5th September 2009, 06:19
#3
Are you sure it is the rear. There have been a couple lowered M5's who get the same clunking noise at low speed because of the front swaybar end droplinks. You may want to check that out. The only parts that could create that same noise in the areas you describe are the springs, swaybar, and connecting brackets related to swaybar. Hope this helps and please let us know what you find out.
T.C.
'01 Brushed Steel M5
front splitters
3.45 differential
'01 Silverstone M5- sold
SuperSprint:X-pipe
