DYI _Coding the E63-E64 *Updated 02-21-2011 - Page 28 - BMW M5 Forum and M6 Forums
Like Tree180Likes
LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 30th March 2011, 03:27   #271
zerocks1
zerocks1's Avatar
Garage: 2007 M6 Cab Sapphire Black
So, after a few phone conversations with some stuck members at various steps, we uncover that different MY and month builds require updated files to work. The updated files go in these three folders.
\NCSEXPER\SGDAT\ -------- .ipo files
\NCSEXPER\DATEN\ -------- coding data (daten) for models
\EDIABAS\Ecu\ -------------- .prg files
The \NCSEXPER\DATEN files are in a few posts back
The \NCSEXPER\SGDAT are zipped below and replace the files in that folder
The biggest one (34MB zipped) is the \EDIBAS\Ecu files. It's too large to post here, or email. Just tried with another member.
Anyone have a way to host them? The root source of all three are contained in the cumulative .rar files at rapidshare, which if you do not sign up for a premium account will take considerable time to d/l.
So I have them zipped and ready to upload to someone who can host them.
http://rapidshare.com/files/44454120...200.part01.rar
http://rapidshare.com/files/44454127...200.part02.rar
http://rapidshare.com/files/44454136...200.part03.rar
http://rapidshare.com/files/44454145...200.part04.rar
http://rapidshare.com/files/44454154...200.part05.rar
http://rapidshare.com/files/44454162...200.part06.rar
http://rapidshare.com/files/44454170...200.part07.rar
http://rapidshare.com/files/44454178...200.part08.rar
http://rapidshare.com/files/44454184...200.part09.rar
http://rapidshare.com/files/44454192...200.part10.rar
http://rapidshare.com/files/44454198...200.part11.rar
http://rapidshare.com/files/44454203...200.part12.rar
http://rapidshare.com/files/44454208...200.part13.rar
http://rapidshare.com/files/44454214...200.part14.rar
http://rapidshare.com/files/44454218...200.part15.rar
http://rapidshare.com/files/44454227...200.part16.rar
http://rapidshare.com/files/44454233...200.part17.rar
http://rapidshare.com/files/44454238...200.part18.rar
http://rapidshare.com/files/44454247...200.part19.rar
http://rapidshare.com/files/44454252...200.part20.rar
zerocks1 is online now   Reply With Quote
Old 30th March 2011, 19:47   #272
FogPuppy
Garage: 2010 M6 Carbon Black
Ok I've been following this thread with interest and I have a few questions:
1. Has anyone in the SF Bay area got this working on a 2010 M6? Could I piggy back off your results? I work in Cupertino and live over by Half Moon Bay ...
2. Do we have a definitive "Order cable from this person" and "You need exactly these files"?
thx
Kent
FogPuppy is offline   Reply With Quote
Old 30th March 2011, 20:48   #273
eddiejb
eddiejb's Avatar
Garage: 2007 Interlagos Blue M6 6spd w/ 5.8L Dinan Stroker, 2004 Silver WRX Wagon (lots of mods)
could also set up an amazon cloud drive for free....
https://www.amazon.com/clouddrive/le...tag=slicinc-20
eddiejb is online now   Reply With Quote
Old 30th March 2011, 22:25   #274
zerocks1
zerocks1's Avatar
Thank you Eddiejb
Nice find for free Cloud Services! So I created a new account at
https://www.amazon.com/ap/signin?_en...ntifier_select
login is zerocks123@aol.com (not going to be used as an email account)
pw is m5board
In the Documents directory you will find;
e60 03 28-11.zip... These are updated DATEN files that should be placed in the C:\NCEXPER\DATEN\E60 folder
ediabas ecu folder.zip .........These are updated files that should be placed in the C:\EDIABAS\ECU folder
ncsexper sgdat.zip .......These are updated files that should be placed in the C:\NCSEXPER\SGDAT folder
Profiles.zip. these are additional profiles that if needed can be used as additional options when you open NCS>file>load profile
.......These go in C:\NCSExper\PFL folder
Paste the files in these folders manually and do not delete any files that are not overwritten. So paste and YES to replace all
These are necessary if you have a MY2010 and in some cases >2008. There is no harm updating these for any MY, that I know of
I have come across some members with cable issues, even though the cable itself has the correct sticker and identifier on it. I am not sure the source of these (only two thus far that I am aware of)
Hope this helps move things along
Thanks again Eddie
Ledger:
The Following 4 Users Say Thank You to zerocks1 For This Useful Post:
FogPuppy (30th March 2011), Mark Carson (30th March 2011), MKSixer (1st April 2011), whatheheck (30th March 2011)
Old 31st March 2011, 19:50   #275
zerocks1
zerocks1's Avatar
Cable configuration
Learning from a member with a cable problem:
In addition to the last post, seems some members who purchased cables seemingly with the correct label and advertisement, that it is truly a K+DCAN cable, turns out they are not.
