Low Oil Level Warning?!? Help! - BMW M5 Forum and M6 Forums
Old 18th June 2006, 18:31   #1
Venom77
Venom77's Avatar
Garage: BMW M5 E60 Black
I have 1050 miles on the M5 now, I was going to take it in for service on monday, but driving last night going from 1000-1050 miles. I noticed a little exclamation in the dash by my gear. I opened up the service thing, and under the operating system checks, it had a yellow triangle by oil. Soon after, it changed to a red triangle and said my service was overdue. My oil level guage is almost all the way down and says I'm at minimum to add a quart of oil immediately.
I am not at 1200 miles yet only close... is this normal? Is it safe for me to drive the car 40 miles to the dealer for the normal break in service?
- 06 Sapphire Black E60 M5
-Murdered out in Black
-Florida Enthusiasts-
www.FloridaGerman.com
Venom77 is offline   Reply With Quote
Old 18th June 2006, 18:38   #2
JamesInLV
JamesInLV's Avatar
Garage: E60 M5 - Interlagos Blue/Black/Aluminum
Venon...we're in the same boat! I have my 1200-mile service appointment on Tuesday, and two days ago at about 1100 miles, I got that little exclamation point too and was wondering what the heck it was. Checked through the computer and found I have 0.1L of oil. I'm at about 1140 now, and did a re-check when I pulled into my garage and came out at 0.0L but it still doesn't give me the warning that I must add a quart immediately.
For good measure, even though my appt is on Tuesday, I added about 0.2L just to be safe until then.
Is this normal? From all the posts on here, the fact that neither of us burned down to 0.0L before now is more unusual than normal. There are something like 8-9L of oil in the engine in the first place, so will you be safe for about 40 miles...almost certainly. If you happen to have a quart of oil around you can do what I did just to be safe (and make sure the dealer doesn't give me crap) and add a 1/4 quart or so.
James
Las Vegas, Nevada
Now driving my 1999 Toyota Landcruiser again.
Wife gets the 2007 Honda Odyssey.
Looking forward to my next M5.
2006 ///M5 SOLD :-(
2002 325i SOLD
1987 325i Conv. SOLD
www.LVHomeResource.com
JamesInLV is offline   Reply With Quote
Old 18th June 2006, 19:58   #3
swb3
Garage: 2011 Alpina Blue B7 xDrive
Mine basically did the same thing at 300 miles. If you search one of my early posts you will see I had a faulty oil sensor. However as I have read other posts over time I suspect it was the break-in oil mixing with metal particles and it caused bad readings. I have about 16,000 miles on mine now and have only added 2 liters of oil to the engine besides the service change at 15,000.
I would call the service dept and ask them what to do before adding any oil. I added 2 liters in my panic, and they still told me it was fine to drive the car in 100 miles even though it was probably over filled.
swb3 is offline   Reply With Quote
Old 19th June 2006, 20:00   #4
M52006Black
Garage: M5 2006
No reason to panic. Simply take to dealer and then will top up the oil for you. Recommend that you let the dealer do the top up as they have to reset the oil reading guage.
M52006Black is offline   Reply With Quote
Old 19th June 2006, 22:51   #5
Venom77
Venom77's Avatar
drove it the 40 miles to the dealer, the car went back up to .2 so I figured it would make it just fine...
In for the 1200mi service, then they are going to simonize the car
Old 19th June 2006, 23:40   #6
Demon_M6
Demon_M6's Avatar
Garage: M6 Black/Black
No no need for that, you can reset it ur self, very easy
just select the oil where is shows the clock and temperture
as soon as you see the oil level hold down the button next to the
check button and hold it for 5 seconds.
plus wait untill your oil reachs 0.2L and then add a quart of oil "full bottle"
it should read just perfect on the arrow after you do a reset.
you will be adding oil allot in the future so pick up more oil quarts from
your dealer, they are for free.
Demon_M6 is offline   Reply With Quote
Old 24th April 2010, 18:58   #7
MZLO
Garage: M5 Interlagos
I just got a massage in the dash showing -1.0L in the oil level
What does it mean? Does it mean that the oil level is to low or high?
MZLO is offline   Reply With Quote
Old 24th April 2010, 19:06   #8
justwaiting
justwaiting's Avatar
Garage: 2007 M5 Black
This is a common question on the forum. I usually don't put oil in under the bottom bar...and 1 quart takes it up to around 1.0....it's usually pretty safe around 1.0...but don't overfill above 1.2....I usually put 3/4 in...reset it....wait for it to update..and then check again. It's a common quirky thing with our vehicles...
2007 M5 - Sapphire Black/Black Extended Interior (Headsup/Active Seats/Shades/RPI Ram Air Kit w/ Block off plates/Charcoal Filters Removed/Angel Eye Upgrade/Carbon Fiber Gills/Carbon Fiber Side Mirrors/LCI Rear Taillights)
2007 R1200S - Yellow - SOLD
2007 335I - Black/Black - SOLD(missed the N/A engine)
2004 M3 - Carbon Black/Black - SOLD(but not forgotten )
2001 330I - Black/Grey - SOLD(Cheap leather began to crack after 2 years...sold and got an M3 )
justwaiting is offline   Reply With Quote
oil level Malex E60 M5 and E61 M5 Touring Discussion 5 13th October 2005 08:56
DIY Dummies Guides to Oil Change using Fluid Extractor HDClown E39 M5 and E52 Z8 Discussion 0 18th September 2005 00:46
Low oil warning Rob Plummer E34 M5 Discussion 14 3rd March 2005 21:47
Faulty oil level sensor? Michaelc E39 M5 and E52 Z8 Discussion 0 25th January 2005 15:10
"Engine oil low" Rodrigo Martinez E34 M5 Discussion 3 21st September 2000 00:28
