Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > BMW M5, M5 Touring, M6 and Z8 Forums > E63 BMW M6 Forum and BMW M6 Convertible | m6board.com
Old 8th October 2009, 00:14   #1
RavineSpeed
RavineSpeed's Avatar
Garage: 2006 M6 Black Saphire
Flat Tire Indicator--WTF
I was driving along in my '06 M6 yesterday (Chicago, cold and rainy weather, tires have 11K miles on them) and the red flat tire indicator came on, and the nav screen instructed me to stop, consult my owner's manual and change the tire immediately. Well, I immediately got off the interstate, drove into a gas station (in a questionable area), inspected the tires (couldn't see any flats, didn't know which one was the problem), put some air in each of them and drove about 15 miles to the nearest BMW dealer.
The indicator light subsequently went off while I was on my way to the BMW place, the tech looked at me like I was nuts, they checked the pressure and said all was good and sent me on my way.
Why on earth would this happen? I was about ready to do the whole tire fix procedure in the manual (5 pages long), but I risked it due to my location, the lousey weather, and the fact I couldn't tell which one was "flat" and just crossed my fingers.
Has this happened to anyone out there?
Now I'm worried I have a slow leak and the damn thing will go flat on me when I'm not 15 miles from a BMW place.
RavineSpeed is offline
Old 8th October 2009, 03:53   #2
Pio
Pio's Avatar
Garage: 2008 M6 - Alpine White
The only issue my M6 has had is with the TPM system. When it was brand new before I put 100 miles on it, the TPM Malfunction warning came on and they couldn't figure out why. It was intermittent for the first 1,000 miles, then it went away. It came back about a month or so ago, same thing, the tire pressures were fine but it still displayed TPM Malfunction. I took it to the dealer and its been fine since.
Pio
2008 AP M6 SMG (19" HRE C20's, Yellow Brembo's w/ Slotted Rotors , ASR exhaust & Intake)
Evosport Pulley & Headers NEXT!
2007 Black 750 Li
Notables no longer in the stable:
2001 M5 Dinan Stuff
2001 C5Z
2003 CL55
2005 C6
2006 C6Z (Sc'd 611 rwhp / 580 rwtq)
2003 C5Z (SC'd735 rwhp / 680 rwtq)
Pio is offline
Old 8th October 2009, 03:55   #3
dalmy
dalmy's Avatar
Garage: M6 Silver Gray
Bad tire pressure sensor? (on the assumption that the tire is fine)
Intermittent fault? (I hate those)
Shouldn't the fault be recorded in some detail (at least identifying the sensor that flagged the problem) displayed when the dealer connects the car to the all-powerful diagnostics computer?
Hope that helps,
DWA
dalmy is offline
Old 8th October 2009, 17:30   #4
Smokin Joe
Garage: 2007 M6 convertible - Black
This is surely a sensor problem. Usually it happens in colder weather. Has it been cool in Chi-town?
It happened to me last winter and I brought it right in to my dealer. While I was waiting, there were 2
other BMW owners with the same problem. Dealer said they had to change the sensor and that fixed it.
They must have had a bad batch because I found a few postings about this after it happened to me.
Smokin Joe is offline
Old 8th October 2009, 17:49   #5
RavineSpeed
Yes, it has gotten cold. The Tech seemed so cavalier about it, and none of the tires looked bad or seemed to have lost any pressure, so you're probably right, however, after they inspected it, he did not suggest doing anything about a faulty sensor.
This chaps my ***** though. These cars have gotten so technologically advanced that little things like a flat tire misread (again this was the FLAT TIRE WARNING, not low pressure) due to a 20 degree drop in temperature can freak us out and make us do all sorts of crazy things, like pull out the tire repair/reinflation system in the rain in a dangerous neighborhood for no reason.
I love the car, but I'd be really ticked off if I had gone through all the trouble and danger to fix something that wasn't broken becasue of a faulty $10.00 pressure sensor. I risked running on the rim to get to the BMW place to avoid the inconvenience and danger, and the whole time I was scared that I was rolling on a flat with limited control.
Sorry for the rant, but sometimes the technology just goes overboard.
Old 8th October 2009, 18:09   #6
MiamiSixer
MiamiSixer's Avatar
Garage: White M6
If you put air in the tires and it went away a tire was a few pounds low, that's all; you probably have a nail in it. Also I'd recommend everybody to make sure the TPMS nut is tight (on the valve touching the rim) that gave me a nice little headache...
MiamiSixer is offline
Old 8th October 2009, 18:43   #7
snowball
snowball's Avatar
Garage: '07 M6 Cab Black Sapphire
Ravinespeed, your car has a FTM which is different from the TPM that was put M6 starting with 2007. The FTM does not have pressure sensors, but uses the information from other systems on your M6 including the ABS system looking for rotational speeds vs. possible tire diameter change.
Same for the M5: Tire Pressure systems: FTM (MY2006) vs TPM (MY2007)
When you use the reset on your Nav screen you can tell. TPM (Tire Pressure Monitor -with pressure sensors inside each tire) says TPM and FTM (Flat tire monitor - no pressure sensors) says FTM .
From manual FTM and TPM:
snowball is offline
Old 8th October 2009, 19:11   #8
RavineSpeed
Snowball, thanks. Even without sensors, the system malfunctioned in some way, which is my point. Since there are no sensors on '06, temperature would be unlikely to have any effect, so I now have no idea why the warning light would go off...
Old 8th October 2009, 19:17   #9
snowball
snowball's Avatar
You mentioned this happened in rainy weather. If you were driving even a little aggressively (easy for us to do) and spinning tires, it would for sure, fool the system into thinking something was wrong, and a tire was changing diameter based on speed and tire rotation. Thus causing an alert.
snowball is offline
Old 16th October 2009, 00:58   #10
whatheheck
whatheheck's Avatar
Garage: 2006 M6 Indianapolis red
Sales Feedback: (3)
Excellent thought, and I agree.
Dan
Supersprint Headers, Tubi Rumore Plus exhaust, Dinan CAI, Defi Heads Up Display, Strong Strut front anti-sway bar, Powerchip 93 S/W, Euro Arm rest, Fikse Profil 5S Rims; Goodyear Eagle F1 GS-D3, Polk Audio Tweeters, Boston Acoustic Speakers, Integrated 60gig Video Ipod, HiDef DICE Radio iPod interface, Icelink, Rouge Engineering Short shifter, StopTech Big Brake Kit, TC Design rear sway bar brackets, HID 8000k fog lamps, 8000K low beams, Euro clear corner HID headlamps, Mark IV Nav, Lamin X films, Predator ICE LED AE, Valentine 1, M20 Blinder Anti Laser, TEC cup holder, All LED interior lights, LED footwell lights, LED trunk lights, Ultimate Cup Holders, Hella TC-400 Tire Pressure Monitor System, etc.
whatheheck is offline
Flat tire SoCalJD E39 M5 and E52 Z8 Discussion 12 15th March 2008 16:18
Flat tire SliverSled E60 M5 and E61 M5 Touring Discussion 4 16th May 2006 19:21
WTF new rear wheel /tire dark knight E39 M5 and E52 Z8 Discussion 1 23rd May 2003 01:41
Tire Pressure Indicator Steve Beswick E39 M5 and E52 Z8 Discussion 2 1st December 2001 19:12
Tire Pressure Indicator Steve Beswick E39 M5 and E52 Z8 Discussion 2 1st December 2001 06:42
Page generated in 0.15669 seconds with 11 queries
