20 inch Racmonolite aftermarket wheels - Page 60 - BMW M5 Forum and M6 Forums
Old 6th September 2006, 10:52   #591
Jamie140
Jamie140's Avatar
Garage: '03 360 spider, '06 M5
Originally Posted by MRichmond
Wait. What profile and brand tires are you using? It sounds like you experienced a huge increase in ride harshness and your car is not even lowered???
No, a slight increase in harshness. I'm not sure, however, that I'm prepared to accept more harshness by adding springs. I would consider, however, an adjustable coilover system when one becomes available.
I did the conti's. The Yokos are also available in these sizes. 305/25 and 275/30.
2012 M5
2011 997TTS Cab
2010 335i Cab
2003 e39 M5
1996 993TT
2004 Porsche Carrera GT
2012 Harley Street Glide
1993 Harley Nostalgia 'Cow Glide'
Jamie140 is offline   Reply With Quote
Old 6th September 2006, 13:53   #592
shep01
Garage: 550i
let me just say.....
i sure hope you all begin to feel the difference in ride from the decrease in unsprung weight. The pictures, the cars, look great. I personally would be running the 275/30 up front and the 305/25 in the rear. That will not produce any ABS error ( or any other error). It will, as we have discussed, produce a speedo error, erring to the side of saftey for you guys as the speed will be overstated by 4%. On the other hand, I like the free differential upgrade and be sure the 500hp will be quite happy spinning a larger tire.
Beautiful cars, no doubt looking a bit more agressive with the H & R's but all looking much more 'proper' with these wheels.
Shep
shep01 is offline   Reply With Quote
Old 6th September 2006, 13:56   #593
shep01
Garage: 550i
very common - not the tires
Originally Posted by PFDSOTM
Yes, they're 275/30 front and 305/25 rear. I contemplated keeping the stock size but Chuck convinced me with the added rubber protection. Glad I went wider, it does fill the wheel arches well and also looks menacing from the rear view.
Just had them mounted today so haven't had much seat time. Did notice a clunking sound when going through my neighborhood road dip and pulling up the garage curb but it doesn't sound like rubbing...more like a light clunk from the right rear...hope it's not something with the spring install...have to get it checked out.
Likely your springs are seating themselves. It is difficult to get them properly seated while the car is in the air. Many times it takes a few mile and a good bump to get them seated. It should go away entirely - if it doesn't let them take a look at that corner as the spring can get hung up. The larger rubber will definitely not rub - it is not even close.
Good choices all the way around. Congrats and enjoy!
Shep
Old 6th September 2006, 14:00   #594
shep01
Garage: 550i
Motons.....
Metalman has had Motons on the car for some time. He is actually doing some fine tuning right now regarding droop/shock shaft lengths. Now that he has done the hard part all you have to do is call Moton or email Metalman and you can have full adjustable suspension. He has a set of wheels with 325's mounted on the rears - just wait until you see this set-up.
Shep
Old 6th September 2006, 14:10   #595
shep01
Garage: 550i
I don't know why I just love white BMW's....
First time posting pictures so hope I did it correctly. Sorry for the delays in posting the pictures...had problems obtaining the H&R Springs. Sorry for the dark pictures, camera ran out of battery as the sun was setting...got only one pic in daylight.
Running 275/305 Conti's...ride is just a bit stiffer...hardly noticeable. Thanks again to Chuck and Shep for the awesome job with the wheels!
Hummmm
Old 6th September 2006, 14:55   #596
Jamie140
Jamie140's Avatar
Shep
325? Dayam.....
Old 6th September 2006, 15:10   #597
shep01
Garage: 550i
yep...
325? Dayam.....
He already has the tires mounted - just waiting for the motons to come back with the redesigned shaft length. He tracks the car often, on slicks, and is not real conservative when it comes to such matters.
Old 6th September 2006, 16:07   #598
glowrider
Moderator Emeritus
Garage: CL 63, S550, RR Sport SC
Will there be a way to recalibrate the speedo/odo?
glowrider is offline   Reply With Quote
Old 6th September 2006, 20:01   #599
shep01
Garage: 550i
no
no practical way. there are ways to write an algorithm an do a correction electronically, but, the wiring is super involved and ultimately I do not know anyone with a device that is plug and play.
Old 6th September 2006, 20:34   #600
PFDSOTM
Garage: 2003 M3 Alpine White
Shep
Drove the car out for lunch and did hear the tires rubbing when making a hard right (from left rear). All the clunking and rubbing seems to only come from the left rear so I'm wondering if it might be the springs not set properly on that side. Curious to see if anyone with 305 are larger experiencing and problems...with H&R springs.
Strange considering you guys think there shouldn't be any rubbing...seems like there's still plenty of clearance..
PFDSOTM is offline   Reply With Quote
20 inch Rädenergie wheels H&R Springs TOPSUPRA E60 M5 and E61 M5 Touring Discussion 25 20th December 2005 00:09
20 inch wheels willm5ad E39 M5 and E52 Z8 Discussion 26 18th December 2005 16:41
wtb 20 inch style 32's stevenbenatar Parts / Other For Sale or Wanted 3 18th October 2005 19:13
M5 rims and X5 20 inch Rims alpineblue Parts / Other For Sale or Wanted 0 1st October 2004 01:51
20 Inch after market wheels on the E60 M5? 2004M5 E60 M5 and E61 M5 Touring Discussion 7 10th September 2004 20:05
