19th October 2006, 15:44
#2
1984 Escort GT (loaded)
In a nutshell there are 3 different options to choose from, one of which is NOT to just change the tips. You exhaust basically has 3 sections (starting from the rear end) you have the (a)mufflers, (b) pipes that include the resonators and then the (c)headers.
Option 1: Change the mufflers. If all you care about is changing th exhaust note on your car, then this is your best bet. There are many to choose from but a lot of people here either go with the Eisenmann which is on the loud side or SuperSprint which is on the calmer side. Changing the mufflers will not increase performance on your car but it will sound better.
Option 2: Change mufflers and remove stock pipes that have the resonators then add pipes without resonators (x-pipe or straight pipes). This will make the exhaust note louder with some/minimal performance gains.
Options 3: Change mufflers, add x-pipe/straight pipes, change headers. This will turn your car into monster. It will be very loud but the performance gains are very noticiable.
Short summary but I hope this helps
Cheers ///
