks and nice figure. Usually not much up there.
Old 26th April 2011, 16:36   #309
whatheheck
whatheheck's Avatar
Sales Feedback: (4)
Update:
I heard one of our very highly valued member here is trying to find a way for us to be able to customize our own splash screen.
That would be awesome!
Just think, you can put your girlfriends photo (yes plural), your ex-wife's photo, your divorce lawyer's photo, Newt Gingrich photo, Charlie Sheen's photos, your dog, your kid's baby sitter, or even your mother in law!
Looking forward to this! Thanks!
Old 26th April 2011, 19:56   #310
BurnR8
BurnR8's Avatar
I am going with ADONIS DNA
Currently Active Users Viewing This Thread: 7 (1 members and 6 guests)
jaminj946
Coding our own E63-E64 Success_Finally! zerocks1 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 37 25th April 2011 10:56
How long will you keep your M6 (E63/E64)? Mark Carson E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 22 20th August 2010 18:01
The last E63/E64 - own a piece of history Mark Carson E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 5 12th March 2010 17:43
E63 and E64 Exhaust the same? Serious6 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 17 22nd April 2009 20:53
Euro Headlights for M6 and other E63/E64 TheGermanOne Parts / Other For Sale or Wanted 0 30th July 2007 13:52
