Stock M5 rainy day dyno results - BMW M5 Forum and M6 Forums
Old 28th October 2006, 20:26   #1
multiowner
multiowner's Avatar
Garage: 2009 MB Cl63 Artic White
Getting ready to do the rear differentials so I decided to get the beast dyno'ed. Found a great shop in Staten Island. Ripp Modifications. Two regular guys, Ross and Perry. Have alot of knowledge between them. New Dynamics Dynamometer can do both rear and all wheel drive.
Was able to do 2 runs, before trans got yellow cog and had to cool down,
1st run cold 419.8 whp w/ 319 ftlb torque
2nd run hot 432.4 whp w/ 329 ftllb torque
Very happy with results, car completely stock with charcoal filters removed.
Was in 4th gear 500 w dcs off ( programed w/ m button) will scan and post Monday with air chart.
2009 MB CL63 Artic White Cashmere
2006 M5 Sapphirre BlacK/BlacK Traded 4/09
2007 MB SL550 Iridium Silver/Ash Traded 4/09
2008 335xi Alpine/Beige
2005 Porsche Cayenne S Gray/Black
multiowner is offline   Reply With Quote
Old 28th October 2006, 20:31   #2
darren_dallas
darren_dallas's Avatar
Garage: 2008 M5 Interlagos Blau
Multiowner,
I've not seen too many dyno sheets on the M5 (have been looking for some myself) so I appreciate you sharing your results.
I am concerned though at how low the rwhp numbers turned out. Rwtq numbers seem like they may be in line with what to expect, but 319 and 332 rwhp are low. Are you sure you don't mean 419 and 432? That would be more appropriate.
Thank you,
Darren
2011 X5M Carbon Black
darren_dallas is offline   Reply With Quote
Old 28th October 2006, 20:35   #3
chrisn
Garage: 2006 E60 M5 (Silverstone II)
Umm, did you swap the "4" for a "3" in those numbers?
Should be around 420-425 RWHP with filters out
chrisn is offline   Reply With Quote
Old 28th October 2006, 20:35   #4
Sprocket
Sprocket's Avatar
Garage: Black Sap
If you go back and do your runs in 6th gear (1:1 drive ratio) you will see about 100 hp improvement at the wheels. The car should be making about 410-450 rwhp.
Sprocket is offline   Reply With Quote
Old 28th October 2006, 21:34   #5
Wolverine
Wolverine's Avatar
Garage: BMW E60 M5 Silverstone II/Silverstone/Aluminum
Actually, you're much better off doing the runs with the new differential. You should be able to run the car in 6th gear (1:1) without exceeding the maximum speed of the dyno.
With the existing differential, the HP peak of the M5 at 7750 rpm in 6th gear is at a speed of 165 mph. This is above the max speed of most dynos. However, if you use the 3.91 differential, 7750 in 6th gear occurs at 152 mph. Most dynos can go up to 150, so you'll get a much more accurate run in 6th gear with the new differential.
Wolverine is offline   Reply With Quote
Old 28th October 2006, 22:11   #6
JamesInLV
JamesInLV's Avatar
Garage: E60 M5 - Interlagos Blue/Black/Aluminum
1st run cold 319.8 whp w/ 319 ftlb torque
2nd run hot 332.4 whp w/ 329 ftllb torque
Like was said otherwise, those WHP numbers should be 419 and 432, or perhaps they were drastically reduced by running in 4th gear (not likely). My dyno run, w/out charcoal filters was 431.2hp and 317.5 ftlb of torque. That 329 ftlb number sounds great, but it was also done in 4th gear. Stock, your dyno run should be done in 5th gear, since you can't run 6th gear to redline without hitting the speed limiter. To run a decent before & after, you should do a dyno run in 5th gear once you get the new differential, and then do another run in 6th gear (as said, that's the closest 1:1 ratio) to get the most accurate dyno numbers on your car to take away with you. I know dyno time costs money, so whatever you do will be great.
James
Las Vegas, Nevada
Now driving my 1999 Toyota Landcruiser again.
Wife gets the 2007 Honda Odyssey.
Looking forward to my next M5.
2006 ///M5 SOLD :-(
2002 325i SOLD
1987 325i Conv. SOLD
www.LVHomeResource.com
JamesInLV is offline   Reply With Quote
Old 29th October 2006, 01:09   #7
multiowner
multiowner's Avatar
Sorry All
Corrected the results.
Cold 419.8 whp 319 ftlb
Hot 432.4 whp 329 ftlb
4th gear 500/dcs off
Old 29th October 2006, 15:49   #8
FikseGTS
Garage: ACR,GT-R
can you post the dyno graph?
FikseGTS is offline   Reply With Quote
Old 1st November 2006, 18:12   #9
AUDIRS6
Garage: 2006 BMW M5 Black/Black
Right on the money. 15% drivetrain loss. is 425 whp and 325 wtq. So all the power is there.
AUDIRS6 is offline   Reply With Quote
Old 1st November 2006, 18:28   #10
IloveM5s
Garage: hotwheels
Should be more like 12%, but I'm splitting hairs.
IloveM5s is offline   Reply With Quote
Wooo tfung gone off deep end... EBMCS03 Off Topic Forum 4504 25th April 2011 22:04
How many of you guys, read GUSTAV's article on his DINAN visit/tour............ FAST 5 E39 M5 and E52 Z8 Discussion 21 16th June 2008 17:40
M5 Dyno Results Michaelc E39 M5 and E52 Z8 Discussion 11 23rd January 2005 22:16
My thoughts and some dyno results OEM Vs Nowack...long version Apples Most Memorable Threads' 65 10th June 2002 09:54
