Charcoal Filter removal question - BMW M5 Forum and M6 Forums
Old 19th April 2010, 21:23   #1
golf_hero
golf_hero's Avatar
Garage: 2009 M6 Vert - Carbon Black
Hi All,
This weekend I removed my charcoal filters and also put in BMC filters while I was at it. My car is an 09 vert and I followed the instructions posted on the board. Everything went well except I had to disconnect and reconnect one hose that was not in the instructions (see pictures below). The hoses were held via clamps along the side of the air box and one of the hoses did not have enough play to get the airbox out without removing the hose. I'm pretty sure it was a coolant hose.
Excuse my ignorance, but I just want to make sure it was no big deal disconnecting and reconnecting this hose (air bubbles, pressurization issue, etc). When I disconnected it, it made a sucking sound like it was pressurized and a bit of coolant leaked out (just a spoonful). I don't think this is any different than opening up the coolant resevoir to check coolant levels, but wanted to make sure (I'm paranoid because the car is new
The car is driving great and no warnings so hopefully not a big deal - can anyone confirm this is ok?
TIA!
golf_hero is offline   Reply With Quote
Old 20th April 2010, 07:20   #2
Blacksport350
Blacksport350's Avatar
Garage: 2008 M6 Black 6MT
It should have been possible to pop them out of the "channel" that they sit in and move them over so you didn't have to disconnect them to remove the covers.
That aside, there should be no issues that result from the minor loss of coolant and the sucking was just a bit of pressure or vacuum in the system that was released so also nothing to worry about.
"When you turn your car on, it should return the favor..."
Blacksport350 is offline   Reply With Quote
Charcoal Filter Removal??? MCarRacr07 E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 10 29th June 2008 04:53
Help Charcoal Filter removal problemo! M5Froth E60 M5 and E61 M5 Touring Discussion 1 3rd February 2008 23:04
Charcoal filter removal epm E60 M5 and E61 M5 Touring Discussion 9 25th July 2007 04:58
Charcoal Filter removal... Stewart W E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 20 18th June 2007 04:13
E60 M5 - Charcoal Filter Removal - Step-by-Step (w/Pictures) jfenley M5 E39 and E60 tips & tricks 0 2nd February 2006 06:05
