20th February 2008, 04:08
#1 (permalink)
Vorsteiner Trunk QUESTION: Anyone w/GPS or SAT Problems Out there!
Have the Vorsteiner trunk but now the GPS is consistantly WAY off and SAT does not work...unless (in both the GPS and SAT case) the trunk is openned...almost like the trunk is blocking the signal to the GPS in the trunk. Local dealer (Crevier BMW) has tried everything and states the problem is caused by the trunk! I want to know if anyone can help!
20th February 2008, 07:17
#2 (permalink)
Since antennas for these functions are mounted to the underside of the truck lid, it is very likely they were improperly installed when transferred to the carbon trunk lid. My guess is they were mounted upside down, causing the receiver to face toward the ground when the trunk is closed resulting in a nule signal.
This would fall in line with your symptoms, as once the trunk is opened there is enough of an angle for them to acquire a signal.
I would check the orientation of the antennas to assure they are properly mounted.
-Audio
2006 M6 Indianapolis Red / Sepang Bronze
2004 SL55 Brilliant Silver / Berry Red
2000 M5 Carbon Black / Silverstone (Retired)
- Iforged Aeros
- Stoptech Reds
- BB Tri-flo
- 6000K
- Rogue SSK
20th February 2008, 09:57
#3 (permalink)
-Audio
I thought about that and as such I took the two modules and flipped them with the metal-side up and reinstalled them but at no avail! I have not swapped them back and forth, putting left on the right and vice-versa. Anyone know more about which module is which an dthe oriegntation of each, I could really use that!? Any other info would be helpful as well!
22nd April 2008, 00:25
#4 (permalink)
Any update on this?
23rd April 2008, 20:41
#5 (permalink)
My sat radio stopped working after the bootlid was instaled
Vorsteiner CF Hood
Vorsteiner CF Boot Lid
ACS CF Flipper
ACS CF Diffusor
Charcoal Filter Remove
Meisterschaft GT2 (SIICK)
Meisterschaft Section 1
NEEZ EuroCross Super
KW Coilovers
http://gthaus.com/main.php
For the latest talk about Mfest pls click here Mfest forum
23rd April 2008, 21:09
#6 (permalink)
oh man... that's not good
quote=Powerbeast;1313088]My sat radio stopped working after the bootlid was instaled[/quote]
23rd April 2008, 21:28
#7 (permalink)
I know, I want to take it to the dealer but I know there gonna say you changed your trunk out.
Vorsteiner CF Hood
ACS CF Flipper
ACS CF Diffusor
KW Coilovers
24th April 2008, 02:29
#8 (permalink)
drop me a line and I can share potential fix...as I had to deal with similar issues!
24th April 2008, 06:39
#9 (permalink)
this is what is preventing me from getting the bootlid although i love it
2005 Lotus Elise (track rat! - Ohlins coilovers, Larini SE exhaust, CF side scoops)
2005 E46 M3 (Sold!!! but not forgotten)
2004 Range Rover HSE (gf drives it)
2006 E350 MB (got it for my mama)
1989 E30 (R.I.P.)
M6!!! selling parts:
- Eibach springs
- RPI ram air intakes (Sold)
- BMC filters
- charcoal filter delete
- Vorsteiner lip ($1000)
- Eisenmann Race exhaust ($1800)
- SS X-pipes ($700)
- Angel Eye LED Bright Star upgrade
- Aicona 20's powdercoated black ($4000)
- CF roundels
- CF grills ($300)
- CF lower steering wheel ($200)
(if out of state, you cover shipping)
24th April 2008, 08:38
#10 (permalink)
Compamy Representative for 503 Motoring
Don't worry guys I had the same problem and it is because of the carbon fiber The signals can only partially pass through and it causes distortion. I moved my units underneath the rear package tray, there is plenty of room under there and it works perfect. All you have to do is split the wire loom in-the trunk and run them into the package tray. Took my stereo guy about 1 hour to do the conversion.
Whats your story? Find out at www.503motoring.com
Also check out our work at www.myspace.com/503motoring
Please feel free to call me with any inquiries or questions 503.469.9821 M-F 8:30-5:30 Pacific Time
Tim Walbridge
CEO
503 Motoring
