Old 25th May 2006, 17:31   #11
6speed
6speed's Avatar
Garage: 1984 Escort GT (loaded)
Originally Posted by Wolverine
Great times - 12.5@116 is really good for your first trip. You should post on dragtimes.com. Excellent launch at 1.94 - I'm having trouble getting under 2.1 with my gtech. I hope to hit the strip in a few weeks.
How do you like your G -tech? Do you have the SS or RR? Did you hard wire it?
Cheers ///
6speed is offline
Old 25th May 2006, 17:48   #12
bernhtp
Garage: M6 Convertible - Saphire Black, Portland Brown full merino, CF
What was the temperature that night? I imagine the humidity was high due to the rain.
How fast is this track? For example, what are typical "good" runs for stock E55s there?
Do you think that your last launch was near optimal, i.e., initial full throttle with some let-up for traction control? The C&D technique appeared to be a bit different - 80% at launch and then application of full throttle. How much do you think hitting the rev limiter (2-3) hurt your ET and speed?
Mike, have you tried using D5 sport with your G-Tech? I'm thinking that it's possible that getting a precise time of shift might be more important than speed of shift and that its hard not to be off by a few hundred RPM when shifting manually, especially on the 1-2 shift where revs climb so fast.
Tom
bernhtp is offline
Old 25th May 2006, 17:49   #13
Mr. Vroom
Mr. Vroom's Avatar
Garage: 2006 m5 white
Awesome quarter time! Did you remove your charcol filters?
Mr. Vroom is offline
Old 25th May 2006, 18:26   #14
6speed
6speed's Avatar
Tom
Temperature: 79 degrees
Humidity: not sure on the % but it was high due to the rain
I did ask some of the local guys there how the track behaved (fast or slow) and they all pretty much said the same thing - middle of the road
My launch felt pretty good (did not bog down much) but I did have some wheel spin (too much) @ aroung 7000 rpms. For the strip I think my method is better than C&D's, for the road I would use C&D's approach - just because it is stickier at the track and it is easier to control the wheel spin when you drop the clutch at 4000rpms (which is essentially what I am doing). I honestly believe that if I had a few more cracks at it I could have gotten my 60' times in the high 1.8's.
Regarding the rev limiter: not sure how much it hurt my times but when I hit it I did feel a slight let down.
6speed is offline
Old 25th May 2006, 18:43   #15
spatterso
spatterso's Avatar
Garage: 06 Silver Gray M5
Fantastic results! Eager to see your next trip results!
steve
06 M5 (Silver Gray/Walnut Madeira/Black Perf/all options/V1 hardwired/M40 enabled/Reus Audio upgrade package III)
03 M5 (Carbon Black/Black/all options/80 Gig Phatbox/V1 Hardwired) - gone but not forgotten!
spatterso is offline
Old 26th May 2006, 01:42   #16
theob
theob's Avatar
Garage: E60 M5 Interlagos Blue
Send a message via ICQ to theob Send a message via MSN to theob Send a message via Skype™ to theob
Well done 6speed!
Next time do your drill without the child seats though! I bet you'll post a lower 1/4mile figure
Any worth mentioning time from other stock cars? (C6 etc?)
08/2005 E60 M5 A30/LKA9/4MK
Options List:
261,319,403,423,430,431,441,442,459,465,488,494, 506,524,534,563,601,609,610,644,672,677,775.
Mod List:
DMS ECU Upgrade, Eisenmann Sport Exhaust,
Supersprint X-Pipe, BMC Filters, Onyx 35 & 20 tint, Recaro Young Sport child seat
RSS: http://feeds.feedburner.com/theobRSS
theob is offline
Old 26th May 2006, 01:46   #17
Enzom
Garage: 05 E55 brilliant silver
How much fuel did you run with? You may find that running with too little fuel (and too little weight over the rear tires) allows for too much wheel spin at the start and in first gear. I always try to run with a 1/4 tank.
Enzom is offline
Old 26th May 2006, 02:12   #18
pvr
pvr's Avatar
Garage: BMW M5 (E60) Black Sapphire (1/06)
A most excellent showing. I imagine that you had a lot of adrenaline flowing. Your helmet is *almost* as mean looking as your car.
Paul
2006 M5, Sapphire Black/ Black Full Leather/Walnut
pvr is offline
Old 26th May 2006, 02:57   #19
6speed
6speed's Avatar
Good point but I had close to a 1/2 tank so that should be ok
6speed is offline
Old 26th May 2006, 14:35   #20
6speed
6speed's Avatar
Yeah, the adrenaline was pumping. You should try to make it out with me next time. A couple E60's in hicktown would really be something
Cheers ///
6speed is offline
Nowack Tuning Report, The Truth (Long Version) CharlesW Most Memorable Threads' 44 30th November 2002 05:49
DRAG STRIP RESULTS!!!! Yupkwondo E39 M5 and E52 Z8 Discussion 23 13th June 2001 08:03
At the strip... alpywhite E39 M5 and E52 Z8 Discussion 19 29th May 2001 18:36
Went To The Drag Strip And Dyno On The Weekend.... RobC E39 M5 and E52 Z8 Discussion 4 5th April 2000 20:37
Page generated in 0.15693 seconds with 12 queries
