M6 Kelleners / Schrick Cams, Active Autowerke CAM ECU, Supersprint X-Pipe & Mufflers - BMW M5 Forum and M6 Forums
Old 16th January 2007, 08:09   #1
KeithTa
KeithTa's Avatar
Garage: M6 Alpine White w/ Red Int.
Its been 2 FULL weeks since Active Autowerke started working on my M6.
Before I get started, I just wanted to direct anyone interested in my vehicle's cam progress to my previous thread that I started back on December 1st, 2006. This way, you guys can get an overview of the preparation I went through before Active started on my car. Here is the thread:
M5/M6 Kelleners Cams Arrived !!
Even though I asked Active to take photos of the install as it progressed, they were so focused on the job; they didn’t even end up of taking photographs at all! Sorry guys....no pictures!
Anyhow.....here are the latest updates on my car thus far:
Using the BMW instructions, the required special tool set, and replacement gaskets I provided, Active began breaking down the engine for the cam upgrade. Shortly after they started, they realized that I never provided them with the instructions for the vanos adjustments required to complete the install! So, they had to do some research and picked up the additional required documentation to continue the job.
The install moved along and the driver’s side cams were pulled and replaced without any issues. But when it came time to pull the final cam on the passenger side, for some reason, the special jig wouldn’t fit over the cam to remove it. Active spent two days between repair books and speaking to some of their contacts at BMW before they came to realize that the 4th cam on my car was never aligned correctly from the factory! Therefore, it couldn’t be removed with the special tools through conventional means.
Here was the email Karl from Active sent to me last week:
"...Scrappy and I are still here working on your car, we did the driver's side cams quite easily, but the passenger side is giving us a warm time. We were here on Tuesday night as well. We are taking our time to check, double check, triple check everything and that is why we are taking so long. The problem we encountered on the passenger side cams was the factory alignment of the exhaust camshaft was off, the jigs would not fit and after trying like 4 times we came to the conclusion that the vanos gears were never aligned properly from the very beginning. So here we are on Wednesday night making our own special tools to take apart the vanos cam helical gears to align them before installing. We are getting somewhere!!......"
GEEZE! This means my car was never running the way it should have been from the very instant I drove it off the lot!
After picking apart a number of dyno runs I located online, I noticed my stock DynoJet dyno pass at 422 to the wheel with the carbon air filters removed was about 10 whp lower than what most of the other M5s & M6s were putting down. Even my latest DynoJet pass at 459 WHP after the SS headers & cats w/ AA ECU seemed a bit off when compared to another M5 with the similar mods.
After discussing this issue over with Active last week on Friday, we figured we may very well see "higher than normal gains" from the cam upgrade since the last dyno pass was run with the incorrect stock cam timing.
So, I waited for the weekend to pass and called Active on Monday late afternoon to see how things were coming along. The car was back together and they were already working on the cam ECU tuning. They said my car put down 448 wheel horsepower on their Mustang dyno! For those of you who don’t know about Mustang dyno statistics, Mustang dyno numbers always show lower HP numbers than DynoJet dynos. If you take a look at my SS Headers/Cats thread at:
My M6 Active AutoWerke mods! [SuperSprint headers + cats & AA ECU]
You will see my best Mustang dyno run put down 410 hp to the wheels
The Mods on my car when the 410 hp was produced were:
Carbon air filters removed
Supersprint Headers
Supersprint Cats
AA Header/Cats ECU Tune
(Slightly compromised exhaust cam timing)
The Mods on my car when the 448 hp was produced were:
K & N stock filter replacement
Supersprint Headers
Supersprint Cats
AA Cam ECU Tune
3.91 Dinan Differential (doesn’t effect HP)
Schrick Kelleners cams
(Correct exhaust cam timing)
After my last conversation with Karl on Monday afternoon, he explained to me that my car was running a bit too lean in the midrange and that they are still working on getting the timing and fuel ratios perfect. In addition, they were also working on trying to figure out how to crack the code in the ECU to raise the rev limiter. According to the dyno sheets, Active is certain that if they can get the motor to spin a few hundred more RPM they will squeeze another 5-10 HP out of the car. Raising the rev limiter will cause the RPM on each up shift to fall into a higher more optimal power range when running through the gears under full throttle.
Once Active is done with the tuning on the Mustang dyno, they will run the car over to a DynoJet dyno near their shop and get a final HP number.
Cams and tuning complete…………NEXT...........the M6 goes back to Active immediately to get the Supersprint X-Pipe (with SS resonator) and the Supersprint Sport Mufflers installed. They may touch up the tuning some once the new exhaust components are installed. Lastly, one last trip back to the DynoJet for a Grand Finale pass.
