Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > BMW M5, M5 Touring, M6 and Z8 Forums > E63 BMW M6 Forum and BMW M6 Convertible | m6board.com
Old 21st October 2009, 03:29   #1
MVP
Garage: M6 Coupe
Braking too hard can cause damage to car? And weird noise coming from right rear wheel.
I was driving behind a Z4 M when I saw a heavily modded 645i to my right. I guess something about it caught my eyes and I rubbernecked a bit. By the time I looked back at the road, I was terribly close to the M which has already stopped on a red light. I had to slam on the brakes as hard as I could and the steering wheel shook violently but fortunately I managed to make the stop right before I rear ended him (I am talking about perhaps 10 cm away from impact). I will definitely be more careful on the road after this incident but somehow, I feel the car a little limp after braking so hard. I am wondering if I am simply worrying over nothing or if I risked damaging anything significant by slamming my brake to the fullest?
Another question I have is regarding a weird rubbing sound whenever I make a right turn. It sounds like it came from my right rear wheel but I have taken the car to the dealership several times but they can't find anything wrong with it. They also can't seem to give me an explanation either but every friend that has been in my car can verify the noise so I know I am not insane here (well, at least not over the car :P).I have had the car since new and there doesn't seem to be anything that warrants the wheel to make such a rubbing noise as far as I am concerned. Does anyone have a possible suggestion to what might have caused the problem?
Thanks.
MVP is offline
Old 21st October 2009, 09:03   #2
Clyde
Clyde's Avatar
Garage: Sepang Bronze M6 Coupe
Originally Posted by MVP View Post
...I am wondering if I am simply worrying over nothing or if I risked damaging anything significant by slamming my brake to the fullest?
There should not be a problem. "Slamming" down on the brake pedal and holding it down is the correct way to perform an emergency stop
Some cars even detect sudden brake pedal movement and increase brake pressure, since many drivers will not push the petal hard enough in an emergency -- I don't know if the M5 has this feature.
...I have is regarding a weird rubbing sound whenever I make a right turn.
Are you sure it's not your differential?
Noise from the differential is a very common issue.
Clyde is offline
Old 21st October 2009, 18:15   #3
M-individual
M-individual's Avatar
Garage: BMW M6 convertible individual - Rubinschwarz / Merino Goldbrown
That doesn't sound right to me. You may get a little bit of shaking as the back end of the car gets light under heavy braking. Sure your rotors aren't worn?
You should not feel any difference to the brakes after one emergency stop. M6 brakes aren't the best of the best when you track the car but under normal driving conditions (including emergency stops) they do their job very well and are not affected at all.
PS: you may have been thrown off by the fact that you felt ABS kick in. A lot of people are worried that something is wrong with the brakes when ABS starts to work because they get this grinding noise and feel from the brake pedal. That is perfectly normal though.
Go to a place where you can practice a couple of emergency stops (= slam the brakes and keep them slammed until you come to a full stop) and see how the car reacts. You will be able to analyse and experience it way better if you do this premeditated.
Cheers,
M
M-individual ///
_________________________
2007 M6 Convertible Individual (Ruby Black - Merino Gold Brown)
2008 BMW X5 4.8i (E70) - Alpinweiss III
2007 Ferrari F430 F1 - Bianco Avus - CS Brakes
Ferrari 599 HGTE One to One - Grigio Ferro Met - Grigio Corsa Daytona challenge rims - lots of CF parts
We need IDEAS not solutions
M-individual is offline
The Following User Says Thank You to M-individual For This Useful Post:
logpak23 (22nd October 2009)
Old 22nd October 2009, 06:03   #4
logpak23
logpak23's Avatar
Garage: 2008 alpine white m5
Send a message via AIM to logpak23
in the manual it says to occasionally put the brakes under load to keep them running properly, so dont worry about slamming on the brakes at all.. +1 on the fact that you should go to a safe location and try to slam on your brakes and get a feel for them.
logpak23 is offline
Strange noise coming from rear of car brucewil E60 M5 and E61 M5 Touring Discussion 16 1st August 2007 22:12
Hard Braking Noise Manx M5 E60 M5 and E61 M5 Touring Discussion 6 30th August 2006 23:18
BBK Stoptech front kit on my car pulsating under hard braking conditions. Normal? atomic80 E39 M5 and E52 Z8 Discussion 4 2nd September 2005 09:06
REALLY weird clunking noises coming from under the car..... bluebeast01 E39 M5 and E52 Z8 Discussion 4 12th July 2003 06:01
Partial Wheel Lockup - Braking Hard From 80 MPH DrRob E39 M5 and E52 Z8 Discussion 16 7th August 2002 21:54
Page generated in 0.11535 seconds with 11 queries
