Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > BMW M5, M5 Touring, M6 and Z8 Forums > E63 BMW M6 Forum and BMW M6 Convertible | m6board.com
Old 22nd October 2009, 01:48   #1
MiamiSixer
MiamiSixer's Avatar
Garage: White M6
Remove Primary Cat in South Florida
Hey guys, does anybody know a trustworthy shop in South Florida that could delete the primary cat? Also, do you need an extension to replace the sensors behind the secondary?
MiamiSixer is offline
Old 22nd October 2009, 02:00   #2
snowball
snowball's Avatar
Garage: '07 M6 Cab Black Sapphire
Go see ASR Engineering, Inc.
snowball is offline
The Following User Says Thank You to snowball For This Useful Post:
MiamiSixer (22nd October 2009)
Old 22nd October 2009, 03:31   #3
Pio
Pio's Avatar
Garage: 2008 M6 - Alpine White
Originally Posted by snowball View Post
+1
Pio
2008 AP M6 SMG (19" HRE C20's, Yellow Brembo's w/ Slotted Rotors , ASR exhaust & Intake)
Evosport Pulley & Headers NEXT!
2007 Black 750 Li
Notables no longer in the stable:
2001 M5 Dinan Stuff
2001 C5Z
2003 CL55
2005 C6
2006 C6Z (Sc'd 611 rwhp / 580 rwtq)
2003 C5Z (SC'd735 rwhp / 680 rwtq)
Pio is online now
Old 22nd October 2009, 05:11   #4
sattman
sattman's Avatar
Garage: 2006 M6 interlagos blue
when you mean delete do you mean gut it out or replace it with headers. Cause i was thinking about gutting them. It seams to take the same time as installing headers but you save the money on not having to buy them and still get the gains. but i decided to wait till the warranty is over.
let me know what you come up with.
2006 interlagos blue silvertone interior Dyno'd 433 rwhp - scoops only
AC Schnitzer Trunk Lid Spoiler
AC Schnitzer springs
AC Schnitzer white carbon interior
RPi scoops
RPi block off plates
RPi GT exhaust v2 Cat back
21" HRE 597r
sattman is offline
Old 22nd October 2009, 18:39   #5
snowball
snowball's Avatar
+1 I agree, replacing just the cats with pipe or gutting them, makes the BMW OEM headers perfect, and is a lot cheaper.
snowball is offline
Old 22nd October 2009, 23:38   #6
MiamiSixer
MiamiSixer's Avatar
Garage: White M6
Do you guys think gutting them and leaving the empty chamber wouldn't affect the air flow?
Old 23rd October 2009, 00:08   #7
ASR Engineering
Company representatvie for ASR Engineering
ASR Engineering's Avatar
Garage: M5 Black
Would not recommend gutting them, as this would increase aerodynamic tumble within the exhaust flow. You would be much better off cutting the cat out and wedling in a straight pipe if you don't want to spend the money on headers. Although, the labor costs would be a bit more than just installing headers since doing this kind of job is more labor intensive. Eventhough the labor costs are higher, you will still be saving quite a bit of money over purchasing headers.
Also, you will need to do a DME re-flash for the O2 CEL.
ASR Engineering is offline
Old 23rd October 2009, 03:54   #8
sattman
sattman's Avatar
. i knew it would throw a CEL, but i didn't think about the aerodynamic tumble. Something to think about. There was a member in S America who did this and said it did pretty well for him but i don't remember what else he said about it or if he dynoed it afterwards.
RPi scoops
21" HRE 597r
sattman is offline
Old 23rd October 2009, 04:38   #9
Murtaza
Murtaza's Avatar
Garage: 08 M6 Alpine White
Wouldn't the bored primary cats inner surface be smooth? What would cause aerodynamic tumble?
__________________________________________________ _
'08 M6 Alpine White on Black | RPi GT Exhaust Sec. 3 | RPi Intake Kit | Straightpiped postcat/resonator
'06 SL55 030 Black on Berry Red (gone)
'06 SL500 Iridium Silver on Berry Red (gone)
'06 E350 (gone)
'99 M3 Black on Black (gone)
Murtaza is offline
Old 23rd October 2009, 20:40   #10
ASR Engineering
Garage: M5 Black
Aerodynamic tumble is basically a measure of airflow turbulance. Even if the area is smooth inside the bored out catalytic, this will still cause aerodynamic tumble since airflow turbulance is not necassarily caused by just rough exhaust path surfaces. One of the major factors of airflow turbulance in this scenario is the expansion of piping diameter right before the header collector causing a reduction of exhaust gas energy and in turn decreasing it's scavenging affect. When the cat is in place, it slows down the exhaust flow allowing it to build more exhaust gas energy to negate the fact that it is placed in a larger surface area. This is not to say that you won't make more power when the primary cat is deleted. It will make more power, but not as much as if it were done correctly.
The Following User Says Thank You to ASR Engineering For This Useful Post:
Murtaza (23rd October 2009)
Who,s from South Florida? BROKER E39 M5 and E52 Z8 Discussion 7 31st October 2005 19:56
Anyone Here from South Florida?? apk1013 E39 M5 and E52 Z8 Discussion 6 20th October 2004 21:08
South Florida M5ers Zman E39 M5 and E52 Z8 Discussion 33 7th November 2001 18:28
South Florida people Jester E39 M5 and E52 Z8 Discussion 0 11th February 2001 17:42
Page generated in 0.12866 seconds with 11 queries
