Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > BMW M5, M5 Touring, M6 and Z8 Forums > E63 BMW M6 Forum and BMW M6 Convertible | m6board.com
Old 29th September 2009, 01:23   #11
M6SCSMD
M6SCSMD's Avatar
Garage: 2008 M6 Alpine White Black Interior with Carbon Fiber
Originally Posted by ibmw m6 View Post
let me explain my thought to do both...there are plenty of Dinan cars around, and plenty of twin turbo m6. But how many have you heard do both. I want to have a bad machine, even if it is just short lived. But I also want it to be daily driveable. Have any of you heard how reliable both of these kits are?
I have over 1700 miles on my new engine and have not had one problem. It is still great to drive daily, but when you jump on it, she becomes another kind of monster. I love the fact that Dinan is reliable and close for me. The ASR TT is a great option also, but I live North of the Mason Dixon line. As was stated before, there is always some else that has more mods and is faster. It is the arms race for cars.
Modifications: (Installed 06/09)
-Dinan High Flow Air Mass Assemblies
-Dinan Throttle Bodies
-Dinan Free Flow Exhaust
-Dinan 13% Underdrive Crankshaft Pulley Kit
-Dinan 5.7L Stroker Engine
-Passport 9500ci
M6SCSMD is offline
Old 29th September 2009, 02:53   #12
Riksut
Riksut's Avatar
Garage: M6 vert
I would get DINAN 5.7L stroker + ASR Nitrous kit. Should be a good combo.
Riksut is offline
Old 29th September 2009, 08:20   #13
ibmw m6
Garage: BMW M6 Cab
I spoke with Dinan today, they have only ever done 2 M6 cabrios and 1 is in Canada. I am going to do the whole s3 upgrade with brakes, and differ. I am still not sure of lowering springs.
I am also still thinking about a 150 shot of NOS.
We shall see!
ibmw m6 is offline
Old 29th September 2009, 16:48   #14
ASR Engineering
Company representatvie for ASR Engineering
ASR Engineering's Avatar
Garage: M5 Black
We currently do not have any of our Twin Turbo Packages on the street, since the two we are currently building in house are both Stage III's with built engine and take a bit longer than Stages I and II. As of right now, we have already completed about 95% of the hard parts needed for Stages I & II. That being said, it wouldn't take us very long to complete a Stage I or II at this point. Stage I will produce a minimum of 40% more hp over stock putting you @ 700flywheel hp. There would be no need to do both the Stroker and our TT since we have the capability to produce up to 1300whp with the Stage III, of course in my opinion the SMG will not be able to support that kind of power. Keep in mind that a stroker S85 is a completely different type of power than a TT S85, and at the end of the day it's all a matter of preference. Hopefully, this helps answer some of your questions!
ASR Engineering is offline
Old 29th September 2009, 21:41   #15
sheim911rs
Garage: 2009 M6 coupe, 6 spd, Black Saphire; 2007 & 2008 GT3RS (both Green); 1984 Ruf; 1973 Carrera RS
I have the dinan S2 package....perhaps not the ultimate, but I do find the suspension to be wonderful. Not too low in terms of driveways etc, but definitely more sporting in feel.
sheim911rs is offline
Old 30th September 2009, 06:29   #16
ibmw m6
Garage: BMW M6 Cab
no it makes me more confused, so I think I will call you tomorrow. or maybe email you.
ibmw m6 is offline
Old 30th September 2009, 07:24   #17
snowball
snowball's Avatar
Garage: '07 M6 Cab Black Sapphire
We shall see!
I think if you look carefully at Dinan's website there is no full Signature package of any kind for the convertible. While the coupe has S, S1, S2, & S3 Signature pacakages, there are several things in the suspension kits just not available for the convertible. You can get close, but not official.
snowball is offline
Old 30th September 2009, 08:01   #18
ibmw m6
Garage: BMW M6 Cab
Yes this is what was explained to me, however they do have some suspension options we are going to try, and they also talked about more power to be had in the near future.
I am also in the process of getting my wife an x6m, she can not decided on color or interior.
ibmw m6 is offline
Old 30th September 2009, 14:33   #19
M6SCSMD
M6SCSMD's Avatar
So, you would have to build your own transmission to withstand the (holy crap) 1300 bhp of the Stage III?
-Passport 9500ci
M6SCSMD is offline
Old 1st October 2009, 04:15   #20
Myke951
Myke951's Avatar
Garage: 944 Turbo White
Send a message via AIM to Myke951
SMG is not strong enough, thats for sure... It cant handle the torque and thats why alot of high tq/hp SMG builds have RCOG's
2004 Mini Cooper S: Alta supercharger 15% pulley upgrade, Dinan cold-air intake, Skunk2 header back exhaust, RMW CUSTOM TUNE, Alta oil catch can, OMP Strut brace, Eibach pro-kit springs, H-Sport camber links, 19mm Rear sway bar w/ adj. end links, 18 in. Breyton mini magics, 6lbs lighter crank pulley, polyeurathane tranny and engine bushings, wheel Studs, Wilwood BBK... More to come soon!
RIP=White 944 turbo: KKK K-27/6 turbo, upgraded intercooler, Lindsey Racing hardpipes, Autothority MAF, B&B exhaust with 4.5" oval tip, Siemens #55 fuel injectors, Lindsey Racing MaxHP custom Chip set, 3 bar fuel pressure regulator, Re-worked head and slightly overbored pistons, Spec Lightened 6 puck stage 3 clutch, Quaif torque biase differential, Apexi AVC Type-R Electronic boost controller, HKS type-1 turbo timer, Shimmed wastegate, Champion Motorsports adj. bypass valve, Weltmeister front and rear sway bars, Weltmeister strut tower brace, Koni adj. "yellows", unknown springs, Turbo Twist rims, Kumho Ecsta Supra tires... And a couple of more unknown mods...
Myke951 is offline
Ultimate ///M meet ///WALL_ST Regional Forums and Events and group meetings for M5, M6 and Alpina owners 2 3rd November 2007 01:47
-The ultimate M5?- Petey Pop E39 M5 and E52 Z8 Discussion 6 1st July 2004 07:39
for the ultimate fanatics KRM Off Topic Forum 0 8th June 2002 07:17
What is the Ultimate M car ? Black M5 E39 M5 and E52 Z8 Discussion 0 30th January 2002 21:21
The ultimate E34... ydelta E34 M5 Discussion 3 28th September 2001 00:19
Page generated in 0.16792 seconds with 11 queries
