Temporarily disable Bluetooth for private conversation? - BMW M5 Forum and M6 Forums
post #1 of 16 Old 4th January 2007, 01:28 PM Thread Starter
C_Stradale
C_Stradale's Avatar
Sometimes when there are others in my car, and I get an incoming call, or want to make an outgoing call, I do not want to broadcast the conversation over the handsfree system. This had proven to be embarrassing at times. I try to always remember to warn the caller that they're on speaker, and others are present, but sometimes I forget.
Is there a quick and easy way to temporarily disable the Bluetooth so I can use the Razr normally?
C_Stradale is offline
post #2 of 16 Old 4th January 2007, 01:55 PM
12Special
12Special's Avatar
I find the quickest way to do this is from the phone itself - there's a menu item to "Use handset" which disconnects the Bluetooth and switches to the handset.
Jim -
The 12th in a list of special cars:
2006 e60 M5 - Silver-Gray / Black / Walnut
All options except rear airbags
12Special is offline
post #3 of 16 Old 4th January 2007, 02:12 PM
Mitch
Mitch's Avatar
Great question C I have the same issue.
Mitch
'06 M5 Alpine White (Delivered 7/31/06)
'97 NSX-T red/black
'97 Valkyrie
Mitch is offline
post #4 of 16 Old 4th January 2007, 03:30 PM
andrewsherman
andrewsherman's Avatar
The easiest way is from the phone itself. Depending on your phone, you may be able to use a programable button to toggle the blutooth on and off. That feature exists on most blackberry models. You hit the button and it prompts you to confirm that you wand to disconnect bluetooth and continue the call. Switching back to bluetooth while on a call is not so easy as you have to wait for the phone to re-connect with the car and, as we know, this can take more than a minute.
The other alternative is to switch Bluetooth off through the iDrive, but I cannot confirm that this will not end your call.
2014 M5 Competition|Space Grey|Black Merino Full Leather|Anthracite Trim|Executive package|LED Lighting Package|Drivers's Assit Package|B&O Sound System|Bel STiR Plus 9500ci|IND Side Markers and Side Vents|Exhaustmeister|Pirelli Sottozero Serie II
Past Rides:'07 M5 Silver grey/Black(Nicely Modded)|'04 745Li Titanium Grey/Black|'01 740iL Titanim Silver/Black|'91 K1100RS|'88 K75S
andrewsherman is offline
post #5 of 16 Old 4th January 2007, 04:58 PM
azwdct
Interesting question and something I have struggled with. With both my old Motorola Rzr and my current LG phone, switching to handset works only temporarily--the call reverts back to bluetooth in a few seconds and is back on speaker. I have also found that if you are on a call and turn off the engine, the call stays active and the iDrive screen stays lit even long after I end the call. I have tried locking and unlocking the car, but the screen still stays on. The only way I have found to turn it off completely is by starting the car again, then turning it off.
azwdct is offline
post #6 of 16 Old 4th January 2007, 07:26 PM
LI-M5
LI-M5's Avatar
thats pretty acurate.. its sort of a pita.
2013 F10 M5
Apline White/Black/Black
LI-M5 is offline
post #7 of 16 Old 4th January 2007, 09:31 PM
unfoundhorsepower
unfoundhorsepower's Avatar
unfoundhorsepower is offline
post #8 of 16 Old 4th January 2007, 10:35 PM
Mitch
Mitch's Avatar
I'll just keep telling my passenger not to listen...it's easier.
Mitch
'97 NSX-T red/black
'97 Valkyrie
Mitch is offline
post #9 of 16 Old 4th January 2007, 11:36 PM Thread Starter
C_Stradale
C_Stradale's Avatar
Hmm, give phone command to Use Handset, eh?
That sounds reasonable, now if I can just find that on my Razr! Thanks guys!
post #10 of 16 Old 5th January 2007, 12:36 AM
NinthSwat
NinthSwat's Avatar
Turning on/off bluetooth is not really convenient solution.
Try next: once you have incoming/outgoing call, pickup and then press button that enables speakers of your phone, so voice is going over phone speakers and then press it again to return to phone internal silent speaker, and call returns back to cell instead of car speakers. That does the trick for 1 call.
On nokia phones that is upper right button (right above hangup), remember to do it once you already picked up the call.
www.m3life.com
NinthSwat is offline
Solution to issues with Bluetooth and WM5.0! (JetWare software) spatterso E60 M5 and E61 M5 Touring Discussion 51 20th April 2007 03:53 PM
BMW technical bulletin regarding Bluetooth issues cobradav E60 M5 and E61 M5 Touring Discussion 0 14th July 2006 03:17 AM
Playing music via Bluetooth iPod? sdietric E39 M5 and E52 Z8 Discussion 1 10th March 2006 02:45 PM
Anyone with access to a new ETK CD? CountZero E39 M5 and E52 Z8 Discussion 15 20th February 2003 01:32 AM
Confirmed - Bluetooth phone for MY03 andrewe E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 0 21st August 2002 03:32 PM
