Going into 1st gear 'clunk' - Page 5 - BMW M5 Forum and M6 Forums
Old 12th May 2008, 06:50   #41
Mike Benvo
Garage: BMW
I had this happen to me and it turned out to be a transmission pulse sensor.
It's normal for a slight clunk to occur, but not one that makes you feel as if you were rear ended.
_________
Mike Benvo - BMW Coding / Programming Expert - E60 M5 Euro SMG Available
E60/E61 Coding List Available Here: http://www.bpmsport.com/Coding.pdf
Cars:
E90 M3 6MT - Akra Evo, Crank Pulley, Stage II BPMSport ECU Flash, BBS LM, LCI
E60 Silver Grey BMW M5 - Dinan Rear Section, Crank Pulley, Stage II Flash RIP
E60 2010 550i M-Sport Automagic - 100% bone stock other than window tint
1990 E32 735i -Low Comp M35B30 w/ GT35 Turbo, Air to Water intercooler @ 14 PSI
540HP 2003 BMW 330ci - Low comp, 15PSI ASA Supercharger, ~540WHP - RETIRED
mbenvo@gmail.com
Mike Benvo is offline   Reply With Quote
Old 15th November 2011, 15:13   #42
TheRacerBoss
Garage: BMW 530i Black
Damn I am a victim 2,
Never had this problem until now. Got to rush to the dealership before my warranty is out.
Thanks for the thread, it serves well even though its ancient
TheRacerBoss is offline   Reply With Quote
Transmission Syncro Problem?? MariettaM5 E39 M5 and E52 Z8 Discussion 25 13th September 2012 05:06
3.45 diif. - 1st gear myth EMPEROR E39 M5 and E52 Z8 Discussion 90 11th September 2009 18:37
engaging 1st gear jefrem E28 M5 Discussion 2 6th December 2002 17:47
SL 55 vs Z8 at the Nurburgring! mmunson E39 M5 and E52 Z8 Discussion 64 21st April 2002 01:42
KirklandM5, when are you doing the Dinan LSD tests? kenneth E39 M5 and E52 Z8 Discussion 45 28th July 2001 19:57
