Old 19th May 2006, 16:03   #1
DazzaM
DazzaM's Avatar
Garage: Ruby Black M5
Speed cameras displayed on satnav
First of all I would like to say a big thank you to Mathmos from www.e60.net for the info and for helping me getting mine working.
Right some pics first.....
Listing the Gatso's positions
South London
South London a bit closer
and here's one of Mathmos pic's
So this is how you can do it.....
Before you start go to www.pocketgpsworld.com and download the latest speed camera database. It costs around £2 a month or £19 a year. Click on Speed Cameras on the top menu and select 'other' in the drop down chart. You need to download one in a asc format.
1. Create an image of the NAV DVD using DVD Decrypter.
2. Open the iso file for edit (I used UltraISO) and extract the file \tpd\ntcBeu_eu.04.II_20040726\eng\eng.lsc to your local hard disk.
3. Edit the extracted eng.lsc file with a text editor. Wordpad or notepad won't do, I used VEdit.
4. Look for the "TPD-CAT" lines and add a new one for the category you want to add. eg.
TPD-CAT 7395 N Rest areas
TPD-CAT 9101 N Golf clubs
becomes
TPD-CAT 9000 N UK Speed Cameras
5. Near the top of the eng.lsc file look for the "TPD-GRP" lines and add the new category to one of them eg.
TPD-GRP 10001 41012 7366 7384 7379 7352 7312 9108 41001 7395 7316
becomes
TPD-GRP 10001 41012 7366 7384 7379 7352 7312 9000 9108 41001 7395 7316
6. Look for the "TPD-ICO" lines and add a new one for the new category eg.
TPD-ICO 7395 /icons/poi_rest_area.gif
TPD-ICO 9101 /icons/poi_golf_course.gif
becomes
TPD-ICO 9000 /icons/poi_speed_camera.gif
7. Look for the "TPD-SEA" lines and add a new one for the new category modifying the numbers accordingly.
TPD-SEA 7395 http://tpdhost/cgi/form?templ=/eng/...3N&UNIT=%23%23U
TPD-SEA 9101 http://tpdhost/cgi/form?templ=/eng/...3N&UNIT=%23%23U
becomes
TPD-SEA 9000 http://tpdhost/cgi/form?templ=/eng/...3N&UNIT=%23%23U
8. Save the eng.lsc file and copy it back into the correct location in the iso file opened for edit in Step 2.
9. Copy the icon you want to use (the icon must be a 16x16 pixels 256 colors GIF image with transparency) into the \tpd\ntcBeu_eu.04.II_20040726\icons directory in the iso file opened for edit in Step 2.
10. Extract the sf_9101.htm and the st_9101.htm files from the tpd\ntcBeu_eu.04.II_20040726\eng amd rename them accordingly, sf_9000.htm and st_9000.htm in this case.
11. Download the perl script file provided by Mathmos HERE and using the .asc file containing the uk speed camera locations obtained from pocketgpsworld.com, create the idx and url files.
If like me you have no idea about using perl, download cygwin from www.cygwin.com and make sure you select the perl modules when installing it. Find the cygwin folder on your hardrive and open it. In there you should have a folder called Home, open that and open the next folder (mine was called Darren, so I guess it will be your name or the PC's name). Put the perl file and the asc file you downloaded into that folder. Now run cygwin (icon on desktop) and type..
perl createidxurl.pl pocketgps_uk_gatso.asc 9000 (press return)
pocketgps_UK_gatso was the file name to my asc file so change that to whatever your asc file is named as. You should now have a idx and a url file in that folder.
Some IT geek will more than likely start droning on about perl and start telling how I should have done it 'this way' but this system worked so naa :hairypoke:
12. Look in the tpd\ntcBeu_eu.04.II_20040726\tables\0 directory and find the last .idx and .url files listed. On my DVD they were 0097.idx and 0098.url.
13. Rename the idx and url files generated in step 10. accordingly eg. 0099.idx and 0100.url in my case and then copy them back into the correct location in the iso file.
14. Go back and edit the sf_9000.htm and st_9000.htm that you created in Step 9. Change all occurances of 9101 to 9000, change the idx and url references to the filenames you used in step 11. and change any relevant text to what you want eg. Golf clubs becomes Speed Cameras. Once done copy them back into the correct location in the iso file.
