Launch Technique For M6 - Page 2 - BMW M5 Forum and M6 Forums
Old 4th November 2010, 09:40   #11
Hasan Shaikh
Hasan Shaikh's Avatar
Garage: E63 ///M6 - White
Originally Posted by whatheheck View Post
Great question.
First and foremost of course is tire temperature.
To my experience and based on extensive readings - maximum tire adhesion starts around and above 106F.
Anything lower than 106F and tires will slip and slide.
My EDC setting is almost always at normal / 1 LED lit mode.
It appears you already have your M6 set at maximum / optimum torque and power.
The only thing I can think of would be modulating your throttle to keep the wheel from spinning and getting the best tire grip.
+ 1
In addition, no matter what you do, you shall never be able to keep up with a Porsche from a stand still. Your friend had a GT3, I can assure you, you shall be surprised how fast the Carrera S is off the line. Absolutely unbelievable.
Hasan Shaikh is offline   Reply With Quote
The Following User Says Thank You to Hasan Shaikh For This Useful Post:
whatheheck (4th November 2010)
Old 4th November 2010, 09:56   #12
gasterus
gasterus's Avatar
Garage: M6, Black/black
Originally Posted by Hasan Shaikh View Post
+ 1
Yes, its amazing how P cars can effectively put down so much power to their wheels. My friend's GT3 is able to gain 1 car length from a f430 scuderia at launch, and won the 1/4 mile by more than 4 car lengths.
07 M6 blk/blk
RDsport RS58 stroker with custom ECU tune
Decated stock headers, supersprint x-pipe, E-Race mufflers
Evosport Pulleys, BMC air filters, RPI air scoops & oilcooler
H&R springs, Dinan FRC & rear sway bar
20" Ac Schnitzer V with Yokos advans sport
Brembos 6-pot 405mm front+4-pot 380mm rear
08 E92 M3 S.Graphite/Red
gasterus is offline   Reply With Quote
Old 4th November 2010, 10:01   #13
Hasan Shaikh
P has the perfect formula for launch. Rear engine, rear wheel drive and a ligt weight body. There is nothing that can best that.
You should see the new Turbos with PDK go. They are absolutely mind blowing.
Old 4th November 2010, 14:28   #14
M6Cabrio
M6Cabrio's Avatar
Garage: 2010 Alpine White M6
Besides the launch control, what is the best EDC setting for you to get the most traction off the line. I tried drag racing my stroker with my friend's tuned GT3, and he basically flew pass me at launch, while my car is struggling for grip. My EDC was at the softest setting, traction with M-dynamic mode, tire pressure at 33psi and tranny at S5 setting.
S5 MDM is actually a LOT slower than S6 DSC off. The only way you will get traction without Slicks/drag radials is going to a track that is prepped extremely well. EDC on softest setting seems to help too, but I still leave it on the hardest setting. For a stroker, I would just ease into it, but for a stock M5/6 just stomp the pedal and go. It will launch your car at 3500 RPM instead of the USA launch control setting which is lower. I have had times of 12.5-12.6 with my heavy cabrio stock by doing that method, and I think that is a decent time for that heavy car. Coupe's should be able to get a 12.0-12.1. I know for sure with slicks you could see 11.9 stock.
Last Produced V10 E64 M6 in the World -- Delivered August 14, 2010
M6Cabrio is offline   Reply With Quote
The Following User Says Thank You to M6Cabrio For This Useful Post:
Old 4th November 2010, 16:45   #15
David M///
David M///'s Avatar
Garage: 2007 M6 Coupe Silverstone/Black
Also, the age of your rear tires will make a big difference with regards to how well they hook up. You can pretty much stomp on it with new tires, but I've found that the PS2s get really greasy after they are about two thirds worn.
David M///
David M/// is offline   Reply With Quote
Old 4th November 2010, 16:57   #16
M6Cabrio
M6Cabrio's Avatar
I ran my times with bald tires too...I want to get back to a track to test it out with new tires.
Old 4th November 2010, 17:22   #17
Exeenom
Garage: Mercedes E63 AMG - BMW 650 & 335i
To my knowledge, BMW factory programmed Launch Control is the quickest.
I've only tried it once on a deserted road and it scared the heck out of me.
Driver needs practice to get the hang of it.
Note: based on what I've read - clutch wont last very long after a few runs using Launch Control.
So take note.
Here you go, as posted by Moderator scoopz:
THANKS A MILLION whatheheck..... that PDF is awesome. I guess we'll try out both methods and report back
Thanks to all who replied, I appreciate your help
Exeenom is offline   Reply With Quote
Old 4th November 2010, 18:14   #18
whatheheck
whatheheck's Avatar
Garage: 2009 M6 Convertible, black / tan
Sales Feedback: (4)
You're welcome.
As you can see, each of us have different techniques.
It is best to experiment and do whatever works best for you.
I agree with M6Cabrio - S6 DSC off mode provides the most power to the wheels.
Just make sure you try the S6 DSC off first on an empty street as the power of the V10 is insane with traction control off, engine and torque set to maximum (S6 DSC off.)
Dan
Evolve ECU Tune, Tubi Rumore exhaust, BBS RGR rims; Polk Audio Tweeters, 5500K Osram Cool Blue HID,Valentine 1 Radar Detector; Laser Interceptor Laser Jammer; All LED interior lights, LED footwell lights, LED trunk lights, Ultimate Cup Holders, 3rd brake light LED flasher, ash tray delete; LED license plate lights; RPI Ram Air Scoops + Block off plates; BMC Air Filters.......
whatheheck is offline   Reply With Quote
Old 7th November 2010, 17:50   #19
Exeenom
The tires have about 2000 miles on them right now so hopefully they'll be alright.... I just hope we get a nice cool day in SoCal for this event because lately it seems that it's been getting hotter instead of cooler although last year around the same time, it did drop down to 50 F at the track (Famoso) and almost everybody beat their personal best . It'd be awesome if we get a negative DA.
Old 27th November 2010, 07:10   #20
DAFSTST
Garage: 2010 Silverstone Metallic, Black Interior, Maya 20 in Wheels and "ALL" Options.
I have a hell of a time hooking up and know with practice I will get better. One night after 6 or 7 runs, trying all kinds of ways and still not hooking up, I tried this... I left the M button off, slammed my foot to the floor and after a blink of an eye, hit the M button. It worked with just a little wheel spin and cut 2/10th off my other times. Is it the way to go, can't say without some more runs.
DAFSTST is offline   Reply With Quote
The Following User Says Thank You to DAFSTST For This Useful Post:
whatheheck (27th November 2010)
New launch control technique? RussianM E60 M5 and E61 M5 Touring Discussion 9 7th July 2009 23:17
Best Launching technique.. OC e39r E39 M5 and E52 Z8 Discussion 30 5th June 2009 21:34
Porsche's version of Launch Control: "Launch Assistant" on the 911 GT2 (997) Gustav E60 M5 and E61 M5 Touring Discussion 1 31st August 2007 03:31
What is the best technique to do 0-60? at80 E39 M5 and E52 Z8 Discussion 24 20th September 2005 21:48
Shifting Technique wxl1988 E39 M5 and E52 Z8 Discussion 16 23rd April 2004 07:45
