Old 1st May 2007, 10:56   #1
hexproject
hexproject's Avatar
Garage: AW 07 M5, HB 06 Cooper S JCW
need help for ipod interface
hi, trying to figure out what i need for the ipod interface.
This is what my glove looks like.
it's a 2007 m5..
any help would be great.
i went to the i-Drive, doesn't have a CDC options.
only, FM, AM, AUX, SAT, CD, WB
am i stuck with the dealer if i want ipod interface?
hexproject is offline
Old 1st May 2007, 14:34   #2
mcw331
mcw331's Avatar
Garage: 2006 BMW M5 Interlagos Blue
I'm not sure they pre ran the cable you need. On Andrew's 07 they didn't.
What you need is the loom with 2 green fiber optic cables and a brown and orange cable. On our 06's the X18180 connector was already on the end of the loom and connected to the CDC. See labeled pic attached.
Check that loom on the right in your pic. Does it contain a green fiber optic cable and the brown and orange cable? If so you can put the X18180 adapter on yourself (but MAY still need a reprogram). If it is not there... you are stuck with having the dealer run it.
Mike Williams
2006 M5 Interlagos/Portland Brown/Walnut Maderia -His
Full Leather/M Multifunction Seats/HUD/Sirius/Power Rear Sunshade
Wk 49 Build
50200 miles; awesome above 5500 RPM.
Valentine V1 Hardwire
Blinder Extreme M40
IPOD interface
IPOD Video Hardwire
2006 750Li Alpine White/Cream Beige - Hers
Premium/Sport/Rear Entertainment/Comfort Access/
mcw331 is offline
Old 1st May 2007, 14:45   #3
dimitri
Garage: 2006 m5 /white/indy red
did u have a cd changer?
also try this go this site http://www.bmwdiscountparts.com/ thats were i bought what i needed u can call them or email they will ask for your vin and tell u exactly what you need the only thing is if u never had a changer u might need to visit the dealer for them to program once u installed the module. But just so u know if u do a search here in the forum theres plenty of info ..my persoanl expierence that i had was i disconnected the changer and plugged in the module and within 10 minutes the ipod worked.
dimitri is offline
Old 1st May 2007, 20:02   #4
hexproject
hexproject's Avatar
hey, MCW 331, thanks for the help.
will see it tonight.. was reading some other directions, which one is in and which one is out for the optic fiber cable?
Old 1st May 2007, 21:32   #5
mcw331
mcw331's Avatar
I believe if you turn the power on the one which has "light" coming out of it goes to in. I didn't have to attach an adapter though.
mcw331 is offline
Old 1st May 2007, 23:02   #6
LarryWomack
LarryWomack's Avatar
Garage: E60 M5 Silver Gray
If you had a factory installed CD changer you'd likely have unplugged two connectors to get it out - One for power (which it appears we see in your photo) and the other for the MOST bus connection.
Remember not to stick anything other than the fiber optic cable into the MOST bus connector. Fiber optics are easily damaged.
2006 Silver Gray / Black Merino Full Leather / Walnut
Dinan S2 Suspension
Premier Paint Protective Film
V1 Hardwired
LarryWomack is offline
Experiences with Intravee II ipod interface? Osodog E39 M5 and E52 Z8 Discussion 38 21st October 2008 21:32
Ipod Intergrated + Interface (spec.dock) Mikebuzzsaw M5 E60 Group Buy Forum and Sponsor Discussion and Offerings 10 25th April 2007 04:03
iPod Interface Installed in '07 M5 andrewsherman E60 M5 and E61 M5 Touring Discussion 9 13th November 2006 14:38
So what's the deal with the ipod interface on MY '07? Gadgets E60 M5 and E61 M5 Touring Discussion 2 5th November 2006 06:44
iPod MOST Interface installed Questions Dr.Know E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 0 4th September 2006 18:46
Page generated in 0.11710 seconds with 12 queries
