• Latest threads
    • Custom feed
      • Updates
        Old 18th August 2007, 19:45   #1 (permalink)
        jbizzy21
        jbizzy21's Avatar
        Modified M6 spinning tires in 3rd gear?
        in my m6, i have the supersprint headers/x-pipe, eisenmann race exhaust, and AA ecu...i also have on some michelin ps2's, which i was under the impression are good tires...however, ive found that if i am in 3rd gear, dsc off s6 and i punched it, though i obviously start moving very quickly, i can feel my tires spinning underneath the car all the way through 3rd, into 4th gear...it does it so much that i almost never change lanes when this goes on, as i dont feel completely comfortable about the level of traction im getting...my tires are not overly worn, so its not because i have balding tires...does anyone else have this problem, and if so what did you do to correct it?
        jbizzy21 is offline
        Old 18th August 2007, 19:57   #2 (permalink)
        holmesmd
        holmesmd's Avatar
        Send a message via AIM to holmesmd
        I would say that this is pretty expected given the mods. Any 500 hp + car that you stomp on should spin it's tires with the traction system off. Doing it through fourth suggests to me that you should modulate the throttle a bit more when you drive PS2's are almost unanimously the favored tires for this and any other M-Car for that matter. Try using M-Dynamic mode and stop flooring the car all the time. If your tires are not yet bald, they will be if you keep it up!
        holmesmd is offline
        Old 18th August 2007, 21:51   #3 (permalink)
        chiromikey
        on certain roads or just in some areas of the country it's not going to matter what tire you have, the roads just aren't conducive to great traction...vegas for example. in my area i can take some roads and get great traction while i can get on others and spin the tires at any speed under 60mph.
        on a side note, when you're done with the ps2's and want even better traction try the toyo t1r's. after dumping the ps2's i've discovered the t1r is an all around better tire at half the price! btw, i'm not alone in that opinion.
        chiromikey is offline
        Old 19th August 2007, 10:13   #4 (permalink)
        Wolverine
        Wolverine's Avatar
        Something sounds amiss to me.
        I would guess it's your road surface, or possibly tire inflation (too high) or maybe even alignment. No way the M6 should be breaking traction all the way up to 120 mph in 4th gear. Just not gonna happen on a reasonable road surface in a straight line with a 550 hp 3800 lb car. With the PS2's properly set-up, if you're breaking traction just at the shift point from 3rd to 4th, you're doing great.
        Of course if you're tweaking the steering a bit when you shift and getting the car a little sideways, then anything can happen...
        2006 E60 M5 Silverstone II/Silverstone/Aluminum, All Options, 35% tint, Aluminum Pedals, V1 Hardwired, Blinder Xtreme M40, Michelin PS2's on 20 inch BBS RS-GT's, Blizzak LM 22's on OEM 19 inch wheels, Straight Pipes/No Resonator, Charcoal Filters Removed, H&R Springs and Spacers, Dinan 3.91 Differential, Active Autowerks ECU, BMC Filters, RPI Air Intakes, Evosport Pulley.
        Wolverine is offline
        Old 19th August 2007, 17:13   #5 (permalink)
        lasorsa
        lasorsa's Avatar
        I have the same problem, especially when merging into traffic on highway. When I have it in m mode mdm I also feel the rear end waiving back and forth like the computer is trying to adjust. Its a little scarry. When it first happend to me I took the car back to bmw and the rep took a ride with me and said I should be happy with it.
        2007 E60 M5 Black, Black,SMG
        K40 calibre with laser difuser
        Eismann Sport Ovals, Eismann X pipe,
        Dinan wheels with PS 2s
        Dinan stage two suspension
        Dinan carbon cross braces
        Dinan 3.91 Diff.
        Evosport pully.
