20 inch Racmonolite aftermarket wheels - Page 62 - BMW M5 Forum and M6 Forums
Old 7th September 2006, 19:16   #611
Zapper
Garage: M3 Carbon Black
Originally Posted by bmwbonehead
Jamie, Zapper, any issue with your nonlowered cars?
No rubbing on my car, but I'm running the 285 rear and on stock suspension.
Zapper is offline   Reply With Quote
Old 7th September 2006, 19:22   #612
bonehead
bonehead's Avatar
Garage: Somethin' German
Sales Feedback: (7)
Forgot you went with that size combo. James, when are you going to have your set up done?
Boner
bonehead is offline   Reply With Quote
Old 7th September 2006, 19:37   #613
JamesInLV
JamesInLV's Avatar
Garage: E60 M5 - Interlagos Blue/Black/Aluminum
Setup should be done on Tuesday or Wednesday next week for me. Wheels are supposed to arrive Monday, tires on Monday or Tuesday. I'll probably have the tires/wheels on first, then get the H&R springs installed as soon as I can get an appt for it after that.
Edit: One special factor for my tires. Tirerack has received limited fitments in the ContiSportContact 3 (yes, THREE) tire, including 305/25. I had them ship me those for the rear along with the Contact 2 for the front. Not sure if there will be any measurement differences since Continental hasn't provided any fitment information on their website, so that could also be a difference on whether mine rub or not, before or after the springs go in.
James
Las Vegas, Nevada
Now driving my 1999 Toyota Landcruiser again.
Wife gets the 2007 Honda Odyssey.
Looking forward to my next M5.
2006 ///M5 SOLD :-(
2002 325i SOLD
1987 325i Conv. SOLD
www.LVHomeResource.com
JamesInLV is offline   Reply With Quote
Old 7th September 2006, 20:32   #614
andrewsherman
andrewsherman's Avatar
Garage: 2007 Silver Grey
I have heard the the '07s were going to be fitted with the 3's. Does anybody know if this is true? Any word on how they will compare with the PS2s?
'07 M5: Silver Grey/Black Full Merino Leather|Walnut Madeira Wood Trim|HUD|Sirius|Comfort Access|Split Rear Seats|Rear Sunshades|iPod Interface|
Goodies: ESS Software|Dinan 3.91 Rear Differential|EvoSport Pulley|Dinan Free Flow Exhaust|Dinan Front Control System|Dinan Rear Sway Bar|RPI Ram Air Scoops|BMC Filters|RPI Oil Cooler|SprtintBooster| HRE P40s in Graphite|LED Tail Lights|AngeliBright 3.0|AC Schnitzer Roof Spoiler|Vizualogic A-1250 Rear DVD Sysyem|Huper Optik ceramic tint|clear-bra|V-1 Stealth Install|Blinder M-40|Aluminum Pedals|LED interior bulbs|OE M6 style wheels w/Blizzak LM-22 255/40VR19 (Winter Set up)
Past Rides: '04 745Li Titanium Grey/Black|'01 740iL Titanim Silver/Black|'91 K1100RS|'88 K75S
andrewsherman is offline   Reply With Quote
Old 7th September 2006, 21:35   #615
shep01
Garage: 550i
you need more camber
Originally Posted by PFDSOTM
It's definitely the sound of tires rubbing...I had it in my previous M3. However, If you don't plan to use lower springs, you shouldn't have a problem...the rubbing is slight but noticeable.
I cannot imagine them rubbing but, it may well be that you to add more negative camber to the alignment. BMW notoriously dials in alignment settings that propmote understeer. You should max out whatever available negative camber is available from the factor suspension - especially with that larger rubber. Ideally, the car will handle far better with 1.5 degrees or more of negative camber. That will also eliminate any slight rubbing you may be having.
Can you get me the factory specification for their alignment?
shep01 is offline   Reply With Quote
Old 7th September 2006, 21:40   #616
shep01
Garage: 550i
alignment
When you lower the car you effect the camber in the wrong direction! You also likely still have a factory alignment which is ordinarily lousy specs that encourages understeer. If you can get me the factory specs I can give you a proper baseline alignement set-up that will both wear your tires well and consider the lowered car and the larger/wider rubber. I will also give you some agressive alternatives for those who partake in more "spirited" driving. I have been doing racecar alignments, myself, for a long time. I do all my alignemnts with string, not computer, and I have years of parameters and specs as a resourse to draw upon.
Rolling the fenders, which I do commonly on most of my cars, is always an option but let's first see what your rear camber looks like.
Old 7th September 2006, 22:11   #617
PFDSOTM
Garage: 2003 M3 Alpine White
Shep,
I'm out of town this weekend, I can get it to you Monday. Hopefully this can fix the problem....thanks.
PFDSOTM is offline   Reply With Quote
Old 7th September 2006, 22:19   #618
bonehead
bonehead's Avatar
Sales Feedback: (7)
I take it that the Conti 3's don't come in the 275/30's (yet)?
Old 7th September 2006, 22:32   #619
ChuckD
Garage: White E46 M3
Shep,
Forgive me if you mentioned it already. But did your installer check alignment or realign the car after he installed the springs? If not then Shep is on to somthing in that.. you could have even more positve camber than even the factory aligment specifies. Shep can easily get you a street performance alignment specs based off the stock specs that will enhance the car yet not overly wear the tires.
Also.. how does the car handle with the new springs? Would you say it is less or more apt to roll than it did with the factory springs installed? I am wondering what the spring rates are in comparison to the stock springs.
Looking at your pictures I can not see how you are rubbing unless the new springs compress too far in combination with an already overly postive camber setting. Remember as you take that aggressive right hand turn the tendancy of your left wheels will be to have the tops lean towords the fender lip.
To be clear.. not that the springs are the problem, but they could exacerbate an already overly positive camber setting if it was not compensated for after the spring installation.
ChuckD is offline   Reply With Quote
Old 7th September 2006, 22:38   #620
JamesInLV
JamesInLV's Avatar
Nope...just the 305/25 for the rear. The just started receiving inventory, so it's only a matter of time (weeks, a month or two?) before they have a wider inventory in the Conti 3.
20 inch Rädenergie wheels H&R Springs TOPSUPRA E60 M5 and E61 M5 Touring Discussion 25 20th December 2005 00:09
20 inch wheels willm5ad E39 M5 and E52 Z8 Discussion 26 18th December 2005 16:41
wtb 20 inch style 32's stevenbenatar Parts / Other For Sale or Wanted 3 18th October 2005 19:13
M5 rims and X5 20 inch Rims alpineblue Parts / Other For Sale or Wanted 0 1st October 2004 01:51
20 Inch after market wheels on the E60 M5? 2004M5 E60 M5 and E61 M5 Touring Discussion 7 10th September 2004 20:05
