Burnout's and Launch Control with bad wheel hop! - BMW M5 Forum and M6 Forums
post #1 of 30 Old 8th November 2005, 11:37 AM Thread Starter
4rotor
Hi all,
Had a play around this morning, having trouble doing a burnout! I think I need to find that happy medium of revs vs brakes!
Reason I was trying to do a burnout is because I tried Launch Control for he first time today. MAN!!! it has terrible wheel hop/tramping, which is basically when the rear wheels bounce up and down on the road as they are spinning - trying to get traction. It really isn't a nice feeling (feels like the diff. is going to fall out!) - so I pulled my foot out!
So, to overcome this wheel hop problem - I have done this on other cars before (RX-7 is the first one that comes to mind, as it had really bad wheel hop). Doing some solid burnouts in the RX-7 sorted the tyres, so that I could then do hard launches getting lots of traction and no wheel hop.
So trying to do this with the M5 now, and it appears to be a little bit of a mission to get it to do a burnout. Anyone got any tips?
Cheers,
Glenn
4rotor is offline
post #2 of 30 Old 8th November 2005, 11:55 AM
1.NEON
1.NEON's Avatar
Re: Burnout's and Launch Control with bad wheel hop!
Only used launch control once and absolutely no axle hop, out of the blocks incredibly fast.
Car slow out of the blocks without it, would be interested to see if you can use launch control without the full throttle and a 4k launch. I was hoping you could launch with say 2.5-3k revs but haven't tried that yet, if anyone else has tried this please give us your impressions.
1.NEON is offline
post #3 of 30 Old 8th November 2005, 12:01 PM Thread Starter
4rotor
Hi Peter,
I found that you couldn't launch it at lower revs, I tried 2k, 2.5k, 3k, 3.5k - and nothing happens when you let go of the lever.
I have managed to increase my revs to just under 5K (what it has on the tachno) - by pushing the cruise control lever forward, it is meant to be movable up and down by 500rpm from reading the manual. But I found that the needle just hovers slightly under 5K on mine.
Cheers,
Glenn
4rotor is offline
post #4 of 30 Old 8th November 2005, 12:06 PM
Tim_M
Tim_M's Avatar
You guys really should read the manual! You can adjust the launch control revs by using the cruise control stalk - I can't remember the adjustment range off the top of my head.
Edit: Note to self: read posts before replying to them!
Tim
Last edited by Tim_M; 8th November 2005 at 12:08 PM. Reason: Edited to remove foot from mouth!
Tim_M is offline
post #5 of 30 Old 8th November 2005, 01:43 PM
cidair
cidair's Avatar
No axle hop whatsoever ( had it on the E39 sometimes )!
Tried both LC and DSC off takeoffs with a lot of wheels spin in 1st 2nd and 3rd. Temperatures where + 25 deg C.
2012 /// M5 F10 Silverstone/Black.
2011 K1600GT Light Grey
Previous:
2011 550ixDrive M Sport Space Grey/Black.
2008 M3 E92 Alpine White/Black.
2007 330xdAT TiSi/Black.
2005 /// M5 Silverstone/Black.
2004 545iA, TiSi/Black.
2000 /// M5 Carbon Black / Black.
cidair is offline
post #6 of 30 Old 8th November 2005, 02:07 PM
greggb
Think you feeling things that aren't there...
There is nothing greater than a BMW Launch Control..
greggb is offline
post #7 of 30 Old 8th November 2005, 02:20 PM Thread Starter
4rotor
I know what it is! feels like you have left the diff on the road.
A video would prove it for you!
Cheers,
Glenn
4rotor is offline
post #8 of 30 Old 8th November 2005, 02:27 PM
Spiroman
Much depends on the surface you're on and the tire compound and tread pattern. Try it on a skid pad with slicks and see what happens!
Best regards,
Spiroman is offline
post #9 of 30 Old 8th November 2005, 02:30 PM
StealthBlue
StealthBlue's Avatar
StealthBlue is offline
post #10 of 30 Old 8th November 2005, 03:03 PM
e6tme
Tim
What is the exact procedure for this? Our manuals in the USA say nothing about this.
Anyone whose already had their 1200 mile want to give it a try??
e6tme is offline
