Old 10th December 2005, 13:08   #1
507bhp
507bhp's Avatar
Garage: 2006 Lexus GS430 Silver
Exclamation Engine Oil Leak Suspected! Please Help! URGENT!!!
Dear fellow board members,
I have a very strange engine oil issue with my M5. I would really appreciate it if someone can read the following carefully and be able to give me the diagnostics of my car's condition.
Thank you in advance.
Here is a quick summary.
My car arrived with about 30km on odometer. At this time, the meter showing 0.9L Engine Oil Level.
When the car reached around 600Km, the engine oil level dropped to 0.8L.
When the car reached around 1,000Km, the engine oil level dropped to 0.7L.
(This was right befroe we took off on a long distance weekend trip yesterday)
Within 100KM of travel (from 1,000Km mark), the engine oil level dropped to 0.5L (from 0.7L). Then it maintained this level (0.5L) for next 200KM of travel. (Still showing 0.5L at 1,400Km) That was yesterday. Then today, the engine oil dropped from 0.5L to 0.1L within 200Km of travel. (At this point, the car travelled total of 1,600Km and have 0.1L of engine oil left). I stopped at next service station and topped off the engine oil with a 1 liter bottle of 10W-60. (I didn't empty the whole bottle as the computer showed 0.1L left inside the engine)
When I recheck the engine oil level, it showed 0.9L after refill. So I resumed the travel again. Within 20Km of travel from then, the oil level dropped again to 0.8L. However, after that the oil level maintained on 0.8L although I drove another 160Km from that point. Currently, it is showing 0.8L at around 1,800Km. (Used 1 Liter of Engine Oil within 1,600Km)
Here are some key points to consider:
-The rate of engine oil droppage is not consistant or relavant to the distance travelled. Sometimes, it drops large amount in short time and sometimes it doesn't.
-The rate of engine oil droppage is not consistant with how hard the car is driven.
-At one point it dropped 0.4 Liters of oil within 200Km of travel. But at the end of travel, it didn't drop any oil level at all within 160Km of travel.
-There is no trace of engine oil under the car. As I was fully aware of VANOS OIL LINE FAILURE ISSUE, I knew what to watch out for. When I noticed the engine oil dropping fast, I started to check under the car every time I park the car somewhere. There is only some water dropping (suspect air conditioner relater) but no oil dropping at all.
It seems the rate of oil leak is too slow to be considered as VANOS OIL LINE FAILURE but too fast for normal engine oil consumption. I try hard to look for any oil trace but there is none. Is this normal or do you guys suspect something is wrong? If so, what do you think is wrong? I've scheduled to take the car in to BMW dealer for 2,000Km service in 6 days but I want to know whether I should be concerned of this or not. I would appreciate any help you can provide.
Thank you.
507bhp is offline
Old 10th December 2005, 13:29   #2
Tim_M
Tim_M's Avatar
Garage: Jerez Black M3 cab
Re: Engine Oil Leak Suspected! Please Help! URGENT!!!
That actually sounds about normal - the car uses a lot of oil during the first 2000 km, and the oil level drops inconsistently. Just keep checking the oil level by performing a rapid check before you leave the car - pull up the Idrive oil level indicator before holding in the BC button as it will give you more information.
I understand that you are nervous - we all are at the moment, and it appears that BMW are allowing pro-active, pre-emptive replacement of oil lines on cars built during the affected period now that oil lines are readily available (the lead time is down to 5 days now, and while some will disagree with me, I think that is acceptable). Do you know the build week of your car? If not your salesman will be able to tell you. I seem to remember you bought a UK car and exported it.
Tim
Tim_M is offline
Old 10th December 2005, 14:32   #3
360bhp
360bhp's Avatar
Garage: M5 black
Tim - when was the affected period for the suspect cars ?
Thanks.
