DYI _Coding the E63-E64 *Updated 02-21-2011 - Page 29 - BMW M5 Forum and M6 Forums
Like Tree180Likes
LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 2nd April 2011, 09:53   #281
reesy_csl
reesy_csl's Avatar
Garage: BMW M6 - Silverstone 2
The dreaded PIN 8!
I've just received my cable this morning, and although labelled as a K DCAN+ cable, it has pin 8. I bought from the Canadian vendor, Dan you'll most likely have the same thing buddy.
I've opened it up, and it seems that pin 8 is joined by solder to pin 7, so in effect is carrying whatever Pin7 is. It looks like an easy enough job, just unsolder from the reverse. So I am assuming on all of the working cables Pin 8 does not exist at all? Alan, would it be possible to put a picture up of yours, so I can be certain before I unsolder this one.
Thanks a lot!
James
E63 M6 - GC Coilovers/Camber Plates/Top Mounts, Brembo BBK, Eisenmann Race, CA Stage 2 Map, Carbon Lip, LCI Tails, CIC Idrive Retrofit, Combox
E36 M3 Evo
Race Car - S54 Engine, Stripped Out, Cobra Sebring Pro, Lexan Windows, 1100kgs
ZX10R Track Bike - Ohlins, PC3, K-tech, Akrapovic Exhausts, Brembo, Renthal
reesy_csl is offline   Reply With Quote
Old 2nd April 2011, 18:19   #282
zerocks1
zerocks1's Avatar
Garage: 2007 M6 Cab Sapphire Black
Here is closeup of the cable pins. As you can see pin#8 is missing, as it should be. This was one of the major differences in our cars vs. other models where this cable would in fact work. From the reading I have done, and at least one confirmed first hand desolder of the shunt between pin 7 and pin 8, removing the wire going to pin 8 allows the cable to work properly with our E63-64's.
It will cause the cable to no longer be backward compatible with K only type OBDI model cars, but I for one didn't buy one for anything other than my E64.
Dave, leaving the cable out of the picture for the moment. You definitely have a program problem and likely incompatible with the image on your laptop as you surmised. Can you try loading the program on a different laptop? Or perhaps on a desktop you may have, just as a test. I think the program isn't liking your laptop, and I've seen reports of certain Dell brands not accepting the files properly (I use a Dell from work and it does work just fine). It may not like your laptop unless you start partitioning your HDD, which may mess with your required work image.
I think we may be getting to the bottom of the cable communications problems via this pin for some of you.
zerocks1 is online now   Reply With Quote
The Following 2 Users Say Thank You to zerocks1 For This Useful Post:
reesy_csl (3rd April 2011), whatheheck (12th April 2011)
Old 3rd April 2011, 23:30   #283
zerocks1
zerocks1's Avatar
Finally had a chance to do some testing with the fuel reserve warning indicator.
Here are the settings and approximate values when the warning will come on
Module: KOMBI
Line of code: tank_schwelle_reserve
Standard setting: wert 03
Options:
wert 02 warning appears with approximately 1/8 tank, 36 miles to empty
wert 01 warning appears with a little less than 1/8 tank, 24 miles to empty
In both cases, once you reach approximately 20 miles to empty, the fuel tank light stays lit and the iDrive screen maintains a countdown of xx miles to empty.
I left the setting at wert 02. Got a little scared leaving it at 01 with visions of AAA or BMW Roadside assistance with a container of 87 Octane and an embarrassing look on my face
Mark Carson (4th April 2011), whatheheck (12th April 2011)
Old 6th April 2011, 13:56   #284
reesy_csl
reesy_csl's Avatar
I removed pin 8, not much trouble at all, just undo the solder joint and remove the pin. I have communication through INPALOAD and also NCSExpert, but having the same trouble others are mentioning when going back(F6).
I've attached a screenshot of what error i'm getting. I have done all the updates to daten etc.
Any ideas Alan?
Old 6th April 2011, 14:43   #285
reesy_csl
reesy_csl's Avatar
Ignore the previous post, I solved it using Clyde/Zerocks solution posted earlier in this thread. Basically clear the text located within the TRC/MAN files from the work folder. It seems to be an issue caused by a corrupt original profile read.
All working well! I now have a digital speedo reading!! Thanks for all your help
Old 6th April 2011, 17:04   #286
zerocks1
zerocks1's Avatar
Thats great reesy. Glad the pin desolder worked. Yes the F6 return is usually a corrupt .TRC and .MAN and/or duplicate file with the same extensions in your work folder. Found that out the same way you did.
Plenty you can do now. Just make sure you have a backup of the original modules files, just in case. Name them all something you will recognize and save them in your backup folder, not your work folder
Congrats.
Old 6th April 2011, 17:18   #287
reesy_csl
reesy_csl's Avatar
I've had a little play already! Got the indicators in the HUD and the digital speed on the BC button. I was trying to do the folding mirrors, but was unsure what I needed to change. Do you remember which you did Alan? I remember it being in both KGM and CAS.
Old 6th April 2011, 17:43   #288
zerocks1
zerocks1's Avatar
I will assume you car has the factory Comfort Access feature.
KGM module
line of code BEIKLAPPEN_B_KOMFORTSCH nicht_aktiv to aktiv
CAS module
lines of code komfortschliessung_fb nicht_aktiv to aktiv (if not already). To use, exit car, hold lock button on FOB approximately 3 seconds and release
komfortschliessung_pa nicht_activ to aktiv This perform the same function with a two second touch on the door handle
Let me know if you need more tips
The Following User Says Thank You to zerocks1 For This Useful Post:
Old 6th April 2011, 18:00   #289
reesy_csl
reesy_csl's Avatar
Worked perfectly! Alan, thank you very much for all the time you have put in to making this work, it's much appreciated. This thread is truly invaluable!
The Following User Says Thank You to reesy_csl For This Useful Post:
zerocks1 (6th April 2011)
Old 11th April 2011, 04:58   #290
Mark Carson
Mark Carson's Avatar
Garage: Cold beer
I'm stuck at the same point you were. I renamed my .TRC file. Did you delete all of the text within the file but leave the file on the file system or do something else?
2011 Z4 3.0
2011 528i
2010 M6 Individual Coupe http://www.m5board.com/vbulletin/e63...vidual-m6.html
Mark Carson is offline   Reply With Quote
Coding our own E63-E64 Success_Finally! zerocks1 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 37 25th April 2011 10:56
How long will you keep your M6 (E63/E64)? Mark Carson E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 22 20th August 2010 18:01
The last E63/E64 - own a piece of history Mark Carson E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 5 12th March 2010 17:43
E63 and E64 Exhaust the same? Serious6 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 17 22nd April 2009 20:53
Euro Headlights for M6 and other E63/E64 TheGermanOne Parts / Other For Sale or Wanted 0 30th July 2007 13:52