        Dinan throttle bodies
        Gruppe M carbon cold air intake kit (FOR SALE)
        Dinan stage two software...or something
        RD Sport Headers with race cats
        ASR Engineering Stage Three
        lasorsa is offline
        Old 19th August 2007, 18:32   #6 (permalink)
        jbizzy21
        jbizzy21's Avatar
        see, the thing about what mine does, is that its not like im completely losing traction...im definitely still touching the road, and the back end isnt going out on me...think of it as almost somewhat hydroplanning on a road with no water...the roads that its happened on are generally open highways with good traction, sometimes even freshly paved roads...am thinking about switching the tires regardless(my buddy with a new 997T said these were the best)...the only problem is have is that i have 20 inch rims on, instead of 19's, and my guy at the shop was finding that a lot of tires (at least for track/street use) only go up to 19. i may try those toyos though.
        jbizzy21 is offline
        Old 19th August 2007, 22:07   #7 (permalink)
        cpiguy
        cpiguy's Avatar
        Hey Mike:
        I'm runing very simular mods on my M6 Cab. I noticed you mention straight pipes- no resonator. Are you saying the rest of your exhuast is stock. If so, what was the effect on the sound? Louder, deeper, etc???
        Thanks Dude
        cpiguy is offline
        Old 20th August 2007, 19:47   #8 (permalink)
        deknight
        deknight's Avatar
        Thanks for the tire tip. I am running Michelin Ps2 255.30.20 and 295.25.20. I was looking for a larger diameter to match the stock diameter but could not find anything. The toyo tr1 comes in 255.35.20 and 305.30.20 that will fit just fine on my Hre's.
        deknight
        2007 Nurburgring Blue M6 Full Black Int, carbon fiber, HUD, Ipod inter., charcoal filters out, BMC filters,
        Comfort Access, Eisenmann Race exhaust, Evosport 3.91 2 clutch LSD, Vorsteiner Carbon Fiber hood,
        HRE 545r 20" wheels, Evosport Pulley, Hartge springs, 20 mm HR frnt spacrs
        Dinan Front Roll control, Dinan rear sway, Dinan Camber 650i Camber plate, Evosport Headers.and Section 1 high flow cats,
        RPI Ram Air, Evosport Stage 2 S/W, AC Schnitzer rear wing & front splitters, Hamann apron.
        2007 Alpine White Z4 M Coupe, Supersprint Sport Exhaust & X-pipe, H&R Springs, Hamann Strut Tower Brace, APR GTC 200 Rear Wing & Front Canards.
        2002 blue water M5- Gone but not forgotten!!
        Dinan Exhaust, Dinan Flywheel, Dinan Stage 2 software
        Supersprint x-pipe, AA CAI, short shift kit , Dinan Stage 3 Koni suspension.
        deknight is offline
        Old 21st August 2007, 20:35   #9 (permalink)
        T Bone
        T Bone's Avatar
        Reality Check
        You guys are a bunch of whiners.....solving a problem that doesn't need to be solved.....
        Any Honda owner would give his left nut to spin his tires in 3rd gear
        J/K, mine spins all the time.
        "Aerodynamics are for people who cannot build engines"...... Enzo Ferrari
        T Bone is offline
        Old 21st August 2007, 22:46   #10 (permalink)
        MD318is
        Send a message via AIM to MD318is
        I think some of you are quite confused or I am VERY confused.
        You are only losing traction in third and as you switch gears to fourth, right? Your not losing traction through all of fourth, right? If your losing traction through all of fourth there is something very wrong as aforementioned.
        '08 135 vert
        '07 ILB M6 vert
        '06 F430 spyder
        '06 ILB M5
        '06 330i
        '05 LSB M3 vert
        '01 X5 4.4
        '96 328 vert
        '94 318 vert
        MD318is is offline
        Old 22nd August 2007, 03:58   #11 (permalink)
        jbizzy21
        jbizzy21's Avatar
        no, not through all of 4th, just 3rd. after the switch into 4th its perfectly fine, no traction issues at all.
        jbizzy21 is offline
        Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
