Old 16th January 2006, 04:58   #1
rob1
Garage: 2006 Black M5
Question on First to Second Gear
I have only had my new M5 for a week and am getting used to the SMG.What can I do to avoid the slight hesitation I am experiencing going from first to second gear .I am not sure if I should let up my foot from the accelerator or keep it on with constant downforce.What will get me from first to second gear sooner?
rob1 is offline
Old 16th January 2006, 05:49   #2
rodman31
rodman31's Avatar
Garage: 2006 Silverstone/Black perforated Leather
What mode are you driving in?? I never let up on the accelerator and I use S3 and S4. Remember there is an actual clutch in there at work, so there is some down time while gears are changed. I actually prefer to use S3, p400 when driving around, I found that to be most comfortable for daily driving.
My wife uses D3 and likes that very much. Hate to say it, but you just have to play around to find which one you like best. When you get thru the 1200 mile and you hit p500 S6 or S5, there ain't no hesitation there at all bro!!!!!
Robert
rodman31 is offline
Old 16th January 2006, 08:44   #3
e60beast
e60beast's Avatar
Garage: 2007 e93 335 Cabrio, Sparkling Graphite
along with what rodman31 said... you may also be shifting to early between 1st and 2nd - its smoothest between 2.8k - 4k I find. Do you see the gear number blinking in the dash between the change? if so, then you are definatly short shifting...
Things also seem to smoothen out after the 1200mi break-in period.
hope that helps.
cheers!
- 2007 e93 335 Cabrio, Sparkling Graphite/Jade Grey
- ex 2006 M5, Saphire Blk/Blk full/walnut
- ex 2001 M5, LeMans Blue/Black heritage
- ex 2004 530i Saphire Blk/Blk -Sport/premium pkg
e60beast is offline
Old 16th January 2006, 16:31   #4
rob1
I appreciate the feedback.I am in S4 400 .I only have about 90 miles on the car.I am using the HUD as my guide when shifting.I have not seen the lights blinking to indicate that I am shifting too soon.I will try to not let up on the gas and just accelerate straight through.I cannot wait for the break in period to end!
rob1 is offline
3.45 diif. - 1st gear myth EMPEROR E39 M5 and E52 Z8 Discussion 90 11th September 2009 19:37
Cam gear question, ****** or advance for better torque? Mark J E34 M5 Discussion 1 9th January 2003 09:12
Gearbox problems bibbya E34 M5 Discussion 13 29th August 2001 22:36
KirklandM5, when are you doing the Dinan LSD tests? kenneth E39 M5 and E52 Z8 Discussion 45 28th July 2001 20:57
First gear problems jazz E39 M5 and E52 Z8 Discussion 4 19th April 2000 15:42
Page generated in 0.10690 seconds with 11 queries
