Don't completely rule out having a real problem. There is a service bulletin that may apply. Probably worth having it at least check out especially against a like 6er configuration (antenna mounted under trunk lid) at least. A second service bulletin does not appear to apply to you as it states your presets will go empty on you indicating other problems.
 | SI B 65 21 05
Sound System, Cruise, Alarms, Monitors | March 2007
Technical Service |
This Service Information bulletin supersedes S.I. 65 21 05
dated May 2006.
designates changes to this revision
SUBJECT
SIRIUS Satellite Radio Cuts Out in Certain Geographic Areas
MODEL
E63 (6 Series Coupe)
E64 (6 Series Convertible)
SITUATION
Some customers may complain that in certain geographic areas the SIRIUS Satellite radio cuts out up to 30 seconds at a time.
CAUSE
SDARS antenna module reception characteristics
CORRECTION
If possible, duplicate the condition together with the customer.
Compare the customer vehicle to a similar vehicle (6 Series) in the same area.
If the vehicles act differently:
- Check the antenna coax cable from the SDARS receiver to the SDARS antenna module
- If this is ok, check for a defective SDARS antenna module by parts substitution
- Only if the antenna from the known good vehicle improves the SIRIUS Satellite radio reception, install a new SDARS antenna module.
