The Aftermarket Suspension Thread - BMW M5 Forum and M6 Forums
Old 28th November 2006, 15:05   #1
AMG ETR
Garage: E46 M3 (HPF Stage 2 Turbo)
I know there area bunch of threads with suspension info and I have looked at them, but I would love some specific comparisions of the setups I am interested in purchasing if anyone has them! My goal is to lower the car (I really like the slammed look), but I do want to improve the handling (more specifically the body roll). I do not mind a little rougher ride, but I do mind rubbing on every little bump (keep in mind I have 20" ACS Wheels).
Setup 1:
RD Sport Lowering Springs and Sway Bars (Front and Rear)
Price: $1450+Shipping/Install
Setup 2:
Dinan Stage 2 Suspension: Lowering Springs, Bump Stops, Rear Sway Bar, Front Roll Control System
Price: $872.50 +Shipping/Install
(Does anyone know if a stage 3 suspension is going to be coming??)
Setup 3:
H&R/Eibach Lowering Springs
Price: ~$300-350 +Shipping/Instal
Those are the three setups I am considering, fell free to add another if you feel it is better and please tell me about it!!
Thanks guys,
Evan
2006 BMW M3 (Comp Pkg./No Sunroof or Power Seats!)
HPF Stage 2.5 = 670RWHP (Race Gas + Meth) // 615RWHP (Pump Gas + Meth)
Sponsored By: SERIOUS AUTOSPORT (www.seriousautosport.com)
2007 BMW M5 (6speed) (SOLD!)
**ASR Engineering Stage 3 (700BHP)**
AMG ETR is offline   Reply With Quote
Old 28th November 2006, 15:40   #2
MRichmond
MRichmond's Avatar
Garage: 2006 M5 Silver Grey/Silverstone/Madeira Walnut
If your goal is the "slammed" look and don't mind a harsher ride, options 1 or 3 should be your frontrunners since the Dinan system does not lower the car as much as H&R (and, I believe, RD).
2006 M5 Silver Gray/Silverstone/Madeira Walnut
Dinan Stage 2 Suspension System
Supersprint Race exhaust with X-pipe
1998 M3 Coupe Technoviolet #315 IP/GTS3
JRZ RS, Bimmerworld cage, Racetech halo seat, GC sway bars, control arms, AA headers and 3" race exhaust (loud and proud), etc., etc., etc. . . .
MRichmond is offline   Reply With Quote
Old 28th November 2006, 16:13   #3
bonehead
bonehead's Avatar
Garage: Somethin' German
Sales Feedback: (7)
Rubbing shouldn't be a problem with any of your choices as long as you stay with stock widths. As a few RAC owners have demonstrated, problems arise not with 20 in diameter wheels (with or without lowering) but with wider rubber (305's in the rear). Not even sure ACS wheels can accomodate this fitment so the issue may be moot.
Boner
bonehead is offline   Reply With Quote
Old 28th November 2006, 16:24   #4
EBuyuk
EBuyuk's Avatar
Garage: 2004 Range Rover, 2006 M5
I have the RD Sport. And I decided to put the Dinan front roll control system and the rear anti roll bar. So that could be an option for you as well. And that would cost you $679 + shipping/install (and install should only be 5 hours maximum)
Member Cerberos has the H&R springs with the Dinan front roll control system and the rear anti roll bar. That could also me a option for you. It is easy to mix and match
The price for the Dinan front roll control system and the rear anti roll bar is $179. And the labor is 1.75 hours.
Ben from Wheels Boutique had the RD Sport 21" wheels with the RD Sport springs and he had told me that he had no rubbing issues. Just an FYI.
EBuyuk is offline   Reply With Quote
Old 28th November 2006, 16:38   #5
Wolverine
Wolverine's Avatar
Garage: BMW E60 M5 Silverstone II/Silverstone/Aluminum
I went with the H&R springs AND spacers. This gives the best look, handling, and ride combination IMO. The ride is slightly stiffer than stock, but by no means objectionable. In fact, I've received several compliments on the ride. The springs definitely lower the car significantly, combined with the spacers, the look is by far the best. The spacers improve the handling, without the disadvantages (heavier, slower, more prone to hydroplaning) of wider tires.
You may need to make a very slight modification (about $100) to the rear wheel well to avoid rubbing with a fully loaded car though.
Wolverine is offline   Reply With Quote
Old 28th November 2006, 17:21   #6
AMG ETR
That sounds like my ideal setup as it will give me the slammed look and the roll control of the Dinan components! Are you and your car in Palm Beach, or out of the country? I live in Downtown West Palm and would love to check out your setup before ordering if possible! If not, please let me know what you think of the setup in a bit more detail!
Did the Dinan components make a huge difference in addition to the springs?
What exactly is the Dinan Front Control system? Just want to be able to let my installer know exactly what it is he will be installing (not a Dinan dealer).
Also did you do anything with the bump stops??
Evan
Old 28th November 2006, 17:23   #7
AMG ETR
The ACS wheels I installed actually have spacers and look great! The fronts are 8" and rears are 10" with 20mm spacers up front and 10mm spacers in the rear! Saved over 22lbs of unsprung weight over the stock 19's with this setup (Crazy going from 19s>20's and saving weight ).
Evan
Old 28th November 2006, 17:26   #8
MRichmond
MRichmond's Avatar
Evan
It may be worth a call to Dinan before you mix and match their parts since Dinan developed its system as a system and mixing with other manufacturers' parts may produce unintended results. I have no reason to believe that this would be the case, but it is worth investigating.
Old 28th November 2006, 17:39   #9
AMG ETR
I do agree and that is why I am looking for his opinion since he has done it. However, sway bars and the roll control shouldn't be effected by the springs... The only thing I am worrying about is the bumpstops as Dinan uses new ones and I do not believe RDSport does...
Evan
Old 28th November 2006, 17:41   #10
EBuyuk
EBuyuk's Avatar
AMG ETR - I haven't gotten the Dinan installed yet but I am going to do them sometime next week. I am thinking about ordering them this week. My car is at Braman currently as I am waiting for them to get the second dinan differential. There were noises coming out of the first one. So hopefully I will have my car by the end of next week ready. But would love to get together once I get my car back.
Just so you know, I don't have bump stops from Dinan.
Aftermarket air suspension? recentrisk E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 1 1st August 2006 01:04
Recommendations for aftermarket coilover suspension? Bilstein? ATLANTA M5 E39 M5 and E52 Z8 Discussion 13 17th July 2006 09:01
need feedback from owners with Dinan Stage III suspension olis1 E39 M5 and E52 Z8 Discussion 11 26th May 2006 00:27
Press Release 4: The suspension of the M5: Ensuring a high degree of agility Gustav E60 M5 and E61 M5 Touring Discussion 0 4th July 2004 21:03
Insuring aftermarket parts tfung E39 M5 and E52 Z8 Discussion 3 11th November 2001 00:30