360bhp is offline
Old 10th December 2005, 15:17   #4
Tim_M
Tim_M's Avatar
I'm not 100% sure of the end date (I should find out next week) but it is week 36-48. The end week might be earlier, I'm just going on ALL the posts I've read on here. It is difficult though sifting through all the noise. I've got the workshop manager at Vines on the case, and if and when he gets an answer from the factory I'll post it here. I must admit my experience has been fine - I presented them with the information I gathered from here, a line was ordered and it arrived in four working days. My car is being picked up on Tuesday morning to have a new line fitted. Having a decent dealer helps!
Tim
Tim_M is offline
Old 10th December 2005, 17:31   #5
bavarian
bavarian's Avatar
Garage: 2008 M5 space grey/silverstone
Sounds perfectly normal for this car. My M5 now has 2200 miles. Here were my oil readings:
20-800 miles 0.8
800-900 0.5
900-1050 0.4
Oil change/1200 mi service
1050-2080 0.8
2080-2140 0.5
2140-2200 0.4
If you plot the oil useage the chart is non-linear. As long as there are no visible leaks, I think you have nothing to worry about.
2008 M5 Space grey/Silverstone/Aluminum
2008 MB CLS 63 flint grey/grey
(SOLD 04/2009)
2006 M5 Sapphire black/Sepang/Olive (SOLD 11/2008)
2006 Maserati QP silver/black
2008 Jeep Wrangler Unlimited Sahara black/grey
bavarian is offline
Old 10th December 2005, 17:33   #6
360bhp
360bhp's Avatar
Garage: M5 black
thanks Tim - btw which prodn week was yr car ?
360bhp is offline
Old 10th December 2005, 17:34   #7
Jamie140
Jamie140's Avatar
Garage: '03 360 spider, '06 M5
I agree with these guys. It sounds like normal oil consumption. Watch for a precipitous drop.
'08 997TT Cab.
'04 Carrera GT
Jamie140 is offline
Old 10th December 2005, 17:49   #8
Filthy Monkey
Filthy Monkey's Avatar
Garage: E60 M5, Silverstone II with Black
It does sound pretty normal. Oil consumption seems to be quite erratic during the run in period and, to be honest, I am not 100% convinced that the dashboard readout is entirely accurate all of the time. However, I have found that things tend to improved after the car has gone through it's first service. I have only used 0.3 litres of oil in the past 4,000 miles, despite going through over 1 litre during the run in period.
E92 M3 - Jerez Black with Fox Red
E60 M5 - Gone
E63 M6 - Gone
Filthy Monkey is offline
Old 10th December 2005, 18:13   #9
desualt
desualt's Avatar
Garage: 2007 335i coupe
Man, reading the title of your topic I was expecting something desastrous, well, like others said, running in this car takes oil so drop down the panic flag and drive/enjoy the car, it will settle down soon.
Mine did the same by the way, at 4400km now and the rate of oil dropping is slowing down, have fate!
_____________
MY PICTURES
06E60M5 Interlagos/black... Sold.
Maya STM 20" on Michelin PS2's
Hartge exhaust with X pipe
H&R spacers. H&R springs.
07 335i coupe, Saphire black/jade grey
19" on style 230, Sirius, prem, Step.
Procede, 333rwhp,400rwt (for now )
23000km,
Robert
desualt is offline
Old 10th December 2005, 18:59   #10
MEnthusiast
MEnthusiast's Avatar
Garage: 03 M5
I think given the justifiable concern over proper measuring of the oil in with the new high tech V10 engine and its electronic measurement system, I can understand Member 507bhp's choice. He was worried. Fortunately it appears that he is OK for now.
All the best,
MEnthusiast is offline
Customer Advisory letter from BMWNA regarding Vanos oil line Lohe E60 M5 and E61 M5 Touring Discussion 52 12th December 2005 20:01
$4k Vanos Oil Leak dagone E39 M5 and E52 Z8 Discussion 12 11th March 2005 07:01
More engine Pics Black M5 E60 M5 and E61 M5 Touring Discussion 2 28th June 2004 23:38
Dam !! rear engine seal oil leak GregC E39 M5 and E52 Z8 Discussion 35 10th January 2004 00:08
engine oil shortage michel E39 M5 and E52 Z8 Discussion 4 1st April 2000 16:05
Page generated in 0.15928 seconds with 11 queries