** (Just to let you know, that since my M6's factory cam timing was off, the car was putting down approximately 12 less horsepower to the flywheel than normal. Therefore, my HP conversions were off when I calculated 50 flywheel hp for the Supersprint headers, cats and ECU. In reality, the M5/M6 e60/e63 will put down 40 additional flywheel HP with these upgrades.)
So all and all, my M6 upgrade components will consist of:
Supersprint Headers
Supersprint Cats
Superprint X-Pipe w/ SS Resonator
AA Cam ECU Tune
I am projecting a DynoJet final number of 490-505 HP to the wheel! With the correction factor applied for drive train loss, my car will be producing between 575 to 592 Flywheel HP!
Final results and initial driving reports coming soon! I will post all the dyno charts once Active is done with the car. Then I am off to the drag strip for some quarter mile runs!
Keith
KeithTa is offline   Reply With Quote
Old 16th January 2007, 10:38   #2
unfoundhorsepower
unfoundhorsepower's Avatar
Garage: 2006 M5-E60, Interlagos blue,all options + 2004 Z4 Red loaded,2004 M3 Luguna Seca Blue, 2009 X5 35d Saphire Black.
Nice, go for it....good luck
unfoundhorsepower is offline   Reply With Quote
Old 16th January 2007, 14:05   #3
Gustav
Administrator
Gustav's Avatar
Garage: BMW M3 DCT Sedan / Limousine
Brave man!
Google+ LinkedIn Facebook Flickr
My email gustav@gtboard.com m5board Member visiting Stockholm, Sweden? PM me to and I'll show you Stockholm! gtboard.com
Gustav is offline   Reply With Quote
Old 16th January 2007, 14:33   #4
6speed
6speed's Avatar
Garage: 1984 Escort GT (loaded)
Wow!!!
Please, please, please take video clips before x-pipe and mufflers. I would like to hear what the beast sounds like before these mods. I am considering the same mods (minus x-pipe and mufflers) but I do not want the thing to sound too obnoxious.
Cheers ///
6speed is offline   Reply With Quote
Old 16th January 2007, 16:24   #5
BostonRocket
BostonRocket's Avatar
Originally Posted by 6speed
Wow!!!
Cheers ///
I agree. Please, PLEASE, some media!!
'Rocket
BostonRocket is offline   Reply With Quote
Old 16th January 2007, 17:08   #6
Fast6
Garage: Red 1983 645
That is not good! Trusting their assessment, which you have every reason to, means that this technological masterpiece of an engine gets put together wrong?
Good luck, too!
'06 M Coupe #308 - Silver Gray/Sepang Brown Dark
E36 M3 gone
E24 645 gone
Fast6 is offline   Reply With Quote
Old 16th January 2007, 22:58   #7
orlandom5
Garage: 2006 m5 interlagos blue
very brave
orlandom5 is offline   Reply With Quote
Old 16th January 2007, 23:35   #8
Scooby M Cinco
Scooby M Cinco's Avatar
Garage: 2006 M5 Interlagos
Thanks for being a leader in this area. There may be some motors not put together correctly? That will be too bad for my lease return. Ha.
Scooby M Cinco
2006 M5 IB/Black driveway
2002 Porsche Targa traded
2000 S4 sold
1993 Cobra Mustang sold
Scooby M Cinco is offline   Reply With Quote
Old 16th January 2007, 23:40   #9
Gustav
Administrator
Gustav's Avatar
Kelleners Sport M5 in action:
M5 vs Z06
M5 vs 997 Turbo
M5 vs F430
M5 vs vs standard M5
M5 vs standard M5 again
Old 16th January 2007, 23:47   #10
Ashok Arora
Ashok Arora's Avatar
A fascinating project - it'll be interesting to see how reliable the car is after all that work.
All the best.
Ashok
next up.. 2013 F30 Alpina B3
http://www.m5board.com/vbulletin/e60...kend-hell.html
Ashok Arora is online now   Reply With Quote
My M6 Active AutoWerke mods! [SuperSprint headers + cats & AA ECU] KeithTa E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 79 24th January 2007 06:46
M5/M6 Active Autowerke mods - Supersprint headers & cats & AA ECU Dyno Results Videos KeithTa E60 M5 and E61 M5 Touring Discussion 7 9th September 2006 01:34
M6 with Supersprint Headers and ECU KeithTa E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 25 1st September 2006 19:27
RHD headers, kelleners cams, ecu remap. => 442bhp! :) Tin E39 M5 and E52 Z8 Discussion 68 25th August 2006 18:03
Active Autowerke M5 ECU Upgrade TOPSUPRA E60 M5 and E61 M5 Touring Discussion 312 24th May 2006 15:17