The correct description is
K+DCAN
USB Interface
(INPA Compatible)
Here's the difference. If you look directly at the pins in the cable, holding the wider side up and the narrower side down, you should see pin#8, which is the upper left location missing. The pin should not be there. If it is, it is not truly a K+DCAN, USB Interface, (INPA Compatible) cable, in spite of what the label says
If you do have a pin at that spot, a member was successful in desoldering the wire to that pin and that pin only (don't try and just break the pin off). Then his cable worked flawlessly. So buyer beware
Just another check to rule out any cable issue.
The Following 2 Users Say Thank You to zerocks1 For This Useful Post:
MKSixer (1st April 2011), whatheheck (1st April 2011)
Old 31st March 2011, 20:56   #276
RandysV10
RandysV10's Avatar
Garage: 2010 Dinan M6 Carbon Black Metallic
K+DCAN
USB Interface
(INPA Compatible)
Thanks again Allen for all your help
I verified last night that I do have all the pins so I will try and open up the cable to disconnect #8s pin wire.
RandysV10 is offline   Reply With Quote
Old 1st April 2011, 14:10   #277
whatheheck
whatheheck's Avatar
Garage: 2009 M6 Convertible, black / tan
Sales Feedback: (4)
Interesting and excellent info.
Thanks Allan!
I will definitely check my cable when I get home in 2 weeks.
K+DCAN
USB Interface
(INPA Compatible)
Dan
Evolve ECU Tune, Tubi Rumore exhaust, BBS RGR rims; Polk Audio Tweeters, 5500K Osram Cool Blue HID,Valentine 1 Radar Detector; Laser Interceptor Laser Jammer; All LED interior lights, LED footwell lights, LED trunk lights, Ultimate Cup Holders, 3rd brake light LED flasher, ash tray delete; LED license plate lights; RPI Ram Air Scoops + Block off plates; BMC Air Filters.......
whatheheck is online now   Reply With Quote
Old 2nd April 2011, 05:00   #278
dave t
Garage: M6 Black
Different error - UI server...
Hey guys, I got a different error...believe I followed all the instructions accurately including copying the updated files from the Amazon cloud into those folder.
By the way, the creation of the INPALOAD shortcut step is hidden under the image on the .pdf file.
When I try to run the INPALOAD shortcut, I get the attached error...any suggestions? Thanks
Error: UI server not found or illegal version!
dave t is offline   Reply With Quote
Old 2nd April 2011, 05:58   #279
zerocks1
zerocks1's Avatar
Dave, I've never seen anyone post an error such as what you did. That message looks like bad download of the program itself or incompatibility with your OS, or an incorrect shortcut. Seems like you are using Win7, which the program will work with. And I assume a 32 bit pc, not 64 bit.
In either case I would try reloading the program and perhaps even downloading it again. It should be approximately 98.2KB in it's zipped form. Also , make sure your INPA shortcut is a short cut to C:\INPA\BIN\INPALOAD.EXE. And also recheck that you unzipped everything to C:\ , not a subfolder you may have created
Keep us posted
Old 2nd April 2011, 06:30   #280
dave t
Garage: M6 Black
Yeah, I'm running 32-bit Win7...tried 2 different NCSEXPER.rar files...one downloaded when it was first reference in this post and a new copy from a recently posted address.
Tried capitalizing to match the PATH, but didn't make a difference. Running out of ideas, thinking that maybe it's cause my OS is a Corporate Image that has been modified...
Curious, without anything plugged into the laptop and you try and run INPALOAD, what happens?
I get the same error regardless if it's hooked up to my car or not. Also get the error when I try and run INPA. When I do hook it up and go through the ignition ON steps, the ODB plug does light up red for the 30 seconds, but can't get past the error.
Currently Active Users Viewing This Thread: 11 (0 members and 11 guests)
Coding our own E63-E64 Success_Finally! zerocks1 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 37 25th April 2011 10:56
How long will you keep your M6 (E63/E64)? Mark Carson E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 22 20th August 2010 18:01
The last E63/E64 - own a piece of history Mark Carson E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 5 12th March 2010 17:43
E63 and E64 Exhaust the same? Serious6 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 17 22nd April 2009 20:53
Euro Headlights for M6 and other E63/E64 TheGermanOne Parts / Other For Sale or Wanted 0 30th July 2007 13:52
