TC-400 is not car specific.
It just depends on the wheel that you have installed to make sure it will fit properly.
It's a 2 step installation.
1) Have the Hella wheel sensor installed by a GOOD / high end tire shop.
And make sure you tell them to be very careful as if they are not, the wheel machine will pop it right off.
2) Once the wheel sensor is installed, take the head unit to a custom shop and have them install it.
Very simple installation. If I remember correctly - two wires, just power and ground.
Then find a location for the display monitor.
YOu are in Seattle?
I had my tire sensor installed by Omni Brake and Alignment in Kirkland.
They did a fantastic job and they only charge $12.00 per wheel!
And that included wheel re-balancing.
Find a local car electrical shop like DEfinitive Audio to install the wiring and display module for you.
Originally Posted by iroquis_pliskin
Do yo think they have Hella TC-400 TPMS for e63?! Tire store should be able to install it, right?!
