Dixis Titanium Exhaust and H Pipe - BMW M5 Forum and M6 Forums
Old 22nd May 2007, 07:29   #1
NobleM400
Company Representative of RPI Power
NobleM400's Avatar
Garage: 06 BMW M5 Silver Gray Metallic
I just picked up the Dixis Titanium Exhaust and H pipe from an M5 Board member (thanks!).
The Dixis is 26.4 lbs. The band clamps (not included) are 1.1 lbs. The stock rubber hangers (reused) are 1.3 lbs. That's a total of 28.8 lbs. The stock exhaust is 79.8 lbs. That's a 51.0 lb difference between the Dixis and the stock system.
Here are some pictures. I'll take some video next. Unfortunately, I let the batteries run out on my HD camcorder.
Stock exhaust:
Stock neck-down:
Here's a look at the stock main cats attached to the headers, sometimes called the precats. They're metal matrix, but high cell-count:
Here are the main cats, sometimes called the secondary:
The first thing that had to be done is cutting the stock pipe. The pipe was cut, then the cut was smoothed, so that it doesn't impede exhaust flow.
Here's the Dixis titanium exhaust:
Close-up of the welds. With titanium, because it is so hard to bend, the shaper turns are welded, while the shallower ones are mandrel bent.
Single wall, flame treated dual tips, 80mm each:
Band clamps are used to connect the exhaust to the stock "section 1" pipes, since the diameters are exactly the same:
It uses an H pipe balancing tube instead of an X pipe:
Here's another look at the tips on the car:
Sound wise, the exhaust is quieter than I expected for such small mufflers, especially with titanium.
Idle is a little louder than stock, though it has a fuller presence. There's absolutely NO drone at all, which is AWESOME. I cannot stand resonance at all, especially with a luxury oriented vehicle.
With low throttle, it's close to stock volumes inside the car, though a bit louder outside. Cruising is comfortable and quiet.
With the mid-throttle, you definitely hear more of the exhaust, though not a lot.
With heavy throttle, or with the throttle completely buried, you can definitely hear the exhaust. There's a far better balance between the induction noise, engine noise, and the exhaust note. At high RPM's, there's a smooth, ramped up scream. Surprisingly, it's not raspy at all, despite the removal of the resonator. There's no crackle or tinny sounding buzz to the exhaust note at all, just a building crescendo to redline.
Overall, I love it. I like how it's reasonably quiet still, because that allows me to increase the noise with headers or high flow cats. If it's too loud to begin with, swapping cats will make it unbearably loud.
Gabe
Race Precision, Inc
Last edited by kees; 22nd May 2007 at 13:15. Reason: Added pictures as attachments
NobleM400 is offline   Reply With Quote
Old 22nd May 2007, 07:33   #2
///M Lifestyle
///M Lifestyle's Avatar
Garage: M6
video clips!!!
2008 Range Rover Sport (Sold)
2011 BMW 740i
///M Lifestyle is offline   Reply With Quote
Old 22nd May 2007, 10:40   #3
RKN
RKN's Avatar
Garage: M FUNF 06 IN.BLUE
a 51.0 lb difference is a lot ...nice exhaust system
nways installition duration?
RKN is offline   Reply With Quote
Old 22nd May 2007, 12:28   #4
dubaibmw
dubaibmw's Avatar
Garage: 2006 e60 m5 interlagos blue
nice one mate nice sound weight save all gotta be good
m5 in dubai
dubai Property specialist
deposit down and on the waiting list for the new m3
not delivered till next june
dubaibmw is offline   Reply With Quote
Old 22nd May 2007, 13:02   #5
gasterus
gasterus's Avatar
Garage: M6, Black/black
Nice exhaust and pictures! Prehaps some video clips......
07 M6 blk/blk
RDsport RS58 stroker with custom ECU tune
Decated stock headers, supersprint x-pipe, E-Race mufflers
Evosport Pulleys, BMC air filters, RPI air scoops & oilcooler
H&R springs, Dinan FRC & rear sway bar
20" Ac Schnitzer V with Yokos advans sport
Brembos 6-pot 405mm front+4-pot 380mm rear
08 E92 M3 S.Graphite/Red
gasterus is offline   Reply With Quote
Old 22nd May 2007, 13:52   #6
unfoundhorsepower
unfoundhorsepower's Avatar
Garage: 2006 M5-E60, Interlagos blue,all options + 2004 Z4 Red loaded,2004 M3 Luguna Seca Blue, 2009 X5 35d Saphire Black.
I like it !! Nice welds it looks of really good quality. thanks
See you all at the:
Mmmmm meet...in Massachusetts, It was good to see all of you !!
unfoundhorsepower is offline   Reply With Quote
Old 22nd May 2007, 18:01   #7
905RMP32V1x
905RMP32V1x's Avatar
Garage: M5, Indy Red
I appreciate all the picts. Looks great.
2006 Indy Red/Blk/Alum loaded,
H&R springs w spacers, 167(M6) wheels,
Dinan 3.91, Evo Pulley
CF grills, CF vents, ACS Spoiler
Vorsteiner CF Vented Hood, CF lower steering wheel
905R-driver
MP32-irons
ProV1x-ball
905RMP32V1x is offline   Reply With Quote
Old 22nd May 2007, 18:23   #8
ALTANertive
ALTANertive's Avatar
Garage: E60 M5 Silver Gray/Indianapolis Red/Aluminum
That is absolutely SIIIIICK!!!
Sound/vid clips or ban!
Oh, any reason you didn't add the section that replaces the 2ndary cats?
2006 BMW E60 M5 SG/IR/Al
ALTANertive is offline   Reply With Quote
Old 22nd May 2007, 18:29   #9
Laidback
Garage: Camaro lol:)
Sales Feedback: (25)
Very sweet exhaust...Hope to see those on our next Vegas Meet
"Illegitimus non carborundum"
Laidback is offline   Reply With Quote
Old 22nd May 2007, 20:30   #10
NobleM400
NobleM400's Avatar
Yeah, will definitely do the video in a day or two.
In terms of the Section 1, I didn't add it because I bought the Dixis exhaust rather unexpectedly.
Is Eisenmann the only one who makes the straight through Section 1?
