Old 17th May 2006, 06:55   #1
1000 Oaks
1000 Oaks's Avatar
Garage: 2006 M5 Met Blk
Trasmission Software Update 5/15/06
I met someone today who said that there was a transmission software update that became available today. Can anyone verify this?
1000 Oaks is offline
Old 18th May 2006, 21:30   #2
DrLaw
DrLaw's Avatar
Garage: 2006 M5 Black/Black
I have my M5 in for service and software upgrade today and asked that if a new version of the SMG software exists, to flash it as well. I'll report after I pick up the car.
DrLaw is offline
Old 18th May 2006, 21:38   #3
1000 Oaks
1000 Oaks's Avatar
great...timming is everything...thanks...look forward to the feedback
Old 18th May 2006, 23:29   #4
J.C.
Garage: 2006 E60 M5 Sapphire Black
Launch Control
This is just speculation, but what if it is an SMG update that completely removes the "not documented in the user manual" feature of launch control from the car altogether? I fear this is what BMWNA is going to do in order to address the issue -- they could take the stance that it's not in the manual, it shouldn't be in the car -- especially seeing as how they recently seem to have updated the manual (the PDF floating around here, if that really is the update) and it STILL doesn't talk about launch control. Hmmm.. what could they be up to?
I'm just worried after hearing ParkerF's story about it not working at all. I just hope he's not the first victim of a launch control removal SMG software update.
USA launch control inop ?
-J.C.
'06 E60 M5 Black Sapphire Metallic / Black Perforated Merino Leather
J.C. is offline
Old 18th May 2006, 23:56   #5
SCORPIO
SCORPIO's Avatar
Garage: 2006 M5 - Silver Gray
Just e-mailed my SA - here is his response:
it regards a trans failsafe warning coming on for no apparent reason with the traction control light also (NO YOU CANNOT GET LAUNCH CONTROL YET)
Heh - guess he knows me too well!!
SCORPIO
2006 BMW E60 M5 - Active Autowerke's ECU upgrade; Charcoal Filters removed
-Silver Gray with Black perf. interior
-Rear side impact airbags
-comfort access
-front multi-function seats with active width adjustment
-wood trim, walnut
-power rear sunshade with rear manual side window shades
-front ventilated seats
-heads-up display
-3M Ultrashield clearbra
2008 Black Yukon Denali - on order!
2007 Saleen Mustang Parnelli Jones Limited Edition 1 of 500 - Sold
2006 Sterling Grey/Grey BMW X5 4.4i w/all available options
2004 Chevrolet Corvette Z06 (red) - Sold
2004 Quicksilver Cadillac Escalade ESV - Sold
2003 Cold Stone Creamery #00 Mini Cooper S Challenge Series Race Car
2003 Sterling Grey/Black M5 - Sold
2000 White Chevrolet Silverado 2500 HD 4x4 SB Pick 'em up truck - Sold
1994 Yellow Land Rover Defender 90 - Sold
1980 Nissan 2WD pickup - Sold
1971 Fiat Spider - Sold
SCORPIO is offline
Old 19th May 2006, 06:23   #6
DrLaw
DrLaw's Avatar
Just my luck! The BMW regional rep. was at the dealership today! They did NOT upgrade ANY of my software! My chief complaint was my CD player running after I shut the car down, and supposedly, they fixed the issue with a setting in the I-Drive menu??!!?? They also told me that my oil level system was working properly, although it will drop suddenly from 1.0 to .4, this is normal???!!!??? As for the SMG software, I was told that no upgrade exists.
Where is that post that details ALL the bug fixes that 21.02 addresses? I have searched, but to no avail.
Thanks!
DrLaw is offline
Old 26th May 2006, 08:45   #7
2006M5
Garage: 2006 M5 Silver Gray
I had my M5 serviced today because of a transmission malfunction warning. It turns out that the service technician found an SMG Fault 5101 for the Hydraulic Pressure Sensor and also found a broken ground cable. According to SIB 23 01 96, they needed to upgrade the software and reprogram the car. They updated my car with PROGMAN 21.02.02. I will let you know if I can get another transmission malfunction warning after the software upgrade today.
2006M5 is offline
Old 26th May 2006, 15:14   #8
Jster
Garage: 2006 M5 Silverstone Silver
DrLaw--did the idrive "fix" stop your CD player run-on problem? Doesn't sound likely but since I have this with both the CD and DVD drive thought it was worth asking. Last time in to the dealer they didn't have a fix.
Jster is offline
Old 26th May 2006, 15:27   #9
DrLaw
DrLaw's Avatar
Glad you asked. They did NOT fix the problem yet and I am planning to return to the dealer and firmly ask that they flash the new software this time. Besides, I have sent $550 to AA and I would like to have this done before I send the ECU to them.
DrLaw is offline
Old 26th May 2006, 18:04   #10
Wolverine
Wolverine's Avatar
Garage: BMW E60 M5 Silverstone II/Silverstone/Aluminum
I've heard from BMWNA that the software fix for the CD player will not be available until late summer. I had the 21.02.01 installed 4/26 and it did not fix the CD.
2006 E60 M5 Silverstone II/Silverstone/Aluminum, All Options, 35% tint, Aluminum Pedals, Valentine V1 and Passport 9500i Hardwired, Blinder Xtreme M40, Michelin PS2's on 20 inch BBS RS-GT's, Winter Pirelli Sottozeros on OEM 19 inch wheels, Resonator Delete, Charcoal Filters Removed, Eibach Springs and Spacers, Active Autowerks ECU, BMC Filters, RPI Air Intakes, Evosport Pulley. Retired from track duty 10/08. Dinan diff replaced with OEM at my cost due to failure at 56,000 miles. First on the list for the upcoming F10 M5.
Wolverine is offline
Attempt at e39 m5 touring project? (Buildstory of DINAN supercharged 540i Touring) aw/ir02smg E39 M5 and E52 Z8 Discussion 979 23rd February 2010 22:54
M5 cars with DVD NAV system, there's a NEW software update........ FAST 5 E39 M5 and E52 Z8 Discussion 4 13th December 2004 01:18
Can anyone hook me up with the latest NAV software update CD please? FAST 5 E39 M5 and E52 Z8 Discussion 12 10th February 2004 22:49
nav software update question mottati E39 M5 and E52 Z8 Discussion 0 25th October 2003 02:07
Nav Sw Ver 18 upgrade - FAQ 1C00lVC M5 E39 and E60 tips & tricks 0 12th March 2002 06:00
Page generated in 0.14532 seconds with 11 queries
