Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > BMW M5, M5 Touring, M6 and Z8 Forums > E63 BMW M6 Forum and BMW M6 Convertible | m6board.com
Old 25th August 2009, 04:32   #1
waleed_wales
Garage: BMW M6 Indy red
My M6 is LEAKING!!
yes,, its leaking oil. I noticed few oil stains underneath the car and i never imagined it would be my bimmer's, as i also park my vette and camaro on the same spot. the leak underneath the front bumper, but when i opened the hood i noticed that its all over the place on the right side(right front wheel side). i also noticed that the oil is the rim and covering the tyre. i checked engine oil level in idrive and all seems ok. any idea whats going on ??
- 07 M6 indy red (black murino, piano black)
- 04 530D Si (my uk drive,,,, diesel hero)
- 06 Caddy escalade
- 91 Vette ( 0.510 Crower Cam, K&N intake, 10.5:1 comp ratio ROSS pistons + GM performance aluminum Heads+ too many stuff added long time ago i cant enen remember them)
- 2001 Camaro SS ( full exhaust system, camshaft(cant remember the figures but a proper choppy one) Fast intake, HP tuner ecu tune, short throw shifter, 90 mm TB, 4.10 gears, K&N intake filter, Nitto 555RII )
- 06 Nissan Altima ( my highway MPG legend)
-95 Mustang (351 stroked windsor, 750 King Demon Carb, fully prepped with 2 stage 220 hp nitrous, AC & stereo Delete,) ((RIP))
waleed_wales is offline
Old 25th August 2009, 17:35   #2
waleed_wales
any ideas????
Old 25th August 2009, 18:12   #3
Ngbrothers
Garage: M6
Since the M6 is an '07, I am assuming it is still under warranty?
Call your SA and get a flat bed.
Ngbrothers is offline
Old 25th August 2009, 18:49   #4
waleed_wales
well,, my warranty has expired few months ago,, but i am taking it to the dealer ASAP
Old 25th August 2009, 20:16   #5
Clyde
Clyde's Avatar
Garage: Sepang Bronze M6 Coupe
Originally Posted by waleed_wales View Post
...the leak underneath the front bumper, but when i opened the hood i noticed that its all over the place on the right side(right front wheel side). i also noticed that the oil is the rim and covering the tyre. i checked engine oil level in idrive and all seems ok. any idea whats going on ??
The oil filter housing is in the lower front right corner. Unlike the M5, the M6 has no access panel. The black plastic shield (the full width of the bumper) must be removed to access the oil filter housing.
Clyde is offline
Old 27th August 2009, 08:04   #6
toussi1
toussi1's Avatar
Garage: M6 2006
The only thing I can imagine is if the oil filter is not on TIGHT and sprayed some oil.
On a 2007 being such a new car, anthing else would be crazy.
Cars: M6 2006, Ferrari 360 \\ HID
toussi1 is offline
Old 28th August 2009, 06:22   #7
chaseatl
Garage: 2008 M5 Silverstone Metallic
Engine Oil Cooler
About 4 months ago I noticed my M6 was leaking oil. I took it to the dealer and was told that the engine oil cooler had been impacted. The engine oil cooler is directly behind the front bumper. I don't remember running over or hitting anything. I had to spend about $1200 for the new engine oil cooler and labor.
chaseatl is offline
Old 29th August 2009, 06:15   #8
ttm6
ttm6's Avatar
Garage: e63 m6 black
you got robbed.
i had the same thing twice and covered under warranty twice. the oil cooler the first time had a crack and the second time bad seals.
don't let them tell you you hit something, if that's the case your front spoiler would be toast. i have my car lowered and the oil cooler doesn't even come close to being touched. under the front spoiler there's a cover that protects your oil cooler so if that's intact you have nothing to worry about. mine did it at 35,000 miles and did it again at 78,000 miles. so you tell me, is it a driving skill or a factory defect.
any way good luck and don't let the dealer bend you over for a lube job.
take care.
TTM6
ttm6 is offline
Old 3rd September 2009, 15:23   #9
waleed_wales
ok,, just recieved a call from them,,, oil cooler busted u were right guys.
hopefully my car will be ready to run again on saturday
Old 4th September 2009, 18:48   #10
Weasel
Weasel's Avatar
Garage: M6 (Silver/Gray)
You gotta luv this forum. Very kind and knowledgeable/experienced folks on here.
Weasel is offline
Leaking Radiator toys r' us E28 M5 Discussion 4 2nd August 2006 07:16
Waterpump leaking? Mattkins99 E39 M5 and E52 Z8 Discussion 0 8th June 2006 10:26
Leaking Diff austen_m5 E39 M5 and E52 Z8 Discussion 2 24th April 2006 01:30
B8 Valve leaking Tinker ALPINABoard.com | BMW Alpina Discussion 4 9th July 2005 21:34
Help ! A/C condenser leaking... GeorgeK E34 M5 Discussion 5 1st May 2000 04:03
Page generated in 0.13878 seconds with 11 queries
