Automatic Wipers Doesnt Work - Any ideas? - BMW M5 Forum and M6 Forums
post #1 of 11 Old 15th April 2006, 06:34 AM Thread Starter
hal2000
I've never been able to get the automatic wipers to work.
The dealer has replaced
Windshield, Sensor ,Cover
Ive turned the knurled knob all the way up and down. Ive tried the single swipe to maybe activate it. (some boards commented that it may need to be activated in order to prevent damage from automatic car washes.)
Any Ideas? I want to get it fixed but i dont want the dealer to mess up anything else in the process.
How well does it work?
2006 BMW M5 Interlagos Blue
hal2000 is offline
post #2 of 11 Old 15th April 2006, 07:11 AM
MEnthusiast
Moderator Emeritus
MEnthusiast's Avatar
I've been using the rain sensing wipers since 2000 and I find they work great. are you pressing the button to activate them?
All the best,
MEnthusiast is offline
post #3 of 11 Old 15th April 2006, 08:40 AM
JamesInLV
JamesInLV's Avatar
I thought after a windshield replacement that the auto wipers on my wife's 325i weren't working and that the installer screwed up the windshield installation. Turns out, there is a sequence where you have the key in position 1 or 2, move the wiper control into the auto position (up one from off), and then start the car. That re-activated the function, so now they work properly all the time. These instructions were specifically spelled out in the manual...might have some special sequence like this for the M5 too.
James
New to me 2006 M3 'Vert
2006 ///M5 SOLD :-(
2002 325i SOLD
1987 325i Conv. SOLD
JamesInLV is offline
post #4 of 11 Old 15th April 2006, 02:16 PM
pvr
pvr's Avatar
Originally Posted by MEnthusiast
... are you pressing the button to activate them?
As Jerry said, there is that little button on the end of the stalk to press. A small light in the button goes on if it is activated. Also, if the windshield-sensor interface has air bubbles, the automatic wiper won't work well.
Good luck.
Paul
2006 M5, Sapphire Black/ Black Full Leather/Walnut
pvr is offline
post #5 of 11 Old 15th April 2006, 05:27 PM
TireBurn
TireBurn's Avatar
You would think that the dealer would have tested the sensor, especially if they had to replace the windshield. This just doesn't make much sense to me, it is one of the easiest items to test if faulty. Squirt water on the windshield and if it is activated via button or otherwise... it works.
I get the impression that a lot of dealerships rape BMWNA on warranty claims.
Does your stalk lite up when you turn on the automatic sensor?
2006 E60 M5 Sepang Bronze/ Sepang / Olive
2004 E46 M3 Cab SMG Titanium Silver/ Light Grey/ Aluminum (**traded)
TireBurn is offline
post #6 of 11 Old 16th April 2006, 02:10 AM
aaronmiles
aaronmiles's Avatar
When a dealer replaces the windscreen they can often forget to re-initialise the rainsensor, it could be that simple
Its a 5 minute job to fix @ the dealer.
I also dont know why its so hard for them to pin down. Take a hose to it and they should be able to test it without issue.
1999 Imola Red M5. Extended Caramel Interior
Mods on my pre-update beast:Eisenmann "Race" exhaust (76mm tips), 19" Hamann PG2's, AACAI, Clear Angel Eyes, MK4 Nav, GC's M5 Coilover kit w/front camber plates, Dinan Front and rear sway bars, D/A swaybar mounts, Dinan front and rear strut brace, Braided brake lines, Eibach 3mm wheel spacers, Rogue Engineering underdrive pulleys, IATS Relocation, Powerchip, Xenon foglights & Lower engine covers w/Brake duct cutout
2008 Volkswagen Golf GTI. The wifes new car
2005 Ford Territory Ghia. The wifes car. (Sold)
1986 Toyota Landcruiser HJ75. The farm ute.
aaronmiles is offline
post #7 of 11 Old 16th April 2006, 03:12 PM Thread Starter
hal2000
First thank you for all the replies. Yes the A does light up when i press the end of the stalk.
I tried testing it with a garden hose from light sprinkle to full monsoon. I'll try to call them and ask them how to reinitialize it.
My dealer has been asbolutely awful.
I was supposed to get the extended warranty at cost and I have tried no less than 15 times to contact them regarding it (email fax, telephone, in person) with no results. I gave up after 3 month. The frustration is just not worth it.
hal2000 is offline
post #8 of 11 Old 16th April 2006, 03:30 PM
rodman31
rodman31's Avatar
Who are you using??? I am partial to BMW of Sterling, I understand this is a little far for you probably, but 2 great M guys there!!
Have you tried Tischer??? They are probably the only other dealer I trust in the area. I used BMW of Fairfax forever and then they went thru 4 SA's in like 3 months!!! I know more than those guys!!
PM me if you want contacts for Sterling or Tischer.
Are you going to the M3 meet?? I should be there!
Robert
rodman31 is offline
post #9 of 11 Old 16th April 2006, 03:42 PM
aaronmiles
aaronmiles's Avatar
The only way to reinitialise the sensor is at a dealer so ringing them wont help....
Mate ..... it is most certainly worth it. Your efforts are more than adequate. You have just spend a substantial amount of your hard earned $$ on a car from a respected marque... and even if you had not done any of those things, its just plain rude. I would rock up to the dealership and request a meeeting with the dealer principal. Outline the attempts you have made to get the warranty sorted out to no avail, make it so obvious that there is no other answer than "Yep... we stuffed up, I'll make sure its fixed".
Remind them that your soapbox is a large one (here) and that while you do not wish to outline your concerns publicly, you may be forced to ask for advice from the wider M5 community which will obviously involve outlining the parties involved. Hopefully they will read that as "Fix it or I will ***** to everyone in sundry". Normally thats enough to get them off their snatches.
Good luck
post #10 of 11 Old 16th April 2006, 04:30 PM
MEnthusiast
Moderator Emeritus
In your place I might just call the next nearest dealer and talk with the service manager and tell them what has happened at your current dealer and that you are looking to take your business to a new dealer and see how the manager reacts. If you are satisfied, ask if they can do that re-initalizaiton right there on the spot (whats involved?- could be a long process- I dont know) and if they can do it, just wait and be patient. Maybe buy a quart of 10w60...
All the best,
Automatic Climate Control - NOT wdwgdas E39 M5 and E52 Z8 Discussion 28 28th August 2015 12:31 AM
Nowack Tuning Report, The Truth (Long Version) CharlesW E39 M5 and E52 Z8 Discussion 90 2nd September 2011 10:49 AM
Wipers not too good, any ideas? plisken E34 M5 Discussion 12 4th October 2005 09:31 PM
Hey Guys, the enemy, no, I mean Mercedes will be the first to offer 7 SPEED TRANS.... FAST 5 GTBoard.com: General Sportscars 2 15th May 2003 10:01 AM
Do you use your M5 to commute to work? Kevmmm E39 M5 and E52 Z8 Discussion 38 13th December 2001 09:28 AM
