• Latest threads
    • Custom feed
      • Updates
        Old 19th August 2007, 18:30   #1 (permalink)
        ajcut7
        ajcut7's Avatar
        Send a message via AIM to ajcut7
        What is your Tire Pressure?
        I had low air in one of my tires yesterday and was curious what psi you guys keep your tires at? My rear tires were at 35psi as they were from the factory, this is for everyday driving, not for track use.
        ajcut7 is offline
        Old 19th August 2007, 20:04   #2 (permalink)
        ///M6 HAMANN
        ///M6 HAMANN's Avatar
        my front tire is 40psi
        and rear 35psi and i got Ps2 Tires
        06 BMW ///M6
        -HAMANN headers
        -EVOTech ECU upgrade
        -HAMANN Rear exhaust "Racing"
        -Super sprint X-pipe
        -Evosport Pulley
        -itg Air Filter changed to (( BMC ))
        -HAMANN Body kit
        -HAMANN 21'' Wheels
        -Angel iBrights Ver.2
        http://www.q6r.com/up/uploads/2048b31ace.jpg
        ///M6 HAMANN is offline
        Old 20th August 2007, 00:53   #3 (permalink)
        RussRamz
        RussRamz's Avatar
        Send a message via ICQ to RussRamz
        The only reliable way to determine tire pressures is to use a thermocouple thermometer to read tire temps and then adjust pressure. Using the manufacturer's recommendation is fine if you are not going to track your car.
        "Quitters never win, winners never quit. But those who never win and never quit are idiots."
        RussRamz is offline
        Old 20th August 2007, 02:20   #4 (permalink)
        Demon_M6
        Demon_M6's Avatar
        I set all the tires at 30PSI, Low but the car rides comfortable than any higher
        pressure. any down side to this other than gas mileage?
        Demon_M6 is offline
        Old 20th August 2007, 02:56   #5 (permalink)
        Wayward
        Wayward's Avatar
        Demon,
        I won't recommend here (you should do whatever provides the most confidence), but I will say that I run my pressures a few PSI higher for the oem Contis. 33/36 is the full load max recomendation. Personally, for normal driving, I run at 2 under all around.
        Wayward is offline
        Old 20th August 2007, 08:11   #6 (permalink)
        RussRamz
        RussRamz's Avatar
        For my high speed runs, I ran the tire pressure at the maximum recommended pressure in the owner's manual. For the track, I run at 2 psi under. I don't have a thermocouple thermometer, but have seriously considered it.
        RussRamz is offline
        Old 20th August 2007, 14:16   #7 (permalink)
        Demon_M6
        Demon_M6's Avatar
        Originally Posted by Wayward View Post
        Demon,
        Thanks wayward but why 2 psi below? My HRE's are a week away with PS2's 20" what do u guys recommend? Sent from my iPhone
        Demon_M6 is offline
        Old 20th August 2007, 19:58   #8 (permalink)
        deknight
        deknight's Avatar
        It depends on your setup or what you want your set up to be. Since the car is already set up for understeer stock, I set mine at 37 in the rear and 34 in front to offset that and get a more neutral set up. If my car was neutral already I would set equal pressure all around.
        deknight
        2007 Nurburgring Blue M6 Full Black Int, carbon fiber, HUD, Ipod inter., charcoal filters out, BMC filters,
        Comfort Access, Eisenmann Race exhaust, Evosport 3.91 2 clutch LSD, Vorsteiner Carbon Fiber hood,
        HRE 545r 20" wheels, Evosport Pulley, Hartge springs, 20 mm HR frnt spacrs
        Dinan Front Roll control, Dinan rear sway, Dinan Camber 650i Camber plate, Evosport Headers.and Section 1 high flow cats,
        RPI Ram Air, Evosport Stage 2 S/W, AC Schnitzer rear wing & front splitters, Hamann apron.
        2007 Alpine White Z4 M Coupe, Supersprint Sport Exhaust & X-pipe, H&R Springs, Hamann Strut Tower Brace, APR GTC 200 Rear Wing & Front Canards.
        2002 blue water M5- Gone but not forgotten!!
        Dinan Exhaust, Dinan Flywheel, Dinan Stage 2 software
        Supersprint x-pipe, AA CAI, short shift kit , Dinan Stage 3 Koni suspension.
        deknight is offline
        Old 20th August 2007, 21:17   #9 (permalink)
        Demon_M6
        Demon_M6's Avatar
        Sorry I don't mean to hijack the thread
        But I got H&R Springs so the car is even leveled front and rear
        33 or 35 all around?
        Demon_M6 is offline
        Old 20th August 2007, 23:12   #10 (permalink)
        Wayward
        Wayward's Avatar
        One of the best things you can do would be to experiment with different setups, whether working to counter understeer as dek said, or simply to find your preferred balance between comfort and handling.
        Among the best ways to do this on the road is to experiment with a stretch of road that you're familiar with. You could run one setup for a few days try another for a few days. As unscientific as this sounds, it should benefit. Be sure to keep as many variables (damper, dsc, shift settings, etc.) the same during your runs.
        Wayward is offline
        Old 20th August 2007, 23:32   #11 (permalink)
        deknight
        deknight's Avatar
        If the temperatures out there are really hot like high 90's to 100 F then go with 33. It is funny I set cold tire pressure at 34 in front 37 in the rear. When I got back from a weeks vacation and got back in the car my TPM told me I had low pressure in my tires. When I checked them every tire was exactly 3 psi lower. I was also alot cooler that day it got to 60 F in the morning when usually it has been around 77 F. No air leaked out it was just so much cooler that I lost 3 psi.
        deknight
        deknight is offline
        Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post! Add this post to your Facebook Profile