15. Right click on the ISO image name and select Properties. In the CD File Section ensure only ISO 9660, Joliet and UDF are ticked. In the ISO 9660 FileName Format section select the Windows/Unix(31) option and leave the other options alone. In The Joliet FileName Format Section select the Extended(110) option. On the Date/Time tab tick the Creation and Modification boxes but do nothing else. Now press OK to save these preferences.
16. Save the edited iso image.
17. Burn the iso image to DVD. I used DVD Decrypter.
Once you have done one it's basicly all setup ready for the next time you download a new camera update so it's very simple to keep updating and burning a new dvd.
I've tried it on a M5, a 535d and a 1 series and all is fine.
Foot to the floor, head back in the seat and just watch the scenery go all Stargate
DazzaM is offline
Old 19th May 2006, 17:03   #2
theob
theob's Avatar
Garage: E60 M5 Interlagos Blue
Send a message via ICQ to theob Send a message via MSN to theob Send a message via Skype™ to theob
A B S O L U T E L Y BRILLIANT!
I'm looking forward to make a similar work for the Greek Nav map...
08/2005 E60 M5 A30/LKA9/4MK
Options List:
261,319,403,423,430,431,441,442,459,465,488,494, 506,524,534,563,601,609,610,644,672,677,775.
Mod List:
DMS ECU Upgrade, Eisenmann Sport Exhaust,
Supersprint X-Pipe, BMC Filters, Onyx 35 & 20 tint, Recaro Young Sport child seat
RSS: http://feeds.feedburner.com/theobRSS
theob is offline
Old 19th May 2006, 17:37   #3
unfoundhorsepower
unfoundhorsepower's Avatar
Garage: 2006 M5-E60, Interlagos blue,all options + 2004 Z4 Red loaded,2004 M3 Luguna Seca Blue, 2009 X5 35d Saphire Black.
wow, sorry, it's WAY over my head, interesting though...thanks
unfoundhorsepower is offline
Old 19th May 2006, 17:39   #4
DazzaM
DazzaM's Avatar
Yep, just use the greek folder and not the eng (english) folder
DazzaM is offline
Old 19th May 2006, 17:42   #5
DazzaM
DazzaM's Avatar
It's really not that hard at all. Trust me I'm not a IT person, I don't even know how to use the likes of excel.
If you download the software needed and follow it step by step you'll be surprised how easy it is.
DazzaM is offline
Old 19th May 2006, 21:39   #6
dannamichael
dannamichael's Avatar
Garage: E60 M5 silverstone ii
need that here in california, USA
need to get GPS on cop cars. that would be great for m5 owners and criminals. ahahhahah
Mtastic
Silverstone II / Black - fully loaded
V1 hardwired
Gtech SS hardwired - good for kicks
Esienmann Race system - cat back
K40 front lazer system
B-rake
S-hift
T-urn
G-as
dannamichael is offline
Old 19th May 2006, 23:46   #7
blau M5
blau M5's Avatar
who said criminals don't drive M5s...
06 Interlagos Blue M5
blau M5 is offline
Old 23rd May 2006, 11:14   #8
Chilliboy
Garage: Volvo V70 T5 Black
Speed Camera Icon
Great stuff, but... I'm probably being dumb here, but from where do you get the speed camera icon? I've searched the net, and found plenty of images, but nothing in the correct format. And then when I edit it down to the 16x16 pixel size it looks a mess. Help!
And I haven't even got to to the cygwin stuff yet!
Chilliboy is offline
Old 23rd May 2006, 13:24   #9
Heuer
Garage: B5 Touring
Superb work and today's project! Any chance of emailing me the camera icon file?
B5 Touring
Porsche 993 Carrera 2
E-Type Roadster
Heuer is offline
Old 23rd May 2006, 13:34   #10
Heuer
Garage: B5 Touring
OK found it!
Heuer is offline
Speed Camera warnings in B5 SatNav Heuer ALPINABoard.com | BMW Alpina Discussion 5 24th May 2006 13:09
what's with this whole speed limiter thing? DINGOLFING E39 M5 and E52 Z8 Discussion 6 28th October 2003 21:21
Rally drivers stung by cameras.... JJJ Off Topic Forum 2 2nd August 2003 10:40
From the Sunday Times Driving section...( long ) JJJ E39 M5 and E52 Z8 Discussion 13 12th July 2003 01:08
Page generated in 0.17319 seconds with 12 queries
