Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > BMW M5, M5 Touring, M6 and Z8 Forums > E63 BMW M6 Forum and BMW M6 Convertible | m6board.com
Old 21st September 2009, 19:49   #1
Smokin Joe
Garage: 2007 M6 convertible - Black
What is the first sign of clutch slippage?
What is the first sign of clutch slippage or worn clutch?
Smokin Joe is offline
Old 21st September 2009, 21:39   #2
snowball
snowball's Avatar
Garage: '07 M6 Cab Black Sapphire
Your RPMs are higher than normal, and the car is moving slower than normal.
For example some basic clues are if you try to accelerate and the engine speeds up and then feels like the car is catching up with the engine or if you are climbing a hill and you can feel the clutch slipping. You can also tell if the clutch is slipping if you shift to a higher gear too soon and the engine accelerates but the car does not.
snowball is offline
Old 21st September 2009, 22:54   #3
whatheheck
whatheheck's Avatar
Garage: 2006 M6 Indianapolis red
Sales Feedback: (3)
That is absolutely correct.
You step on your gas, the engine revs to a higher RPM but the car is not going any faster = worn clutch.
The primary reason I went with SMG. M6 - 6 speed transmission and clutch I understand is weak.
Dan
Supersprint Headers, Tubi Rumore Plus exhaust, Dinan CAI, Defi Heads Up Display, Strong Strut front anti-sway bar, Powerchip 93 S/W, Euro Arm rest, Fikse Profil 5S Rims; Goodyear Eagle F1 GS-D3, Polk Audio Tweeters, Boston Acoustic Speakers, Integrated 60gig Video Ipod, HiDef DICE Radio iPod interface, Icelink, Rouge Engineering Short shifter, StopTech Big Brake Kit, TC Design rear sway bar brackets, HID 8000k fog lamps, 8000K low beams, Euro clear corner HID headlamps, Mark IV Nav, Lamin X films, Predator ICE LED AE, Valentine 1, M20 Blinder Anti Laser, TEC cup holder, All LED interior lights, LED footwell lights, LED trunk lights, Ultimate Cup Holders, Hella TC-400 Tire Pressure Monitor System, etc.
whatheheck is offline
Old 23rd September 2009, 19:01   #4
Smokin Joe
That may be it, but I can't pinpoint the problem. Is there any adjustment that can be made to the clutch?
The car seem a bit sluggish when first pulling out cold. I have to study the rpm versus speed.
Additionally, since getting her back from the dealer, there is a tapping and clacking noise from the valve cover on one side.
Any ideas?
Old 28th September 2009, 00:01   #5
M5 Roggan
M5 Roggan's Avatar
Garage: Silver Shadow 6 (M6 silver grey)
Regarding the clanking noise, that sounds like you could have a problem with your "Vanos", do a search in the forum and you wont be happy. It is a common problem among the few problems there are with these cars. I hope you are covered with warranty or insurance otherwise it could be costly if you want to get rid of the noise. Usually its just noise and dosen't cause any harm, but in some cases it can be bad and need fixing right away.
Normally you do not adjust the clutch on a modern car, if its gone its gone. I have heard about M5's SMG with clutch replacements after less then 50.000km so it can happen quite early if you have driven hard or had bad luck of buying a car that has been driven hard.
Any ideas?
M5 Roggan is offline
Old 28th September 2009, 21:23   #6
Fastoli
Fastoli's Avatar
Garage: 2007 M6 coupe White
the noise on the one bank is 4 weeks down time. make sure you like the loaner they give you. request they order the pump and the internal oil lines at the same time. you might be able to shave 1 good week.
I have been experiencing (in the morning when car is cold) some delay in the first gear as well. not slipping, but not gripping as quick and as soon as before.... the car has 17,000 miles.
Fastoli is offline
Old 29th September 2009, 20:33   #7
Smokin Joe
Fastoli...4 Weeks Wha wha whatttttt?
The loaners my dealer has are shitty 3 series.
I have to study this carefully. Your description sounds a bit like my problem. I feel like there is a slight loss of power and there is a noise near the passenger side valve cover. (usually at startup-cold) Additionally, there seems to be a wet spot on the black plastic cover. (see attached photo).
What do you think I am in for?
Old 1st October 2009, 19:17   #8
Smokin Joe
Any ideas here?
TIA
clutch slippage?? kindanutz E39 M5 and E52 Z8 Discussion 17 16th May 2008 03:02
Clutch Slippage???? BrianS E39 M5 and E52 Z8 Discussion 25 2nd November 2004 14:50
HELP! Clutch Slippage on my M5 GussM5 E39 M5 and E52 Z8 Discussion 25 7th April 2004 03:14
clutch slippage rebel1 E39 M5 and E52 Z8 Discussion 1 7th March 2004 23:09
Clutch Slippage.. BROKER E39 M5 and E52 Z8 Discussion 18 10th May 2001 22:38
Page generated in 0.14134 seconds with 12 queries
