• Latest threads
    • Custom feed
      • Updates
        Old 23rd February 2008, 01:35   #1 (permalink)
        mspeed
        2008 Headlight Install
        Has anyone done this yet? Any instructions on how to remove the front bumper?
        I ordered the headlights from
        http://www.trademotion.com/partlocat...catalogid=4462
        However they did not include the top turn signal part
        mspeed is offline
        Old 23rd February 2008, 05:10   #2 (permalink)
        Cosmos
        Cosmos's Avatar
        WHAT!!??? How could that be, I thought it was all one piece?
        please post a pic of what you got.
        "Motion does not equal progress"...Cos
        Cosmos is offline
        Old 24th February 2008, 06:07   #3 (permalink)
        DoctaM3
        DoctaM3's Avatar
        This must have been an error.. it is 2 piece but they should come together, I am pretty sure.
        DoctaM3 is offline
        Old 24th February 2008, 06:22   #4 (permalink)
        Audioguy
        Audioguy's Avatar
        Cant speak on the headlights, but as for the turn signals above, its not exactly non-invasive.... You've got to remove the top fender bolts in the drip rail and pry the fender away from the chassis in order to get the turn signals out. I'll assume after this is done, most of the headlight fasteners are exposed. Best of luck...
        -Arash
        2006 M6 Indianapolis Red / Sepang Bronze
        2004 SL55 Brilliant Silver / Berry Red
        2000 M5 Carbon Black / Silverstone (Retired)
        - Iforged Aeros
        - Stoptech Reds
        - BB Tri-flo
        - 6000K
        - Rogue SSK
        Audioguy is offline
        Old 22nd March 2008, 01:27   #5 (permalink)
        dtm996c5
        dtm996c5's Avatar
        there are bunch of bolts on the top of the grill, looking at the front of the car (once you've poped the hood). two bolts under the grill between the opening for radiator & etc cooling grill. then there is three bolts along the edge of the fender liner. once these are all removed, just pull out the bumper on each end (near the line of the fender liner). then just slide out the bumper, and becareful with the front pdc plug on the left hand side and the headlight washer plumbing on the right hand side. good luck.
        dtm996c5 is offline
        Old 22nd March 2008, 01:27   #6 (permalink)
        dtm996c5
        dtm996c5's Avatar
        and
        dtm996c5 is offline
        Old 22nd March 2008, 01:27   #7 (permalink)
        dtm996c5
        dtm996c5's Avatar
        yes the headlight and the corner lights are two separate parts and two separate orders.
        dtm996c5 is offline
        Old 25th March 2008, 03:14   #8 (permalink)
        holmesmd
        holmesmd's Avatar
        Send a message via AIM to holmesmd
        What is the part # for the LED front turn signals and how much are they?
        holmesmd is offline
        Old 25th March 2008, 10:58   #9 (permalink)
        dtm996c5
        dtm996c5's Avatar
        if you've read the notation, which indicates that led corner, alc, and etc. are not included and must be ordered separately. BTW how's the headlight installation coming along? as to the led corner lamp part numbers, i will be getting soon. will let you know.
        dtm996c5 is offline
        Forum Jump
