HomeLink programming difficulties - BMW M5 Forum and M6 Forums
post #1 of 10 Old 30th May 2006, 11:33 PM Thread Starter
Cerberos
Cerberos's Avatar
My HomeLink system has defeated me! I just bought a new home, which has a couple of "rolling code" garage door openers by LiftMaster. I've followed the directions in the M5 Manual and also the downloaded versions from HomeLink but cannot get the dang thing to work. I had no problems with the single code openers at my old home, so I don't think it is a faulty HomeLink system. Therefore, I'm turning to best source of knowledge available on the M5 for help, the Members of this forum! I'm sure I am just missing some small step in the process.
Shawn
Cerberos is offline
post #2 of 10 Old 30th May 2006, 11:50 PM
pvr
pvr's Avatar
Here are a couple of older threads on Homelink difficulties. Most questions are answered.
Cannot Program Garage Door Opener
Programming garage buttons
Good luck.
Paul
2006 M5, Sapphire Black/ Black Full Leather/Walnut
pvr is offline
post #3 of 10 Old 31st May 2006, 12:21 AM
dannamichael
dannamichael's Avatar
on my 6month old opener i had to click a switch over from rolling codes to just one code. now it works perfect
Mtastic
Silverstone II / Black - fully loaded
V1 hardwired
Gtech SS hardwired - good for kicks
Esienmann Race system - cat back
K40 front lazer system
B-rake
S-hift
T-urn
G-as
dannamichael is offline
post #4 of 10 Old 31st May 2006, 12:43 AM Thread Starter
Cerberos
Cerberos's Avatar
Good luck.
I found one of these threads yesterday but not the other. The approach in the 63226 thread is a bit different than what I have previously tried. I'll give it a shot this evening.
Thanks,
Shawn
Cerberos is offline
post #5 of 10 Old 31st May 2006, 01:03 AM
JamesInLV
JamesInLV's Avatar
Saw your problems on the board. I'm a real estate agent and so I deal with garage door openers a little more than the average person (other than just pushing the little button) and had just a little difficulty figuring it out when I programmed mine. I probably have the same openers as you since I just bought a new house as well and it has Liftmaster openers with rolling codes too. I think these directions describe all of the steps I used, but I'm not 100% sure without going out and repeating everything over again.
Step 1: Clear your Homelink (don't skip this step) as noted in the manual.
Step 2: Hold the button #1 on your Homelink in, and hold the opener button on at the same time. Hold these until the Homelink LED starts blinking quickly (took about 20 seconds for me, not the manual's stated 15 seconds).
Step 3: Look at the back or side of the garage door opener itself and you will find a programming button. It's probably a red or purple square button. Press this in for about one to two seconds.
Step 4: Immediately (as fast as possible), go into the car and press and hold Homelink button #1 for about a second, then press it in again for a second, then press again a third time.
Step 5: Upon the third (maybe fourth) press, the garage door opener should have flashed it's light bulb off and on again (or on and off). If you press the Homelink button again, it should operage the door. Make sure your car isn't parked under the closing door!
I find that with them programmed, you still have to press the Homelink button for about one second for it to transmit the opener signal.
These directions are only a slight variation of what is straight out of the manual. I programmed two doors with this, and was even able to make button #3 operate the fixed-code gates to my gated neighborhood.
James
New to me 2006 M3 'Vert
2006 ///M5 SOLD :-(
2002 325i SOLD
1987 325i Conv. SOLD
JamesInLV is offline
post #6 of 10 Old 31st May 2006, 02:14 AM
spatterso
spatterso's Avatar
That is exactly how I had to program my '03 M5, and I figure they have to be the same.
steve
06 M5 (Silver Gray/Walnut Madeira/Black Perf/all options/V1 hardwired/M40 enabled/Reus Audio upgrade package III)
03 M5 (Carbon Black/Black/all options/80 Gig Phatbox/V1 Hardwired) - gone but not forgotten!
spatterso is offline
post #7 of 10 Old 31st May 2006, 03:42 AM
m_five
m_five's Avatar
Here's the Homelink site--they have directions (pretty much same as owners manual, but a bit more manufacturer specific). With rolling code openers, you need to follow the instructions carefully.
http://www.homelink.com/home/global.taf
m_five is offline
post #8 of 10 Old 31st May 2006, 04:03 AM
homesite
Thanks,
Hi,
Did you get it to work? I have the same garage opener you have and cannot get it to work either.
2006 Blue M5
2005 Cayenne S
2004 Lamborghini Murcielago
homesite is offline
post #9 of 10 Old 31st May 2006, 06:37 AM Thread Starter
Cerberos
Cerberos's Avatar
Originally Posted by homesite
Hi,
I got the programming to work this evening. Here is the directions I got from HomeLink earlier this afternoon.
Rolling Code Programming:
1. Press and hold the two outer HomeLink buttons until the indicator light begins to flash (after 20 seconds)or the display reads "Channels Cleared". Do not hold for longer than 30 seconds. Do not repeat this step to program additional HomeLink buttons.
2. Place the hand-held transmitter 1-3 inches from the HomeLink button you want to program.
3. Simultaneously, press and hold both your HomeLink button and your hand-held transmitter. Do not release either button until step 4 has been completed. (If you reside in Canada, refer to the "NOTE" below.)
4. When the indicator light changes from a slow blink to a rapid flash or the display reads"Channel Trained", release both HomeLink & hand held transmitter buttons.
5. Then go to your garage door opener motor head unit in the garage. Locate the "Program" or "Learn" button. Usually near the hanging antenna wire on your garage door opener motor head unit. (The name of these buttons vary by manufacturer, please see your garage door openers owners manual for the location of this programming button).
6. Press and release the "Program" or "Learn" button once, like a door bell (1 second)(Do not hold this button down. Holding this button down for too long will erase all Remotes, Keypad and other HomeLink equipped vehicles). There is 30 seconds in which to initiate step 7.
7. Then go to your vehicle and firmly press and hold your already programmed HomeLink button for three seconds and release. Do this procedure a second time and depending on the Brand of your garage door opener you may need to do this step a third time to complete the process.
The garage should now activate when the programmed HomeLink button is firmly pressed and released. If not, give us a call or refer to the "Troubleshooting Tips" noted below.
Shawn
Cerberos is offline
The Following User Says Thank You to Cerberos For This Useful Post:
Idz21 (12th March 2009)
post #10 of 10 Old 12th March 2009, 06:58 PM
Idz21
Thanks for providing the update Shawn. I know this thread is ancient, but I've had similar issues with a garage door opener at my new home which also employs the Liftmaster unit. I'll give the instructions you posted a try when I get home today. It's for my '05 M3, but the Homelink website categorizes us under the same "M-series" group.
I figure bumping this up might help others in the same situation.
IIIM3 Interlagos Blue on Ecru
Options { ZCP-SMG-NAV-HFS-XHL }
Idz21 is offline
HELP! Programming Homelink Visor with DoorKing Gate dmcgibbo E39 M5 and E52 Z8 Discussion 3 16th August 2010 09:58 PM
key memory programming buckshank E39 M5 and E52 Z8 Discussion 2 6th November 2005 11:57 PM
Help with V1 hardwire & homelink MEnthusiast M5 E39 and E60 tips & tricks 2 19th November 2002 09:49 AM
Rear arm rest w/split fold seats and Homelink questions KevinH E39 M5 and E52 Z8 Discussion 5 16th May 2002 10:13 PM
Help for key/memory programming? kgk E39 M5 and E52 Z8 Discussion 4 12th October 2001 08:40 PM
